SMBJ5343B-MS
SMBJ5343B-MS
    MSKSEMI(美森科)
    DO-214AA(SMB)
SMBJ5343B-MS 数据手册
SMBJ53XXB-MS Product specification SMBJ53XXB-MS Features  Low Profile Package for Surface Mountiong(Flat Handling Surface for Accurate Placement)      Zener Voltage 5.1V to 200V Available on Tape and Reel(See E1A Std RS-481) Moisture Sensitivity Level 1 Epoxy Meets UL 94 V-0 Flammability Rating Lead Free Finish/RoHS Compliant (Note1) ("P" Suffix Designates Compliant. See Ordering Information) Maximum Ratings     Operating Junction Temperature Range: -55°C to +150°C Storage Temperature Range: -55°C to +150°C Thermal Resistance:15°C/W Junction to Lead Thermal Resistance:90°C/W Junction to Ambient(Note2) Parameter Symbol Rating Conditions Steady State Power Dissipation P(AV) 5.0W Note 3 Maximum Forward Voltage VF 1.2V IF=1.0A Note: 1.High Temperature Solder Exemption Applied, See EU Directive Annex 7a. 2.Ambient Temperature at 15°C = TA at Mounting Plane. Derate Linearly Above 15°C to Zero Power at 150°C 3.Lead Temperature at 75°C = TL at Mounting Plane. Derate Linearly Above 75°C to Zero Power at 150°C Reference News PACKAGE OUTLINE Device Marking MSKSEMI 369B Cathode Band Logo Type No. For Example: 339B for SMBJ5339B-MS 369B for SMBJ5369B-MS SMB(DO-214AA) Copyright© Msksemi Incorporated www.msksemi.com SMBJ53XXB-MS Electrical Characteristics @ 25°C Unless Otherwise Specified Part Number SMBJ5338B-MS SMBJ5339B-MS SMBJ5340B-MS SMBJ5341B-MS SMBJ5342B-MS SMBJ5343B-MS SMBJ5344B-MS SMBJ5345B-MS SMBJ5346B-MS SMBJ5347B-MS SMBJ5348B-MS SMBJ5349B-MS SMBJ5350B-MS SMBJ5351B-MS SMBJ5352B-MS SMBJ5353B-MS SMBJ5354B-MS SMBJ5355B-MS SMBJ5356B-MS SMBJ5357B-MS SMBJ5358B-MS SMBJ5359B-MS SMBJ5360B-MS SMBJ5361B-MS SMBJ5362B-MS SMBJ5363B-MS SMBJ5364B-MS SMBJ5365B-MS SMBJ5366B-MS SMBJ5367B-MS SMBJ5368B-MS SMBJ5369B-MS SMBJ5370B-MS SMBJ5371B-MS SMBJ5372B-MS SMBJ5373B-MS SMBJ5374B-MS SMBJ5375B-MS SMBJ5376B-MS SMBJ5377B-MS SMBJ5378B-MS SMBJ5379B-MS SMBJ5380B-MS SMBJ5381B-MS SMBJ5382B-MS SMBJ5383B-MS SMBJ5384B-MS SMBJ5385B-MS SMBJ5386B-MS SMBJ5387B-MS SMBJ5388B-MS Regulator Voltage Test Current Maximum Dynamic Impedance Maximum Reverse Current Test Voltage Maximum Regulator Current VZ V 5.1 5.6 6 6.2 6.8 7.5 8.2 8.7 9.1 10 11 12 13 14 15 16 17 18 19 20 22 24 25 27 28 30 33 36 39 43 47 51 56 60 62 68 75 82 87 91 100 110 120 130 140 150 160 170 180 190 200 IZ mA 240 220 200 200 175 175 150 150 150 125 125 100 100 100 75 75 70 65 65 65 50 50 50 50 50 40 40 30 30 30 25 25 20 20 20 20 20 15 15 15 12 12 10 10 8.0 8.0 8.0 8.0 5.0 5.0 5.0 ZZT Ω 1.5 1 1 1 1 1.5 1.5 2 2 2 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 3 3 3.5 3.5 4 5 6 8 10 11 14 20 25 27 35 40 42 44 45 65 75 75 90 125 170 190 230 330 350 380 430 450 480 IR µA 1 1 1 1 10 10 10 10 7.5 5 5 2 1 1 1 1 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 VR V 1 2 3 3 5.2 5.7 