SS1045B THRU SS10200B
10.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
VOLTAGE RANGE
45 to 200 Volts
CURRENT
10.0Ampere
DO-214AA(SMB)
MECHANICAL DATA
.155(3.94)
.130(3.30)
.083(2.11)
.075(1.91)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.093 grams
.185(4.70)
.160(4.06)
.012(0.31)
.006(0.15)
.096(2.44)
.083(2.13)
.008
MAX.
(.203)
.220(5.59)
.200(5.08)
.050(1.27)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SS1045B
45
32
45
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SS1060B
60
42
60
See Fig. 1
Peak Forward Surge Current, 8.3 ms single half sine-wave
SS10100B SS10150B SS10200B UNITS
200
100
150
V
70
105
140
V
100
150
200
V
A
10.0
175
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 10.0A
Maximum DC Reverse Current
Ta=25 C
0.55
0.7
0.02
0.70
0.85
2
0.1
0.70
0.85
5
at Rated DC Blocking Voltage
Ta=125 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JA (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
0.92
0.85
400
250
55
to10+150
-55
-55 to +150
A
V
A
mA
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.4x0.4”(10x10mm) copper pad areas
www.slkormicro.com
1
Rev.1 -- 21 May 2016
RATING AND CHARACTERISTIC CURVES (SS1045B THRU SS10200B)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
50
4
2
60
80
100
120
140
160
180
200
CASE TEMPERATURE,( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
10
5.0
SS
101
50SS
102
00
6
SS
106
SS
101
00
8
SS
10
45
10
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
12
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
250
.01
200
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
150
8.3ms Single Half
Tj=25 C
Sine Wave
100
JEDEC method
50
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
FIG.4-TYPICAL JUNCTION CAPACITANCE
REVERSE LEAKAGE CURRENT, (mA)
JUNCTION CAPACITANCE,(pF)
2800
2400
2000
1600
1200
800
400
Tj=100 C
1.0
Tj=75 C
.1
Tj=25 C
.01
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
www.slkormicro.com
2
很抱歉,暂时无法提供与“SS10100B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.57748
- 50+0.46775
- 150+0.41289
- 500+0.37174
