SMB3Z3.3A
SMB3Z3.3A
    XCH(旭昌辉)
    DO-214AA(SMB)
SMB3Z3.3A 数据手册
SMB3ZxxA SERIES Surface Mount Silicon Zener Diodes Zener Voltage 3.3 ~ 250 V 3.0 Watt Power Dissipation DO-214AA(SMB) Features ● Glass passivated chip ● Built-in strain relief ● Low inductance ● High peak reverse power dissipation ● Low reverse leakage ● For use in stabilizing and clipping with high power rating ● RoHS compliant Mechanical Data Unit: inch(mm) ● Case: DO-214AA Molded plastic ● Lead: Solderable per MIL-STD-750, method 2026 ● Epoxy: UL 94V-0 rate flame retardant ● Polarity: Color band denotes cathode end ● Mounting position: Any Parameter Symbols Value Unit PD 3.0 W VF 1.2 V Junction temperature range TJ,TSTG -55 to +150 ℃ Storage temperature range TJ,TSTG -55 to +150 ℃ DC Power dissipation at TL = 75 °C (1) Maximum forward voltage at if=200mA Note: (1)TL=Lead temperature at 3/8'' (9.5mm)from body SMB3ZxxA SERIES Surface Mount Silicon Zener Diodes Ratings and Characteristics Curves (TA=25℃ unless otherwise noted) SMB3ZxxA SERIES Surface Mount Silicon Zener Diodes Part Number SMB3Z3.3A SMB3Z3.6A SMB3Z3.9A SMB3Z4.3A SMB3Z4.7A SMB3Z5.1A SMB3Z5.6A SMB3Z6.2A SMB3Z6.8A SMB3Z7.5A SMB3Z8.2A SMB3Z9.1A SMB3Z10A SMB3Z11A SMB3Z12A SMB3Z13A SMB3Z14A SMB3Z15A SMB3Z16A SMB3Z17A SMB3Z18A SMB3Z19A SMB3Z20A SMB3Z22A SMB3Z24A SMB3Z27A SMB3Z30A SMB3Z33A SMB3Z36A SMB3Z39A SMB3Z43A SMB3Z47A SMB3Z51A SMB3Z56A SMB3Z62A SMB3Z68A SMB3Z75A SMB3Z82A SMB3Z91A SMB3Z100A SMB3Z110A SMB3Z120A SMB3Z130A SMB3Z140A SMB3Z150A SMB3Z160A SMB3Z170A SMB3Z180A SMB3Z190A SMB3Z200A SMB3Z210A SMB3Z220A SMB3Z230A SMB3Z240A SMB3Z250A Device Marking Code 3H0 3H1 3H2 3H3 3H4 3H5 3H6 3A0 3A1 3A2 3A3 3A4 3A5 3A6 3A7 3A8 3A9 3B0 3B1 3B2 3B3 3B4 3B5 3B6 3B7 3B8 3B9 3C0 3C1 3C2 3C3 3C4 3C5 3C6 3C7 3C8 3C9 3F0 3F1 3F2 3F3 3F4 3F5 3F6 3F7 3F8 3F9 3G1 3G2 3G3 3G4 3G5 3G6 3G7 3G8 Nominal Zener Voltage @IT Maximum Zener Impedance IZT(mA) VZ AVE.(V) VZ MIN.(V) VZ MAX.(V) 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10.0 11.0 12.0 13.0 14.0 15.0 16.0 17.0 18.0 19.0 20.0 22.0 24.0 27.0 30.0 33.0 36.0 39.0 43.0 47.0 51.0 56.0 62.0 68.0 75.0 82.0 91.0 100.0 110.0 120.0 130.0 140.0 150.0 160.0 170.0 180.0 190.0 200.0 210.0 220.0 230.0 240.0 250.0 3.14 3.42 3.71 4.09 4.47 4.85 5.32 5.89 6.46 7.13 7.79 8.65 9.50 10.45 11.40 12.35 13.30 14.25 15.20 16.15 17.10 18.05 19.00 20.90 22.80 25.65 28.50 31.35 34.20 37.05 40.85 44.65 48.45 53.20 58.90 64.60 