1SMB5913B THRU 1SMB5956B
3.0W SURFACE MOUNT POWER ZENER DIODE
■ Features
3.0W Power Dissipation
Ideally Suited for Automated Assembly
3.3V - 200V Nominal Zener Voltage Range
Standard VZ Tolerance is ± 5%
ESD Rating of Class 3 (>8kV) per Human
Body Model
Lead-Free Finish; RoHS Compliant
■ Mechanical Data
● Case: SMB
● Case Material: Molded Plastic. UL Flammability Classification Rating 94V-0
● Moisture Sensitivity: Level 1 per J-STD-020
● Copper Alloy Leadframe with Lead-Free Plating (Matte Tin Finish). Solderable per MIL-STD-202, Method 208
● Polarity: Cathode Band
● Weight: 0.096 grams (Approximate)
Document Number:8080004
Revision:21-Apr-28
An hui Anmei Semiconductor Co.,Ltd.
www.amsemi.com.cn
~1~
Revision:21-Apr-28
www.amsemi.com.cn
~2~
Characteristics(Typical)
Revision:21-Apr-28
www.amsemi.com.cn
~3~
■ Ordering Information (Example)
PREFERED
PACKAGE CODE
MINIMUM
PACKAGE(pcs)
INNER BOX
QUANTITY(pcs)
OUTER CARTON
QUANTITY(pcs)
DELIVERY MODE
GS3AB THRU GS3MB
SMB
3000
6000
48000
13” reel
■ Outline Dimensions
DO-214AA(SMB)
.085 (2.15)
.073 (1.85)
.154(3 .90)
.130(3 .30)
M ounting P ad Layout
0.106
(2.69)
.187(4.75)
.161(4.10)
0.082
(2.10)
.091(2.30)
.083(2.10)
0.081(2.072)
.056(1.41)
.030(0.76)
.008(0.20)
.0 (0.00)
.220(5.60)
.200(5.10)
Revision:21-Apr-28
.012(0.31)
.006(0.15)
0 .220
(5.58)
D im ensions in inches and (m illim eters)
www.amsemi.com.cn
~4~
IMPORTANT NOTICE AND DISCLAIMER
AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA
WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD
OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN
PURCHASE OR USE.
AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or
in any other disclosure relating to any product.
All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application
requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no
warranties, representation or guarantee, whether express, implied or statutory, including, without limitation,
regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM.
AM does not assume any liability or compensation for any application assistance or customer product design,
and make no warranty or accept any liability with products, which are purchased or used for any unintended
or unauthorized application.
Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or
lifesustaining applications or for any other application in which the failure of the AM product could result in
personal injury or death. Customers using or selling AM products not expressly indicated for use in such
applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and
conditions regarding products designed for such applications.
No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this
document or by any conduct of AM. Product names and markings noted herein may be trademarks of their
respective owners.
Revision:21-Apr-28
www.amsemi.com.cn
~5~
很抱歉,暂时无法提供与“1SMB5929B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.50987
- 50+0.49799
- 150+0.49011
- 500+0.48222
