SS56
SS56
    NH(纽航)
    DO-214AA(SMB)
SS56 数据手册
Niu Hang Electronic Co. Ltd Specification For Approval SS54 THRU SS520 SCHOTTKY BARRIER RECTIFIERS 40~200 VOLTAGE: Volts CURRENT: 5.0 Amperes Marking and Polarity DO-214AA(SMB) FEATURES · · · Low Forward Voltage Drop for high efficiency FFYWW Low leakage current for high reliability High forward surge capability for high reliability SS5xx MECHANICAL DATA · · · · Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Mounting Position: Any Remark: Lead Free: Lead Free Finish, RoHS Compliant ①. NH=niuhang trademark Weight:App. 0.095 grams(0.0034 ounce) ②. FF=Product line,According to actual changes; YWW=Periodic code,According to actual changes; TYPICAL APPLICATIONS · For use in high frequency inverters , ③. SS5xx=Modle,xxx=4,45,6,8,10,15,20 DC/DC converters,LED driver etc. applications ④. White band denotes cathode Maximum Ratings(Ratings at 25℃ ambient temperature unless otherwise specified ) Symbol Parameter SS54 SS545 SS56 SS58 SS510 SS515 SS520 Unit Maximum repetitive peak reverse voltage V RRM 40 45 60 80 100 150 200 V Maximum RMS voltage V RMS 28 32 42 56 70 105 140 V Maximum DC blocking voltage V DC 40 45 60 80 100 150 200 V Maximum average forward rectified current(see fig.1) IF (AV) 5.0 A Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC method at rated TL) I FSM 120 A I2t 59.76 A sec Current Squared Time Per Diode(t
很抱歉,暂时无法提供与“SS56”相匹配的价格&库存,您可以联系我们找货
SS56
    • 10+0.37034
    • 100+0.30305
    • 300+0.26936
    库存:1065
