SS24B
SS24B
    HONGJIACHENG(宏嘉诚)
    DO-214AA(SMB)
SS24B 数据手册
� �D� 宏迦橙 SS22B THRU SS2200B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Features DO-214AA(SMB) •Low profile package •Ideal for automated placement •Guardring for overvoltage protection •Low power losses, high efficiency •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications For use in low voltage high frequency inverters, free wheeling,DC/DC converters, and polarity protection applications. Mechanical Data •Case: DO-214AA(SMB) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Device marking code Maximum Repetitive Peak Reverse Voltage VRRM V Maximum DC blocking Voltage VDC V Maximum RMS Voltage Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave Storage temperature Junction temperature VRMS IF(AV) A Tstg ℃ RθJ-A ℃ /W IFSM Tj Typical Thermal Resistance V RθJ-L SS22B SS24B SS245B SS26B SS28B SS210B SS215B SS220B SS22B 20 14 20 SS24B SS245B SS26B 40 28 45 60 45 60 31.5 40 A Maximum instantaneous forward voltage ℃ Maximum DC reverse currentat rated DC blocking voltage VRM=VDC Typical junction capacitance Revision:SBD-May.2023-A0 Ta=25℃ Ta=100℃ 4.0V DC,1MHz V IR mA CJ pF SS220B 56 70 105 140 80 80 2.0 100 150 100 -55 ~ +125 -55 ~ +150 150 200 200 17 SS24B SS245B SS26B 0.55 220 1 of 3 0.2 10 Zhuhai Hongjiacheng Technology co., Ltd -55 ~ +150 60 ℃ /W VF SS215B 50 TEST CONDITIONS SYMBOL UNIT SS22B IF=2.0A SS210B 42 Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER SS28B 0.70 SS28B SS210B SS2150BSS2200B 0.85 0.02 180 0.95 5.0 www.ichjc.com � �D� 宏迦橙 SS22B THRU SS2200B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 2.5 70 AVERAGERECTIFIELDOUTPUTCURRENT(A) SS22B-SS26B SS28B-SS220B 60 PEAKFORWARDSURGECURRENT(A) 2.0 50 1.5 40 30 1.0 20 0.5 0 10 0 40 80 LEADTEMPERATURE(℃) 120 0 160 Fig. 1 Forward Current Derating Curve 100 100 Tj=25℃ Pulsewidth=300us 1%DutyCycle 10 100 NUMBEROFCYCLES SS22B-SS26B SS28B-SS220B 10 INSTANTANEOUSREVERSECURRENT(mA)  INSTANTANEOUSFORWARDCURRENT(A) 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 10 1.0 Tj=100℃ 1 0.1 0.1 0.01 8.3msSingleHalfSineWave (JEDECMethod) 0 0.2 0.4 0.6 0.8 1.0 0.01 SS22B-SS24B SS26B SS28B-SS210B SS215B-SS220B 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) 1.4 0.001 1.6 Fig.3 Typical Forward Voltage Revision:SBD-May.2023-A0 Tj=25℃ 0 20 40 60 80 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 100 Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SS22B THRU SS2200B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMB R3 0.098 3000 6000 48000 13'' Package Outline Dimensions (SMB/DO-214AA) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:SBD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 4.25 4.85 1.85 3.30 2.15 0.75 0.073 0.087 3.94 0.130 0.155 2.65 1.52 0.203 0.15 0.31 5.59 Min. Max. 2.10 - - Zhuhai Hongjiacheng Technology co., Ltd 0.167 0.191 0.085 0.104 0.030 0.060 - 0.008 0.200 0.220 0.006 Dimensions Millimeters 2.26 Max. 2.21 - 5.08 Min. Inches Min. - 0.089 2.74 - 0.085 0.012 Inches Max. - 0.107 www.ichjc.com
SS24B 价格&库存
很抱歉,暂时无法提供与“SS24B”相匹配的价格&库存,您可以联系我们找货
SS24B
    • 5+0.15423
    • 50+0.12118
    • 150+0.10282
    • 500+0.09180
    • 3000+0.08230
    • 6000+0.07712
    库存:542
