SS56B70
SS56B70
    JUXING(钜兴)
    DO-214AA(SMB)
SS56B70 数据手册
SS52 THRU SS5200 Surface Mount Schottky Rectifiers Features ● Low profile package ● Ideal for automated placement ● Fast switching for high efficiency ● High forward surge capability ● High temperature soldering: SMB(DO-214AA) 260℃/10 seconds at terminals ● 0.155(3.94) 0.130(3.30) Component in accordance to RoHS 2002/95/1 and WEEE 2002/96/EC 0.086(2.2) 0.075(1.91) 0.187(4.76) 0.160(4.06) Mechanical Date ● 0.012(0.305) 0.006(0.152) Case: JEDEC DO-214AA molded plastic body ● 0.096(2.44) 0.083(2.13) Terminals: Solder plated, solderable per J-STD-002B and JESD22-B102D ● 0.008(0.203) MAX 0.060(1.52) 0.030(0.76) 0.220(5.59) 0.200(5.08) Polarity: Laser band denotes cathode end Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics o Rating at 25 C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20% Maximum Recurrent Peak Reverse Voltage VRRM SS 52 20 Maximum RMS Voltage VRMS 14 Maximum DC Blocking Voltage VDC 20 Average Rectified Output Current @TL =100℃ IF(AV) 5.0 A Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM 150 A Forward Voltage VFM Type Number SYMBOL @IF=5.0A (Note 1) Peak Reverse Current @TA =25 ℃ At Rated DC Blocking Voltage @TA =100 ℃ 2 IR 2 SS 54 40 SS 545 45 SS 56 60 SS 58 80 SS 510 100 SS 5150 150 28 31 42 56 70 105 140 V 40 45 60 80 100 150 200 V 0.55 0.7 0.85 SS Unit 5200 200 V 0.95 0.1 0.05 10 5 V mA I t Rating for fusing (t
SS56B70 价格&库存
很抱歉,暂时无法提供与“SS56B70”相匹配的价格&库存,您可以联系我们找货
SS56B70
    • 5+0.35151
    • 50+0.34320
    • 150+0.33767
    • 500+0.33202
    库存:2820
