SMBJ53XXB-MS
Product specification
SMBJ53XXB-MS
Features
Low Profile Package for Surface Mountiong(Flat Handling Surface for Accurate Placement)
Zener Voltage 5.1V to 200V
Available on Tape and Reel(See E1A Std RS-481)
Moisture Sensitivity Level 1
Epoxy Meets UL 94 V-0 Flammability Rating
Lead Free Finish/RoHS Compliant (Note1) ("P" Suffix Designates Compliant. See Ordering Information)
Maximum Ratings
Operating Junction Temperature Range: -55°C to +150°C
Storage Temperature Range: -55°C to +150°C
Thermal Resistance:15°C/W Junction to Lead
Thermal Resistance:90°C/W Junction to Ambient(Note2)
Parameter
Symbol
Rating
Conditions
Steady State
Power Dissipation
P(AV)
5.0W
Note 3
Maximum Forward
Voltage
VF
1.2V
IF=1.0A
Note: 1.High Temperature Solder Exemption Applied, See EU Directive Annex 7a.
2.Ambient Temperature at 15°C = TA at Mounting Plane. Derate Linearly Above
15°C to Zero Power at 150°C
3.Lead Temperature at 75°C = TL at Mounting Plane. Derate Linearly Above
75°C to Zero Power at 150°C
Reference News
PACKAGE OUTLINE
Device Marking
MSKSEMI
369B
Cathode Band
Logo
Type No.
For Example: 339B for SMBJ5339B-MS
369B for SMBJ5369B-MS
SMB(DO-214AA)
Copyright© Msksemi Incorporated
www.msksemi.com
SMBJ53XXB-MS
Electrical Characteristics @ 25°C Unless Otherwise Specified
Part Number
SMBJ5338B-MS
SMBJ5339B-MS
SMBJ5340B-MS
SMBJ5341B-MS
SMBJ5342B-MS
SMBJ5343B-MS
SMBJ5344B-MS
SMBJ5345B-MS
SMBJ5346B-MS
SMBJ5347B-MS
SMBJ5348B-MS
SMBJ5349B-MS
SMBJ5350B-MS
SMBJ5351B-MS
SMBJ5352B-MS
SMBJ5353B-MS
SMBJ5354B-MS
SMBJ5355B-MS
SMBJ5356B-MS
SMBJ5357B-MS
SMBJ5358B-MS
SMBJ5359B-MS
SMBJ5360B-MS
SMBJ5361B-MS
SMBJ5362B-MS
SMBJ5363B-MS
SMBJ5364B-MS
SMBJ5365B-MS
SMBJ5366B-MS
SMBJ5367B-MS
SMBJ5368B-MS
SMBJ5369B-MS
SMBJ5370B-MS
SMBJ5371B-MS
SMBJ5372B-MS
SMBJ5373B-MS
SMBJ5374B-MS
SMBJ5375B-MS
SMBJ5376B-MS
SMBJ5377B-MS
SMBJ5378B-MS
SMBJ5379B-MS
SMBJ5380B-MS
SMBJ5381B-MS
SMBJ5382B-MS
SMBJ5383B-MS
SMBJ5384B-MS
SMBJ5385B-MS
SMBJ5386B-MS
SMBJ5387B-MS
SMBJ5388B-MS
Regulator
Voltage
Test Current
Maximum
Dynamic
Impedance
Maximum
Reverse
Current
Test
Voltage
Maximum
Regulator
Current
VZ
V
5.1
5.6
6
6.2
6.8
7.5
8.2
8.7
9.1
10
11
12
13
14
15
16
17
18
19
24
25
27
28
30
33
36
39
43
47
51
56
60
62
68
75
82
87
91
100
110
120
130
140
150
160
170
180
190
200
IZ
mA
240
220
200
200
175
175
150
150
150
125
125
100
100
100
75
75
70
65
65
65
50
50
50
50
50
40
40
30
30
30
25
25
15
15
12
12
10
10
8.0
8.0
8.0
8.0
5.0
5.0
5.0
ZZT
Ω
1.5
1
1
1
1
1.5
1.5
2
2
2
2.5
2.5
2.5
2.5
2.5
2.5
2.5
2.5
3
3
3.5
3.5
4
5
6
8
10
11
14
27
35
40
42
44
45
65
75
75
90
125
170
190
230
330
350
380
430
450
480
IR
µA
1
1
1
1
10
10
10
10
7.5
5
5
2
1
1
1
1
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
VR
V
1
2
3
3
5.2
5.7
6.2
6.6
6.9
7.6
8.4
9.1
9.9
10.6
11.5
12.2
12.9
13.7
14.4
15.2
16.7
18.2
19
20.6
21.2
22.8
25.1
27.4
29.7
32.7
35.8
38.8
42.6
45.5
47.1
51.7
56
62.2
66
69.2
76
83.6
91.2
98.8
106
114
122
129
137
144
152
IZM
mA
930
865
790
765
700
630
580
545
520
475
430
395
365
340
315
295
280
264
250
237
216
198
190
176
170
158
144
132
122
110
100
93
86
79
76
70
63
58
54.5
52.5
47.5
43
39.5
36.6
34
31.6
29.4
28
26.4
25
23.6
Maximum
Dynamic Knee
Impedance
ZZK @1.0mA
Ω
400
400
300
200
200
200
200
200
150
125
125
125
100
75
75
75
75
75
75
75
75
100
110
120
130
140
150
160
170
190
210
230
280
350
400
500
620
720
760
760
800
1000
1150
1250
1500
1500
1650
1750
1750
1850
1850
Maximum
Surge
Current
IZSM
A
14.4
13.4
12.7
12.4
11.5
10.7
10
9.5
9.2
8.6
8
7.5
7
6.7
6.3
6
5.8
5.5
5.3
5.1
4.7
