Z2E24B
Z2E24B
    AM(安美)
    DO-214AA(SMB)
Z2E24B 数据手册
Z2E6.8B SERIES 2W Surface Mount Zener Diodes ■Features • Low inductance. package has Underwriters Laboratory Flammability Classification 94V-0 . • High temperature soldering guaranteed 260°C /10 Seconds, • Plastic At terminals free in compliance with EU RoHS. • Lead ■ Mechanical data • Epoxy:UL94V-0 rated flame retardant • Case : Molded plastic, DO-214AA / SMB • Terminals : Solder plated, solderable per MIL-STD-750, Method 2026 • Polarity : Indicated by cathode band • Weight : 0.093 grams(approx) ■Maximum ratings and electrical characteristics Rating at 25 O C ambient temperature unless otherwise specified. Parameter Symbol Power Dissipa on at TL = 75°C (Note 1 ) Opera ng and Storage Temperature Range Value Units PD 2.0 W TJ,T STG -55 to +150 °C Note : 1.Mounted on 5.0 x 5.0mm (.013mm thick) and areas. Document Number:8080015 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~1~ Z2E6.8B SERIES ■Electrical characteristics Nominal Marking P/N Code Zener Voltage VZ @ IZT Max. Zener Max. Reverse Impedance Leakage Current VZT @ IZT IZT VZK @ IZK IZK IR @ VR Min. V Nom. V Max. V (Ω) (mA) (Ω) (mA) (μA) (V) Z2E6.8B 2006 6.46 6.8 7.14 2 73.5 700 1 5 4 Z2E7.5B 2007 7.13 7.5 7.88 2 66.5 700 0.5 5 5 Z2E8.2B 2008 7.79 8.2 8.61 2 61 700 0.5 5 6 Z2E8.7B 20A8 8.27 8.7 9.14 2 58 700 0.5 4 6.6 Z2E9.1B 2009 8.65 9.1 9.56 3 55 700 0.5 3 7 Z2E10B 2010 9.5 10 10.5 4 50 700 0.25 3 7.6 Z2E11B 2011 10.45 11 11.55 4 45.5 700 0.25 1 8.4 Z2E12B 2012 11.4 12 12.6 5 41.5 700 0.25 1 9.1 Z2E13B 2013 12.35 13 13.65 5 38.5 700 0.25 0.5 9.9 Z2E14B 2014 13.3 14 14.7 6 35.7 700 0.25 0.5 10.6 Z2E15B 2015 14.25 15 15.75 7 33.4 700 0.25 0.5 11.4 Z2E16B 2016 15.2 16 16.8 8 31.2 700 0.25 0.5 12.2 Z2E17B 2017 16.15 17 17.85 9 29.4 750 0.25 0.5 13 Z2E18B 2018 17.1 18 18.9 10 27.8 750 0.25 0.5 13.7 Z2E19B 2019 18.05 19 19.95 11 26.3 750 0.25 0.5 14.4 Z2E20B 2020 19 20 21 11 25 750 0.25 0.5 15.2 Z2E22B 2022 20.9 22 23.1 12 22.8 750 0.25 0.5 16.7 Z2E24B 2024 22.8 24 25.2 13 20.8 750 0.25 0.5 18.2 Z2E25B 2025 23.75 25 26.25 14 20 750 0.25 0.5 19 Z2E27B 2027 26.65 27 28.35 18 18.5 750 0.25 0.5 20.6 Z2E28B 2028 26.6 28 29.4 18 17 750 0.25 0.5 21.3 Z2E30B 2030 28.5 30 31.5 20 16.6 1000 0.25 0.5 22.5 Z2E33B 2033 31.35 33 34.65 23 15.1 1000 0.25 0.5 25.1 Z2E36B 2036 34.2 36 37.8 25 13.9 1000 0.25 0.5 27.4 Z2E39B 2039 37.05 39 40.95 30 12.8 1000 0.25 0.5 29.7 Z2E43B 2043 40.85 43 45.45 35 11.6 1500 0.25 0.5 32.7 Z2E47B 2047 44.65 47 49.35 40 10.6 1500 0.25 0.5 35.8 Z2E51B 2051 48.45 51 53.55 48 9.8 1500 0.25 0.5 38.8 Document Number:8080015 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~2~ Z2E6.8B SERIES ■Rating and characteristic curves Fig. 1-TYPICAL THERMAL RESPONSE Fig. 3-TYPICAL REVERSE LEAKAGE 80 RESISTANCE ( C/W ) θVZ, JUNCTION-LEAD THERMAL Fig. 8-TYPICAL THERMAL RESISTANCE 70 60 50 40 30 PRIMARY PATH OF 20 10 0 CONDUCTION IS THROUGH THE CATHODE LEAD 0 1/8 1/4 3/8 1/2 5/8 3/4 Fig. 4-UNITS TO 12 VOLTS Document Number:8080015 Revision:21-Apr-28 7/8 1 Fig. 5-UNITS 10 TO 50 VOLTS An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~3~ Z2E6.8B SERIES ■ Ordering Information (Example) PREFERED PACKAGE CODE Z2E Series SMB MINIMUM PACKAGE(pcs) INNER BOX QUANTITY(pcs) 3000 OUTER CARTON QUANTITY(pcs) 6000 48000 DELIVERY MODE 13” reel ■ Outline Dimensions DO-214AA(SMB) .085 (2.15) .073 (1.85) .154(3 .90) .130(3 .30) M ounting P ad Layout 0.106 (2.69) .187(4.75) .161(4.10) 0.082 (2.10) .091(2.30) .083(2.10) 0.081(2.072) .056(1.41) .030(0.76) .008(0.20) .0 (0.00) .220(5.60) .200(5.10) Document Number:8080015 Revision:21-Apr-28 .012(0.31) .006(0.15) 0 .220 (5.58) D im ensions in inches and (m illim eters) An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~4~ Z2E6.8B SERIES IMPORTANT NOTICE AND DISCLAIMER AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN PURCHASE OR USE. AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no warranties, representation or guarantee, whether express, implied or statutory, including, without limitation, regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM. AM does not assume any liability or compensation for any application assistance or customer product design, and make no warranty or accept any liability with products, which are purchased or used for any unintended or unauthorized application. Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or lifesustaining applications or for any other application in which the failure of the AM product could result in personal injury or death. Customers using or selling AM products not expressly indicated for use in such applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and conditions regarding products designed for such applications. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of AM. Product names and markings noted herein may be trademarks of their respective owners. Document Number:8080015 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~5~
Z2E24B 价格&库存
很抱歉,暂时无法提供与“Z2E24B”相匹配的价格&库存,您可以联系我们找货
Z2E24B
    • 10+0.39464
    • 100+0.31688
    • 300+0.27800
    • 3000+0.24884
    • 6000+0.22551
    • 9000+0.21384
    库存:2671
