1SMB5913B THRU 1SMB5956B SMB
Silicon Planar Zener Diodes
Pinning
1.Cathode
1
FEATURES
Total power dissipation: Max. 3 W.
Wide zener reverse voltage range 3.3V to 200V.
plastic package suitable for surface mounted design.
2.Anode
2
DO-214AA/SMB
Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
Case: DO-214A A /SMB
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 0.95g / 0.003oz
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Parameter
Symbol
DC power dissipation at TL=75°C, measure at zero lead length (Note 1)
derate above 75°C
PD
Maximum Steady State Power Dissipation @ TA=25°C
Derate above 25°C
PD
Value
Unit
3.0
W
40
mW/°C
550
mW
4.4
mW/°C
Junction to ambient thermal resistance
RthJA
226
°C/W
Junction to lead thermal resistance
RthJL
25
°C/W
Junction Temperature Range
TJ
55 ~ +150
°C
Storage Temperature Range
TSTG
-55 ~ +150
°C
PD mAXIMUM POWER DISSPATION (W)
Note: 1. Mounted on Cu-Pad size 5mm x 5mm on PCB.
Fig.1 Forward Current Derating Curve
5.0
4.0
3.0
2.0
1.0
0.0
Single phase half-wave 60 Hz
resistive or inductive load
25
50
75
100
125
150
175
Case Temperature (°C)
www.yfwdiode.com
1/4
G uangDong YFW Electronics Co, Ltd.
ELECTRICAL CHARACTERISTICS
(T L = 30°C unless otherwise noted,
V F = 1.5 V Max. @ I F = 200 mA(DC) for all types)
Parameter
Symbol
Vz
Reverse Zener Voltage @ I ZT
I ZT
Reverse Current
Z ZT
Maximum Zener Impedance @ I ZT
I ZK
Reverse Current
Z ZK
Maximum Zener Impedance @ I ZK
IR
Reverse Leakage Current @ V R
VR
Reverse Voltage
IF
Forward Current
VF
Forward Voltage @ I F
I ZM
Maximum DC Zener Current
I
IF
VR
VZ
IR VF
V
I ZT
Zener Voltage Regulator
Notes On Page 3:
1. Tolerance and type number designation the type numbers listed indicate a tolerance of 5%
2. Zener voltage (Vz) measurement
Nominal Zener v oltage is measured with the device junction in thermal equilibrium with ambient temperature 25°C
3. Zener impedance (Zz) derivation : Z ZT and Z ZK are measured by dividing the AC voltage
drop across the device by the AC current applied.
The specified limits are for Iz(AC) = 0.1 Iz(DC) with the AC frequency = 60 Hz
www.yfwdiode.com
2/4
Characteristics at Ta = 25°C (Devices listed in bold, italic are ON Semiconductor Preferred devices.)
(TL = 30°C unless otherwise noted, VF = 1.5 V Max. @ IF = 200 mA(DC) for all types)
Nominal Zener Voltage
Type
Marking
913B
I ZT
Z ZT@ I ZT
(mA)
(Ω)
Vz
Min(V)
1SMB5913B
Zener (4)
Impedance
(3)
3.13
Nom(V)
3.3
(2)
Max(V)
3.47
113.6
10
Leakage Current
IR @ VR
Z ZK@ I ZK
(Ω)
(mA)
500
1
Maximum DC
Zener Current
(V)
I ZM (mA)(DC)
100
1
454
(μA)
1SMB5914B
914B
3.42
3.6
3.78
104.2
9
500
1
75
1
416
1SMB5915B
915B
3.70
3.9
4.10
96.1
7.5
500
1
25
1
384
1SMB5916B
916B
4.08
4.3
4.52
87.2
6
500
1
5
1
348
1SMB5917B
917B
4.46
4.7
4.94
79.8
5
500
