ES3DB
ES3DB
    JUXING(钜兴)
    DO-214AA(SMB)
ES3DB 数据手册
ES3A-ES3J Surface Mount Superfast Rectifiers Features ● Low profile package ● Ideal for automated placement ● Glass passivated chip junctions ● Fast switching for high efficiency ● High forward surge capability ● High temperature soldering: SMB(DO-214AA) 260℃/10 seconds at terminals ● 0.155(3.94) 0.130(3.30) Component in accordance to 0.086(2.2) 0.075(1.91) RoHS 2002/95/1 and WEEE 2002/96/EC 0.187(4.76) 0.160(4.06) Mechanical Date ● 0.012(0.305) 0.006(0.152) Case: JEDEC DO-214AA molded plastic 0.096(2.44) 0.083(2.13) body over glass passivated chip ● Terminals: Solder plated, solderable per J-STD-002B and JESD22-B102D ● 0.008(0.203) MAX 0.060(1.52) 0.030(0.76) 0.220(5.59) 0.200(5.08) Polarity: Laser band denotes cathode end Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics o Rating at 25 C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Type Number SYMBOL ES3A ES3B ES3C ES3D ES3E ES3G ES3J Unit Maximum Recurrent Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 V Maximum RMS Voltage VRMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 V Average Rectified Output Current @TL =100℃ IF(AV) 3.0 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 100 A Forward Voltage VFM @IF=3.0A Peak Reverse Current @TA =25 ℃ At Rated DC Blocking Voltage @TA =125 ℃ 2 IR 2 1.0 1.25 5.0 100 1.65 V uA I t Rating for fusing (t
ES3DB 价格&库存
很抱歉,暂时无法提供与“ES3DB”相匹配的价格&库存,您可以联系我们找货
ES3DB
  • 10+0.24624
  • 100+0.19895
  • 300+0.17524
  • 3000+0.15750
  • 6000+0.14333
  • 9000+0.13616
库存:2399