6.2 6.6 6.9 7.6 8.4 9.1 9.9 10.6 11.5 12.2 12.9 13.7 14.4 15.2 16.7 18.2 19 20.6 21.2 22.8 25.1 27.4 29.7 32.7 35.8 38.8 42.6 45.5 47.1 51.7 56 62.2 66 69.2 76 83.6 91.2 98.8 106 114 122 129 137 144 152 IZM mA 930 865 790 765 700 630 580 545 520 475 430 395 365 340 315 295 280 264 250 237 216 198 190 176 170 158 144 132 122 110 100 93 86 79 76 70 63 58 54.5 52.5 47.5 43 39.5 36.6 34 31.6 29.4 28 26.4 25 23.6 Copyright© Msksemi Incorporated Maximum Dynamic Knee Impedance ZZK @1.0mA Ω 400 400 300 200 200 200 200 200 150 125 125 125 100 75 75 75 75 75 75 75 75 100 110 120 130 140 150 160 170 190 210 230 280 350 400 500 620 720 760 760 800 1000 1150 1250 1500 1500 1650 1750 1750 1850 1850 Maximum Surge Current IZSM A 14.4 13.4 12.7 12.4 11.5 10.7 10 9.5 9.2 8.6 8 7.5 7 6.7 6.3 6 5.8 5.5 5.3 5.1 4.7 4.4 4.3 4.1 3.9 3.7 3.5 3.3 3.1 2.8 2.7 2.5 2.3 2.2 2.1 2 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.2 1.1 1.1 1.0 1.0 0.9 0.9 Maximum Voltage Regulation V 0.39 0.25 0.19 0.1 0.15 0.15 0.2 0.2 0.22 0.22 0.25 0.25 0.25 0.25 0.25 0.3 0.35 0.4 0.4 0.4 0.45 0.55 0.55 0.6 0.6 0.6 0.6 0.65 0.65 0.7 0.8 0.9 1 1.2 1.35 1.5 1.6 1.8 2 2.2 2.3 2.5 2.5 2.5 2.5 3 3 3 4 5 5 www.msksemi.com SMBJ53XXB-MS Remarks: 1. Devices Listed Have a ± 5% Tolerance on Nominal VZ. Suffix C Denotes a +2% 2. Nominal Zener Voltage (VZ) is Tested With a 40 +/-10 Milliseconds Pulse Current at 25°C to Avoid Self-heat Affection. 3. The Zener Impedance (ZZT or ZZK) is Derived from The 60HzAC Voltage, Which Results When an AC Current Having a rms value Equal to 10% of the DC Zener Current (IZT or IZK) Respectively. 4. The Maximum Reverse(Leakage) Current is Specified for Devices With ± 20% and ± 10% Voltage Tolerances on Nominal VZ in Another Column. 5. The Maximum Zener Current(IZM) Shown is for ± 5% Tolerance Devices. IZM for ± 10% and ± 20% Devices Can be Calculated Using the Formula: IZM = P V ZM Where “VZM” is VZ at The High End of The Voltage Tolerance Specified and “P” is The Rated Power of The Device. 6. The Surge Current (IZM) is Specified As The Maximum Peak of a Nonrecurring Sine Wave of 8.3 Milliseconds Duration. 7. Voltage Regulation (ΔVZ) is The Difference Between The Voltage Measured at 10% and 50% (IZM). Copyright© Msksemi Incorporated www.msksemi.com SMBJ53XXB-MS PACKAGE MECHANICAL DATA A Dimensions Millimeters B C Ref. H F G D E L J K Min. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 L 0.270 2.60 K DO-214AA (SMB) Inches 2.40 0.100 0.090 REEL SPECIFICATION P/N PKG QTY SMBJ53XXB-MS SMB 3000 Copyright© Msksemi Incorporated www.msksemi.com SMBJ53XXB-MS Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
SMBJ5343B-MS 价格&库存
很抱歉,暂时无法提供与“SMBJ5343B-MS”相匹配的价格&库存,您可以联系我们找货
SMBJ5343B-MS
    • 5+1.02284
    • 50+0.81872
    • 150+0.73124
    • 500+0.62208
    • 3000+0.57348
    • 6000+0.54432
    库存:4546