71.25 77.90 86.45 95.00 104.50 114.00 123.50 133.00 142.50 152.00 161.50 171.00 180.50 190.00 199.50 209.00 218.50 228.00 237.50 3.47 3.78 4.10 4.52 4.94 5.36 5.88 6.51 7.14 7.88 8.61 9.56 10.50 11.55 12.60 13.65 14.70 15.75 16.80 17.85 18.90 19.95 21.00 23.10 25.20 28.35 31.50 34.65 37.80 40.95 45.15 49.35 53.55 58.80 65.10 71.40 78.75 86.10 95.55 105.00 115.50 126.00 136.50 147.00 157.50 168.00 178.50 189.00 199.50 210.00 220.50 231.00 241.50 252.00 262.50 227.3 208.3 192.0 174.0 160.0 147.0 134.0 121.0 110.0 100.0 91.0 82.0 75.0 68.0 63.0 58.0 53.0 50.0 47.0 44.0 42.0 40.0 37.0 34.0 31.0 28.0 25.0 23.0 21.0 19.0 17.0 16.0 15.0 13.0 12.0 11.0 10.0 9.1 8.2 7.5 6.8 6.3 5.8 5.3 5.0 4.7 4.4 4.2 4.0 3.7 3.5 3.3 3.1 2.9 2.7 Maximum Reverse Leakage Current Maximum DC Zener Current ZZT MAX.(Ω) @IZT ZZK MAX.(Ω) @IZK IZK(mA) IR(uA)@VR VR(V) IZM(mA) 10.0 9.0 4.5 4.5 4.0 3.5 2.5 1.5 2.0 2.0 2.3 2.5 3.5 4.0 4.5 4.5 5.0 5.5 5.5 6.0 6.0 7.0 7.0 8.0 9.0 10.0 16.0 20.0 22.0 28.0 33.0 38.0 45.0 50.0 55.0 70.0 85.0 95.0 115.0 160.0 225.0 300.0 375.0 475.0 550.0 625.0 650.0 700.0 800.0 875.0 950.0 1600.0 2000.0 2500.0 3000.0 500.0 500.0 400.0 400.0 500.0 550.0 600.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 700.0 750.0 750.0 750.0 750.0 750.0 750.0 750.0 1000.0 1000.0 1000.0 1000.0 1500.0 1500.0 1500.0 2000.0 2000.0 2000.0 2000.0 3000.0 3000.0 3000.0 4000.0 4500.0 5000.0 5000.0 6000.0 6500.0 7000.0 7000.0 8000.0 8000.0 8300.0 8500.0 9000.0 9000.0 9500.0 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 1.00 0.50 0.50 0.50 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 100.0 100.0 100.0 50.0 50.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 1.0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 7.6 8.4 9.1 9.9 10.6 11.4 12.2 13.0 13.7 14.4 15.2 16.7 18.2 20.6 22.5 25.1 27.4 29.7 32.7 35.6 38.8 42.6 47.1 51.7 56.0 62.2 69.2 76.0 83.6 91.2 98.8 106.4 114.0 121.6 130.4 136.8 144.8 152.0 169.0 178.0 186.0 195.0 205.0 817.0 749.0 691.0 627.0 573.0 528.0 481.0 435.0 393.0 360.0 330.0 297.0 270.0 225.0 246.0 208.0 193.0 180.0 169.0 159.0 150.0 142.0 135.0 123.0 112.0 100.0 90.0 82.0 75.0 69.0 63.0 57.0 53.0 48.0 44.0 40.0 36.0 33.0 30.0 27.0 25.0 22.0 21.0 19.0 18.0 17.0 16.0 15.0 14.0 13.0 12.3 11.6 10.9 10.2 9.5
SMB3Z3.3A 价格&库存
很抱歉,暂时无法提供与“SMB3Z3.3A”相匹配的价格&库存,您可以联系我们找货
SMB3Z3.3A
    • 5+0.54778
    • 50+0.53579
    • 150+0.52780
    • 500+0.51981
    库存:494