1
5
1.5
319
1SMB5918B
918B
4.84
5.1
5.36
73.5
4
350
1
5
2
294
1SMB5919B
919B
5.32
5.6
5.88
66.9
2
250
1
5
3
267
1SMB5920B
920B
5.89
6.2
6.51
60.5
2
200
1
5
4
241
1SMB5921B
921B
6.46
6.8
7.14
55.1
2.5
200
1
5
5.2
220
1SMB5922B
922B
7.12
7.5
7.88
50
3
400
0.5
5
6
200
1SMB5923B
923B
7.79
8.2
8.61
45.7
3.5
400
0.5
5
6.5
182
1SMB5924B
924B
8.64
9.1
9.56
41.2
4
500
0.5
5
7
164
1SMB5925B
925B
9.5
10
10.5
37.5
4.5
500
0.25
5
8
150
1SMB5926B
926B
10.45
11
11.55
34.1
5.5
550
0.25
1
8.4
136
1SMB5927B
927B
11.4
12
12.6
31.2
6.5
550
0.25
1
9.1
125
1SMB5928B
928B
12.35
13
13.65
28.8
7
550
0.25
1
9.9
115
1SMB5929B
929B
14.25
15
15.75
25
9
600
0.25
1
11.4
100
1SMB5930B
930B
15.2
16
16.8
23.4
10
600
0.25
1
12.2
93
1SMB5931B
931B
17.1
18
18.9
20.8
12
650
0.25
1
13.7
83
1SMB5932B
932B
19
18.7
14
650
0.25
1
15.2
75
1SMB5933B
933B
20.9
22
23.1
17
17.5
650
0.25
1
16.7
68
1SMB5934B
934B
22.8
24
25.2
15.6
19
700
0.25
1
18.2
62
1SMB5935B
935B
25.65
27
28.35
13.9
23
700
0.25
1
20.6
55
1SMB5936B
936B
28.5
30
31.5
12.5
28
750
0.25
1
22.8
50
1SMB5937B
937B
31.35
33
34.65
11.4
33
800
0.25
1
25.1
45
1SMB5938B
938B
34.2
36
37.8
10.4
38
850
0.25
1
27.4
41
1SMB5939B
939B
37.05
39
40.95
9.6
45
900
0.25
1
29.7
38
1SMB5940B
940B
40.85
43
45.15
8.7
53
950
0.25
1
32.7
34
1SMB5941B
941B
44.65
47
49.35
8
67
1000
0.25
1
35.8
31
1SMB5942B
942B
48.45
51
53.55
7.3
70
1100
0.25
1
38.8
29
1SMB5943B
943B
53.2
56
58.8
6.7
86
1300
0.25
1
42.6
26
1SMB5944B
944B
58.9
62
65.1
6
100
1500
0.25
1
47.1
24
1SMB5945B
945B
64.6
68
71.4
5.5
120
1700
0.25
1
51.7
22
1SMB5946B
946B
71.25
75
78.75
5
140
2000
0.25
1
56
1SMB5947B
947B
77.9
82
86.1
4.6
160
2500
0.25
1
62.2
18
1SMB5948B
948B
86.45
91
95.55
4.1
200
3000
0.25
1
69.2
16
1SMB5949B
949B
95
100
105
3.7
250
3100
0.25
1
76
15
1SMB5950B
950B
104.5
110
115.5
3.4
300
4000
0.25
1
83.6
13
1SMB5951B
951B
114
120
126
3.1
380
4500
0.25
1
91.2
12
1SMB5952B
952B
123.5
130
136.5
2.9
450
5000
0.25
1
98.8
11
1SMB5953B
953B
142.5
150
157.5
2.5
600
6000
0.25
1
114
10
1SMB5954B
954B
152
160
168
2.3
700
6500
0.25
1
121.6
9
1SMB5955B
955B
171
180
189
2.1
900
7000
0.25
1
136.8
8
1SMB5956B
956B
190
200
210
1.9
1200
8000
0.25
1
152
7
www.yfwdiode.com
3/4
DO-214AA SMB
Package Outline
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
UNIT
mm
mil
VM
A
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
E1
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
160
130
The recommended mounting pad size
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
Summary of Packing Options
Package
DO-214AA SMB
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
3000
EIA-481-1
4/4
很抱歉,暂时无法提供与“1SMB5918B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.60566
- 50+0.49055
- 150+0.43300
- 500+0.38992
- 3000+0.35536
- 6000+0.33809
