MBRS140T3G
Rectifiers- 40V
Symbol
Value
Unit
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
Rating
VRRM
VRWM
VR
40
V
Average Rectified Forward Current
TL = 115°C
IF(AV)
Non−Repetitive Peak Surge Current
(Surge Applied at Rated Load Conditions Halfwave, Single Phase, 60 Hz)
IFSM
Operating Junction Temperature
TJ
1.0
50
−65 to +150
A
A
°C
Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality
should not be assumed, damage may occur and reliability may be affected.
THERMAL CHARACTERISTICS
Characteristic
Thermal Resistance − Junction−to−Lead
(TL = 25°C)
Symbol
RqJL
Value
12
Unit
°C/W
ELECTRICAL CHARACTERISTICS
Characteristic
Symbol
Maximum Instantaneous Forward Voltage (Note 1)
(iF = 1.0 A, TJ = 25°C)
VF
Maximum Instantaneous Reverse Current (Note 1)
(Rated dc Voltage, TJ = 25°C)
(Rated dc Voltage, TJ = 100°C)
iR
Value
0.55
1.0
10
Unit
V
mA
Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product
performance may not be indicated by the Electrical Characteristics if operated under different conditions.
1. Pulse Test: Pulse Width = 300 ms, Duty Cycle ≤ 2.0%.
MBRS140T3G
Rectifiers- 40V
MBRS140T3G
Rectifiers- 40V
MBRS140T3G
B14
B14
MBRS140T3G
Rectifiers- 40V
很抱歉,暂时无法提供与“MBRS140T3G-F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.29541
- 100+0.24011
- 300+0.21246
- 3000+0.17350
- 6000+0.15691
- 12000+0.14861
