Z2E6.8B SERIES
2W Surface Mount Zener Diodes
■Features
• Low
inductance.
package has Underwriters
Laboratory Flammability Classification 94V-0 .
• High temperature soldering guaranteed 260°C /10 Seconds,
• Plastic
At terminals
free in compliance with EU RoHS.
• Lead
■ Mechanical data
• Epoxy:UL94V-0 rated flame retardant
• Case : Molded plastic, DO-214AA / SMB
• Terminals : Solder plated, solderable per
MIL-STD-750, Method 2026
• Polarity : Indicated by cathode band
• Weight : 0.093 grams(approx)
■Maximum ratings and electrical characteristics
Rating at 25 O C ambient temperature unless otherwise specified.
Parameter
Symbol
Power Dissipa on at TL = 75°C (Note 1 )
Opera ng and Storage Temperature Range
Value
Units
PD
2.0
W
TJ,T STG
-55 to +150
°C
Note : 1.Mounted on 5.0 x 5.0mm (.013mm thick) and areas.
Document Number:8080015
Revision:21-Apr-28
An hui Anmei Semiconductor Co.,Ltd.
www.amsemi.com.cn
~1~
Z2E6.8B SERIES
■Electrical characteristics
Nominal
Marking
P/N
Code
Zener Voltage
VZ @ IZT
Max. Zener
Max. Reverse
Impedance
Leakage Current
VZT @ IZT
IZT
VZK @ IZK
IZK
IR @ VR
Min. V
Nom. V
Max. V
(Ω)
(mA)
(Ω)
(mA)
(μA)
(V)
Z2E6.8B
2006
6.46
6.8
7.14
2
73.5
700
1
5
4
Z2E7.5B
2007
7.13
7.5
7.88
2
66.5
700
0.5
5
5
Z2E8.2B
2008
7.79
8.2
8.61
2
61
700
0.5
5
6
Z2E8.7B
20A8
8.27
8.7
9.14
2
58
700
0.5
4
6.6
Z2E9.1B
2009
8.65
9.1
9.56
3
55
700
0.5
3
7
Z2E10B
2010
9.5
10
10.5
4
50
700
0.25
3
7.6
Z2E11B
2011
10.45
11
11.55
4
45.5
700
0.25
1
8.4
Z2E12B
2012
11.4
12
12.6
5
41.5
700
0.25
1
9.1
Z2E13B
2013
12.35
13
13.65
5
38.5
700
0.25
0.5
9.9
Z2E14B
2014
13.3
14
14.7
6
35.7
700
0.25
0.5
10.6
Z2E15B
2015
14.25
15
15.75
7
33.4
700
0.25
0.5
11.4
Z2E16B
2016
15.2
16
16.8
8
31.2
700
0.25
0.5
12.2
Z2E17B
2017
16.15
17
17.85
9
29.4
750
0.25
0.5
13
Z2E18B
2018
17.1
18
18.9
10
27.8
750
0.25
0.5
13.7
Z2E19B
2019
18.05
19
19.95
11
26.3
750
0.25
0.5
14.4
Z2E20B
2020
19
11
25
750
0.25
0.5
15.2
Z2E22B
2022
20.9
22
23.1
12
22.8
750
0.25
0.5
16.7
Z2E24B
2024
22.8
24
25.2
13
20.8
750
0.25
0.5
18.2
Z2E25B
2025
23.75
25
26.25
14
0.25
0.5
19
Z2E27B
2027
26.65
27
28.35
18
18.5
750
0.25
0.5
20.6
Z2E28B
2028
26.6
28
29.4
18
17
750
0.25
0.5
21.3
Z2E30B
2030
28.5
30
31.5
1000
0.25
0.5
22.5
Z2E33B
2033
31.35
33
34.65
23
15.1
1000
0.25
0.5
25.1
Z2E36B
2036
34.2
36
37.8
25
13.9
1000
0.25
0.5
27.4
Z2E39B
2039
37.05
39
40.95
30
12.8
1000
0.25
0.5
29.7
Z2E43B
2043
40.85
43
45.45
35
11.6
1500
0.25
0.5
32.7
Z2E47B
2047
44.65
47
49.35
40
10.6
1500
0.25
0.5
35.8
Z2E51B
2051
48.45
51
53.55
48
9.8
1500
0.25
0.5
38.8
Revision:21-Apr-28
www.amsemi.com.cn
~2~
Z2E6.8B SERIES
■Rating and characteristic curves
Fig. 1-TYPICAL THERMAL RESPONSE
Fig. 3-TYPICAL REVERSE LEAKAGE
80
RESISTANCE ( C/W )
θVZ, JUNCTION-LEAD THERMAL
Fig. 8-TYPICAL THERMAL RESISTANCE
70
60
50
40
30
PRIMARY PATH OF
CONDUCTION IS THROUGH
THE CATHODE LEAD
1/4
3/8
1/2
5/8
3/4
Fig. 4-UNITS TO 12 VOLTS
Revision:21-Apr-28
7/8
1
Fig. 5-UNITS 10 TO 50 VOLTS
www.amsemi.com.cn
~3~
Z2E6.8B SERIES
■ Ordering Information (Example)
PREFERED
PACKAGE CODE
Z2E Series
SMB
MINIMUM
PACKAGE(pcs)
INNER BOX
QUANTITY(pcs)
3000
OUTER CARTON
QUANTITY(pcs)
6000
48000
DELIVERY MODE
13” reel
■ Outline Dimensions
DO-214AA(SMB)
.085 (2.15)
.073 (1.85)
.154(3 .90)
.130(3 .30)
M ounting P ad Layout
0.106
(2.69)
.187(4.75)
.161(4.10)
0.082
(2.10)
.091(2.30)
.083(2.10)
0.081(2.072)
.056(1.41)
.030(0.76)
.008(0.20)
.0 (0.00)
.220(5.60)
.200(5.10)
Revision:21-Apr-28
.012(0.31)
.006(0.15)
0 .220
(5.58)
D im ensions in inches and (m illim eters)
www.amsemi.com.cn
~4~
Z2E6.8B SERIES
IMPORTANT NOTICE AND DISCLAIMER
AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA
WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD
OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN
PURCHASE OR USE.
AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or
in any other disclosure relating to any product.
All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application
requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no
warranties, representation or guarantee, whether express, implied or statutory, including, without limitation,
regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM.
AM does not assume any liability or compensation for any application assistance or customer product design,
and make no warranty or accept any liability with products, which are purchased or used for any unintended
or unauthorized application.
Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or
lifesustaining applications or for any other application in which the failure of the AM product could result in
personal injury or death. Customers using or selling AM products not expressly indicated for use in such
applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and
conditions regarding products designed for such applications.
No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this
document or by any conduct of AM. Product names and markings noted herein may be trademarks of their
respective owners.
Revision:21-Apr-28
www.amsemi.com.cn
~5~
很抱歉,暂时无法提供与“Z2E16B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40922
- 100+0.33146
- 300+0.29258