4.4
4.3
4.1
3.9
3.7
3.5
3.3
3.1
2.8
2.7
2.5
2.3
2.2
2.1
2
1.9
1.8
1.7
1.6
1.5
1.4
1.3
1.2
1.2
1.1
1.1
1.0
1.0
0.9
0.9
Maximum
Voltage
Regulation
V
0.39
0.25
0.19
0.1
0.15
0.15
0.2
0.2
0.22
0.22
0.25
0.25
0.25
0.25
0.25
0.3
0.35
0.4
0.4
0.4
0.45
0.55
0.55
0.6
0.6
0.6
0.6
0.65
0.65
0.7
0.8
0.9
1
1.2
1.35
1.5
1.6
1.8
2
2.2
2.3
2.5
2.5
2.5
2.5
3
3
3
4
5
5
www.msksemi.com
SMBJ53XXB-MS
Remarks:
1. Devices Listed Have a ± 5% Tolerance on Nominal VZ. Suffix C Denotes a +2%
2. Nominal Zener Voltage (VZ) is Tested With a 40 +/-10 Milliseconds Pulse Current at 25°C to Avoid Self-heat Affection.
3. The Zener Impedance (ZZT or ZZK) is Derived from The 60HzAC Voltage, Which Results When an AC Current Having a
rms value Equal to 10% of the DC Zener Current (IZT or IZK) Respectively.
4. The Maximum Reverse(Leakage) Current is Specified for Devices With ± 20% and ± 10% Voltage Tolerances on Nominal VZ
in Another Column.
5. The Maximum Zener Current(IZM) Shown is for ± 5% Tolerance Devices. IZM for ± 10% and ± 20% Devices Can be
Calculated Using the Formula:
IZM =
P
V ZM
Where “VZM” is VZ at The High End of The Voltage Tolerance Specified and “P” is The Rated Power of The Device.
6. The Surge Current (IZM) is Specified As The Maximum Peak of a Nonrecurring Sine Wave of 8.3 Milliseconds Duration.
7. Voltage Regulation (ΔVZ) is The Difference Between The Voltage Measured at 10% and 50% (IZM).
www.msksemi.com
SMBJ53XXB-MS
PACKAGE MECHANICAL DATA
A
Dimensions
Millimeters
B
C
Ref.
H
F
G
D
E
L
J
K
Min.
Max.
Min.
Max.
A
4.25
4.75
0.167
0.187
B
3.30
3.94
0.130
0.155
C
1.85
2.21
0.073
0.087
D
0.76
1.52
0.030
0.060
E
5.08
5.59
0.200
0.220
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.11
2.44
0.083
0.096
J
6.80
L
0.270
2.60
K
DO-214AA (SMB)
Inches
2.40
0.100
0.090
REEL SPECIFICATION
P/N
PKG
QTY
SMBJ53XXB-MS
SMB
3000
www.msksemi.com
SMBJ53XXB-MS
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not
handle applications that require extremely high levels of reliability, such as life-support
have specifications
that can
systems, aircraft's control systems, or
other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with
your MSKSEMI Semiconductor representative
nearest
you before using any MSKSEMI Semiconductor products described
or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in
products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the
performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To
verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test
devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could
endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing
equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are
not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained
herein are controlled under any of applicable local export control laws and regulations, such products must not be exported
without obtaining the export license from theauthorities
concerned
in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior
written permission of MSKSEMI Semiconductor.
Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume
production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or
implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties.
Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI
Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“SMBJ5362B-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.01390
- 50+0.80978
- 150+0.72230
- 500+0.61314
- 3000+0.56454
- 6000+0.53538
