SMB5361A
SMB5361A
    XCH(旭昌辉)
    DO-214AA(SMB)
SMB5361A 数据手册
SMB53xxA SERIES Surface Mount Silicon Zener Diodes Zener Voltage 3.3 ~ 200 V 5.0 Watt Power Dissipation DO-214AA(SMB) Features ● Glass passivated chip ● Built-in strain relief ● Low inductance ● High peak reverse power dissipation ● Low reverse leakage ● For use in stabilizing and clipping with high power ra ● High temperature soldering guaranteed: 260℃/10seconds ● RoHS compliant Mechanical Data Unit: inch(mm) ● Case: DO-214AA Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant ● Polarity: Color band denotes cathode end ● Parameter Mounting position: Any Symbols Value Unit DC Power dissipation at TL = 75 °C(1) PD 5.0 W Maximum forward voltage at if=200mA VF 1.2 V RθJA 65 ℃/W Junction temperature range TJ,TSTG -55 to +150 ℃ Storage temperature range TJ,TSTG -55 to +150 ℃ Typical thermal resistance(2) Note: (1)TL=Lead temperature at 3/8'' (9.5mm)from body; (2)Thermal resistance from junction to ambient and from junction to lead mounted on P. 0.3" x 0.3" (8.0 mm x 8.0 mm) copper pad areas. SMB53xxA SERIES Surface Mount Silicon Zener Diodes Ratings and Characteristics Curves (TA=25℃ unless otherwise noted) SMB53xxA SERIES Surface Mount Silicon Zener Diodes Part Number SMB5333A SMB5334A SMB5335A SMB5336A SMB5337A SMB5338A SMB5339A SMB5340A SMB5341A SMB5342A SMB5343A SMB5344A SMB5345A SMB5346A SMB5347A SMB5348A SMB5349A SMB5350A SMB5351A SMB5352A SMB5353A SMB5354A SMB5355A SMB5356A SMB5357A SMB5358A SMB5359A SMB5360A SMB5361A SMB5362A SMB5363A SMB5364A SMB5365A SMB5366A SMB5367A SMB5368A SMB5369A SMB5370A SMB5371A SMB5372A SMB5373A SMB5374A SMB5375A SMB5376A SMB5377A SMB5378A SMB5379A SMB5380A SMB5381A SMB5382A SMB5383A SMB5384A SMB5385A SMB5386A SMB5387A SMB5388A Device Marking Code 333A 334A 335A 336A 337A 338A 339A 340A 341A 342A 343A 344A 345A 346A 347A 348A 349A 350A 351A 352A 353A 354A 355A 356A 357A 358A 359A 360A 361A 362A 363A 364A 365A 366A 367A 368A 369A 370A 371A 372A 373A 374A 375A 376A 377A 378A 379A 380A 381A 382A 383A 384A 385A 386A 387A 388A Nominal Zener Voltage @IT Maximum Zener Impedance IZT(mA) VZ AVE.(V) VZ MIN.(V) VZ MAX.(V) 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.0 6.2 6.8 7.5 8.2 8.7 9.1 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 22.0 24.0 25.0 27.0 28.0 30.0 33.0 36.0 39.0 43.0 47.0 51.0 56.0 60.0 62.0 68.0 75.0 82.0 87.0 91.0 100.0 110.0 120.0 130.0 140.0 150.0 160.0 170.0 180.0 190.0 200.0 3.14 3.42 3.71 4.09 4.47 4.85 5.32 5.70 5.89 6.46 7.13 7.79 8.27 8.65 9.50 10.45 11.40 