1SMB5913B-1SMB5957B
Silicon Zener Diodes
VZ : 3.3 - 200 Volts
PD : 3.0 Watts
SMB/DO-214AA
Features
0.180(4.57)
0.160(4.06)
Complete Voltage Range 3.3 to 200 Volts
High peak reverse power dissipation
Flat handling surface for accurate placement
0.086(2.20)
0.077(1.95)
Low leakage current
0.155(3.94)
0.130(3.30)
0.209(5.30)
0.201(5.10)
Pb / RoHS Free
0.012(0.30)
0.006(0.15)
Mechanical Data
0.096(2.44)
0.084(2.13)
0.059(1.50)
Case : SMB (DO-214AA) Molded plastic
0.008(0.20)
0.035(0.90)
0.002(0.05)
Epoxy : UL94V-O rate flame retardant
Maximum Lead Temperature for Soldering Purposes :
Dimensions in inches and(millimeters)
260 °C for 10 Seconds
Leads : Modified L-Bend providing more contact area to bond pads.
Polarity : Cathode indicated by polarity band.
Mounting position : Any
Weight : 0.093 gram
MAXIMUM RATINGS
Rating
Symbol
Value
Unit
PD
3.0
W
40
mW/°C
RθJL
25
°C/W
PD
550
mW
4.4
mW/°C
RθJA
226
°C/W
Maximum Forward Voltage at I F = 200 mA
VF
1.5
Volts
Junction Temperature Range
TJ
- 65 to + 150
°C
Storage Temperature Range
Tstg
- 65 to + 150
°C
Maximum Steady State Power Dissipation at T L = 75°C,
Measured at Zero Lead Length
Derate Above 75 °C
Thermal Resistance From Junction to Lead
Maximum Steady State Power Dissipation at Ta = 25 °C
Derate Above 25 °C
Thermal Resistance From Junction to Ambient
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
1SMB5913B-1SMB5957B
ELECTRICAL CHARACTERISTICS
Rating at TL = 30 °C unless otherwise specified
TYPE
Nominal Zener
Maximum Zener
Maximum Reverse
Maximum DC
Voltage
Impedance
Leakage Current
Zener Current
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
(V)
(mA)
(Ω)
(Ω)
(mA)
(μA)
1SMB5913B
3.3
113.6
10
500
1.0
1SMB5914B
3.6
104.2
9.0
500
1.0
1SMB5915B
3.9
96.1
7.5
500
1SMB5916B
4.3
87.2
6.0
1SMB5917B
4.7
79.8
1SMB5918B
5.1
1SMB5919B
IR @ VR
IZM
(V)
(mA)
100
1.0
454
75
1.0
416
1.0
25
1.0
384
500
1.0
5.0
1.0
348
5.0
500
1.0
5.0
1.5
319
73.5
4.0
350
1.0
5.0
2.0
294
5.6
66.9
2.0
250
1.0
5.0
3.0
267
1SMB5920B
6.2
60.5
2.0
200
1.0
5.0
4.0
241
1SMB5921B
6.8
55.1
2.5
200
1.0
5.0
5.2
220
1SMB5922B
7.5
50.0
3.0
400
0.5
5.0
6.0
200
1SMB5923B
8.2
45.7
3.5
400
0.5
5.0
6.5
182
1SMB5924B
9.1
41.2
4.0
500
0.5
5.0
7.0
164
1SMB5925B
10
37.5
4.5
500
0.25
5.0
8.0
150
1SMB5926B
11
34.1
5.5
550
0.25
1.0
8.4
136
1SMB5927B
12
31.2
6.5
550
0.25
1.0
9.1
125
1SMB5928B
13
28.8
7.0
550
0.25
1.0
9.9
115
1SMB5929B
15
25.0
9.0
600
0.25
1.0
11.4
