� �D�
宏迦橙
SS22B THRU SS2200B
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
www.ichjc.com
Features
DO-214AA(SMB)
•Low profile package
•Ideal for automated placement
•Guardring for overvoltage protection
•Low power losses, high efficiency
•Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃
Applications
For use in low voltage high frequency inverters, free wheeling,DC/DC converters,
and polarity protection applications.
Mechanical Data
•Case: DO-214AA(SMB)
Molding compound meets UL 94V-0 flammability rating, RoHS-compliant,
halogen-free
•Terminals: Solder plated, solderable per MIL-STD-750,Method 2026
•Polarity: Cathode line denotes the cathode end
Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL UNIT
Device marking code
Maximum Repetitive Peak Reverse Voltage
VRRM
V
Maximum DC blocking Voltage
VDC
V
Maximum RMS Voltage
Maximum Average Forward Rectified Current
@60Hz sinewave, Resistance load,TL (Fig.1)
Non-repetitive Peak Forward Surge Current
@ t=8.3ms Half-sine wave
Storage temperature
Junction temperature
VRMS
IF(AV)
A
Tstg
RθJ-A
℃ /W
IFSM
Tj
Typical Thermal Resistance
V
RθJ-L
SS22B SS24B SS245B SS26B SS28B SS210B SS215B SS220B
SS22B
SS24B SS245B SS26B
40
28
45
60
45
60
31.5
40
A
Maximum instantaneous
forward voltage
Maximum DC reverse
currentat rated DC
blocking voltage
VRM=VDC
Typical junction
capacitance
Revision:SBD-May.2023-A0
Ta=25℃
Ta=100℃
4.0V DC,1MHz
V
IR
mA
CJ
pF
SS220B
56
70
105
140
80
80
2.0
100
150
100
-55 ~ +125
-55 ~ +150
150
200
200
17
SS24B SS245B SS26B
0.55
220
1 of 3
0.2
10
Zhuhai Hongjiacheng Technology co., Ltd
-55 ~ +150
60
℃ /W
VF
SS215B
50
TEST CONDITIONS SYMBOL UNIT SS22B
IF=2.0A
SS210B
42
Electrical Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
SS28B
0.70
SS28B SS210B SS2150BSS2200B
0.85
0.02
180
0.95
5.0
www.ichjc.com
� �D�
宏迦橙
SS22B THRU SS2200B
www.ichjc.com
Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified)
2.5
70
AVERAGERECTIFIELDOUTPUTCURRENT(A)
SS22B-SS26B
SS28B-SS220B
60
PEAKFORWARDSURGECURRENT(A)
2.0
50
1.5
40
30
1.0
80
LEADTEMPERATURE(℃)
120
Fig. 1 Forward Current Derating Curve
100
100
Tj=25℃
Pulsewidth=300us
1%DutyCycle
10
100
NUMBEROFCYCLES
SS22B-SS26B
SS28B-SS220B
10
INSTANTANEOUSREVERSECURRENT(mA)
INSTANTANEOUSFORWARDCURRENT(A)
1
Fig.2 Maximum Non-Repetitive Peak Forward Surge Current
10
1.0
Tj=100℃
1
0.1
0.1
0.01
8.3msSingleHalfSineWave
(JEDECMethod)
0.4
0.6
0.8
1.0
0.01
SS22B-SS24B
SS26B
SS28B-SS210B
SS215B-SS220B
1.2
INSTANTANEOUSFORWARDVOLTAGE(V)
1.4
0.001
1.6
Fig.3 Typical Forward Voltage
Tj=25℃
60
80
PERCENTOFRATEDPEAKREVERSEVOLTAGE(%)
100
Fig.4 Typical Reverse Characteristics
2 of 3
www.ichjc.com
� �D�
宏迦橙
SS22B THRU SS2200B
www.ichjc.com
Ordering Information
PACKAGE
PACKAGE CODE
UNIT WEIGHT(g)
REEL(pcs)
BOX(pcs)
CARTON(pcs)
DELIVERY MODE
SMB
R3
0.098
3000
6000
48000
13''
Package Outline Dimensions (SMB/DO-214AA)
Symbol
A C
A
B
B
C
H
D
E
D
E
F
F
G
G
H
Suggested Pad Layout
J
K
J
Symbol
M
M
J
K
3 of 3
Dimensions
Millimeters
Min.
Max.
4.25
4.85
1.85
3.30
2.15
0.75
0.073
0.087
3.94
0.130
0.155
2.65
1.52
0.203
0.15
0.31
5.59
Min.
Max.
2.10
0.167
0.191
0.085
0.104
0.030
0.060
0.008
0.200
0.220
0.006
Dimensions
Millimeters
2.26
Max.
2.21
5.08
Min.
Inches
Min.
0.089
2.74
0.085
0.012
Inches
Max.
0.107
www.ichjc.com
很抱歉,暂时无法提供与“SS210B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.19710
- 200+0.15855
- 600+0.13716
- 3000+0.12442
- 9000+0.11330
- 21000+0.10725