12.35 13.30 14.25 15.20 16.15 17.10 18.05 19.00 20.90 22.80 23.75 25.65 26.60 28.50 31.35 34.20 37.05 40.85 44.65 48.45 53.20 57.00 58.90 64.60 71.25 77.90 82.65 86.45 95.00 104.50 114.00 123.50 133.00 142.50 152.00 161.50 171.00 180.50 190.00 3.47 3.78 4.10 4.52 4.94 5.36 5.88 6.30 6.51 7.14 7.88 8.61 9.14 9.56 10.50 11.55 12.60 13.65 14.70 15.75 16.80 17.85 18.90 19.95 21.00 23.10 25.20 26.25 28.35 29.40 31.50 34.65 37.80 40.95 45.15 49.35 53.55 58.80 63.00 65.10 71.40 78.75 86.10 91.35 95.55 105.00 115.50 126.00 136.50 147.00 157.50 168.00 178.50 189.00 199.50 210.00 380 350.0 320.0 290.0 260.0 240.0 220.0 200.0 200.0 175.0 175.0 150.0 150.0 150.0 125.0 125.0 100.0 100.0 100.0 75.0 75.0 70.0 65.0 65.0 65.0 50.0 50.0 50.0 50.0 50.0 40.0 40.0 30.0 30.0 30.0 25.0 25.0 20.0 20.0 20.0 20.0 20.0 15.0 15.0 15.0 12.0 12.0 10.0 10.0 8.0 8.0 8.0 8.0 5.0 5.0 5.0 Maximum Reverse Leakage Current Maximum DC Zener Current ZZT MAX.(Ω) @IZT ZZK MAX.(Ω) @IZK IZK(mA) IR(uA) @VR VR(V) IZM(mA) 3.0 2.5 2.0 2.0 2.0 1.5 1.0 1.0 1.0 1.0 1.5 1.5 2.0 2.0 2.0 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 3.0 3.0 3.5 3.5 4.0 5.0 6.0 8.0 10.0 11.0 14.0 20.0 25.0 27.0 35.0 40.0 42.0 44.0 45.0 65.0 75.0 75.0 90.0 125.0 170.0 190.0 230.0 330.0 350.0 380.0 430.0 450.0 480.0 400 500 500 500 450 400 400 300 200 200 200 200 200 150 125 125 125 100 75 75 75 75 75 75 75 75 100 110 120 130 140 150 160 170 190 210 230 280 350 400 500 620 720 760 760 800 1000 1150 1250 1500 1500 1650 1750 1750 1850 1850 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 300 150 50 10 5 1.0 1.0 1.0 1.0 10.0 10.0 10.0 10.0 7.5 5 5 2 1 1 1 1 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 1.0 1.0 2.0 3.0 3.0 5.2 5.7 6.2 6.6 6.9 7.6 8.4 9.1 9.9 10.6 11.5 12.2 12.9 13.7 14.4 15.2 16.7 18.2 19.0 20.6 21.2 22.8 25.1 27.4 29.7 32.7 35.8 38.8 42.6 42.5 47.1 51.7 56.0 62.2 66.0 69.2 76.0 83.6 91.2 98.8 106.0 114.0 122.0 129.0 137.0 144.0 152.0 1437.0 1317.0 1216.0 1103.0 1009.0 930.0 846.0 790.0 765.0 700.0 630.0 580.0 545.0 520.0 475.0 430.0 395.0 365.0 340.0 315.0 295.0 280.0 265.0 250.0 237.0 216.0 198.0 190.0 176.0 170.0 158.0 144.0 132.0 122.0 110.0 100.0 93.0 86.0 79.0 76.0 70.0 63.0 58.0 54.5 52.5 47.5 43.0 39.5 36.6 34.0 31.6 29.4 28.0 26.4 25.0 23.6 Remark: The device numbers listed have a standard tolerance on the nominal zener voltage of ±5%.
SMB5361A 价格&库存
很抱歉,暂时无法提供与“SMB5361A”相匹配的价格&库存,您可以联系我们找货
SMB5361A
    • 5+0.65924
    • 50+0.53828
    • 150+0.47780
    • 500+0.43244
    • 3000+0.37347
    • 6000+0.35532
    库存:2116
