� �D�
宏迦橙
SS32B THRU SS320B
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
www.ichjc.com
Features
DO-214AA(SMB)
•Low profile package
•Ideal for automated placement
•Guardring for overvoltage protection
•Low power losses, high efficiency
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
For use in low voltage high frequency inverters, freewheeling,DC/DC converters,
and polarity protection applications.
Mechanical Data
•Case: DO-214AA(SMB)
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL UNIT SS32B SS33B SS34B SS35B SS36B SS38B SS310B SS315B SS320B
Device marking code
Maximum Repetitive Peak Reverse Voltage
VRRM
V
Maximum DC blocking Voltage
VDC
V
Maximum RMS Voltage
Maximum Average Forward Rectified Current
@60Hz sinewave, Resistance load,TL (Fig.1)
Non-repetitive Peak Forward Surge Current
@ t=8.3ms Half-sine wave
Storage temperature
Junction temperature
VRMS
V
A
Tstg
RθJ-A
℃ /W
IFSM
A
30
40
50
60
80
100
150
200
40
50
60
80
100
150
200
21
28
35
42
3.0
80
-55 ~ +125
RθJ-L
IF(AV)
Tj
Typical Thermal Resistance
-55 ~ +150
Maximum instantaneous
forward voltage
Revision:SBD-May.2023-A0
105
140
-55 ~ +150
℃ /W
17
TEST CONDITIONS SYMBOL UNIT SS32B SS33B SS34B SS35B SS36B SS38B SS310B SS315B SS320B
IF=3.0A
Maximum DC reverse currentat
VRM=VRRM
rated DC blocking voltage
Typical junction capacitance
70
55
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
56
Ta=25℃
Ta=100℃
4.0V DC,1MHz
VF
V
IR
mA
CJ
pF
0.55
500
1 of 3
0.2
10
Zhuhai Hongjiacheng Technology co., Ltd
0.70
0.85
300
0.05
0.95
5
www.ichjc.com
� �D�
宏迦橙
SS32B THRU SS320B
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
5.0
140
AVERAGERECTIFIELDOUTPUTCURRENT(A)
SS32B-SS34B
SS35B-SS320B
120
PEAKFORWARDSURGECURRENT(A)
4.0
100
3.0
80
60
2.0
40
1.0
80
LEADTEMPERATURE(℃)
120
Fig. 1 Forward Current Derating Curve
100
100
Tj=25℃
Pulsewidth=300us
1%DutyCycle
10
100
NUMBEROFCYCLES
SS32B-SS36B
SS38B-SS320B
10
INSTANTANEOUSREVERSECURRENT(mA)
INSTANTANEOUSFORWARDCURRENT(A)
1
Fig.2 Maximum Non-Repetitive Peak Forward Surge Current
10
1.0
Tj=100℃
1
0.1
0.1
0.01
8.3msSingleHalfSineWave
(JEDECMethod)
0.4
0.6
0.8
1.0
SS32B-SS34B
SS35B-SS36B
SS38B-SS310B
SS315B-SS320B
1.2
INSTANTANEOUSFORWARDVOLTAGE(V)
1.4
0.01
0.001
1.6
Fig.3 Typical Forward Voltage
Tj=25℃
60
80
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
100
Fig.4 Typical Reverse Characteristics
2 of 3
www.ichjc.com
� �D�
宏迦橙
SS32B THRU SS320B
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SMB
R3
0.098
3000
6000
48000
13''
Package Outline Dimensions (SMB/DO-214AA)
Symbol
A C
A
B
B
C
H
D
E
D
E
F
F
G
G
H
Suggested Pad Layout
J
K
J
Symbol
M
M
J
K
3 of 3
Dimensions
Millimeters
Min.
Max.
4.25
4.85
1.85
3.30
2.15
0.75
0.073
0.087
3.94
0.130
0.155
2.65
1.52
0.203
0.15
0.31
5.59
Min.
Max.
2.10
0.167
0.191
0.085
0.104
0.030
0.060
0.008
0.200
0.220
0.006
Dimensions
Millimeters
2.26
Max.
2.21
5.08
Min.
Inches
Min.
0.089
2.74
0.085
0.012
Inches
Max.
0.107
www.ichjc.com
很抱歉,暂时无法提供与“SS320B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40295
- 100+0.32433
- 300+0.28502
- 3000+0.25553
- 6000+0.23199
- 9000+0.22022