100
1SMB5930B
16
23.4
10
600
0.25
1.0
12.2
93
1SMB5931B
18
20.8
12
650
0.25
1.0
13.7
83
1SMB5932B
14
650
0.25
1.0
15.2
75
1SMB5933B
22
17.0
17.5
650
0.25
1.0
16.7
68
1SMB5934B
24
15.6
19
700
0.25
1.0
18.2
62
1SMB5935B
27
13.9
23
700
0.25
1.0
20.6
55
1SMB5936B
30
12.5
26
750
0.25
1.0
22.8
50
1SMB5937B
33
11.4
33
800
0.25
1.0
25.1
45
1SMB5938B
36
10.4
38
850
0.25
1.0
27.4
41
1SMB5939B
39
9.6
45
900
0.25
1.0
29.7
38
1SMB5940B
43
8.7
53
950
0.25
1.0
32.7
34
1SMB5941B
47
8.0
67
1000
0.25
1.0
35.8
31
1SMB5942B
51
7.3
70
1100
0.25
1.0
38.8
29
1SMB5943B
56
6.7
86
1300
0.25
1.0
42.6
26
1SMB5944B
62
6.0
100
1500
0.25
1.0
47.1
24
1SMB5945B
68
5.5
120
1700
0.25
1.0
51.7
22
1SMB5946B
75
5.0
140
2000
0.25
1.0
56.0
1SMB5947B
82
4.6
160
2500
0.25
1.0
62.2
18
1SMB5948B
91
4.1
200
3000
0.25
1.0
69.2
16
1SMB5949B
100
3.7
250
3100
0.25
1.0
76.0
15
1SMB5950B
110
3.4
300
4000
0.25
1.0
83.6
13
1SMB5951B
120
3.1
380
4500
0.25
1.0
91.2
12
1SMB5952B
130
2.9
450
5000
0.25
1.0
98.8
11
1SMB5953B
150
2.5
600
6000
0.25
1.0
114.0
10
1SMB5954B
160
2.3
700
6500
0.25
1.0
121.6
9.0
1SMB5955B
180
2.1
900
7000
0.25
1.0
136.8
8.0
1SMB5956B
200
1.9
1200
8000
0.25
1.0
152.0
7.0
Note :
( 1 ) Suffix " B " indicates ± 5% tolerance, suffix " A " indicates ± 10% tolerance.
ht t p : //
www.lgesemi .c o m
1SMB5913B-1SMB5957B
RATING AND CHARACTERISTIC CURVES( 1SMB5913B - 1SMB5956B )
PD, STEADY STATE DISSIPATION
(WATTS)
5
4
3
TB
2
1
TA
75
100
125
150
FIG. 3 - MAXIMUM SURGE POWER
PPK, PEAK SURGE POWER (WATTS)
FIG. 1 - POWER TEMPERATURE DERATING CURVE
1000
RECTANGULAR
NONREPETITIVE
WAVEFORM
TJ = 25 °C PRIOR
TO INITIAL PULSE
100
10
0.1
1
T, LEAD TEMPERATURE (°C)
FIG. 5 - TEMPERATURE COEFFICIENT RANGES
ӨVZ, TEMPERATURE
COEFFICENT (mV/°C) @ IZT
VZ @ IZT
6
4
2
2
3
4
5
6
7
8
9
10
11
12
ӨVZ, TEMPERATURE COEFFICENT
(mV/°C) @ IZT
UNITS 10 TO 400 VOLTS
10
-4
1000
VZ @ IZT
100
10
10
VZ, ZENER VOLTAGE @ IZT (VOLTS)
IZ, ZENER CURRENT (mA)
100
10
1
1
2
3
4
5
6
7
8
9
VZ, ZENER VOLTAGE (VOLTS)
ht t p : //
1000
FIG. 8 - ZENER VOLTAGE VS. ZENER CURRENT
VZ = 12 thru 82 VOLTS
100
FIG. 7 - ZENER VOLTAGE VS. ZENER CURRENT
VZ = 3.3 thru 10 VOLTS
0.1
100
FIG. 6 - TEMPERATURE COEFFICIENT RANGES
UNITS TO 12 VOLTS
8
10
PW, PULS WIDTH (ms)
10
10
1
0.1
40
50
60
70
80
90
100
www.lgesemi .c o m
很抱歉,暂时无法提供与“1SMB5942B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.71695
- 50+0.58865
- 150+0.52450
- 500+0.47638
- 3000+0.39619
- 6000+0.37695
