Niu Hang
Electronic Co. Ltd
Specification
For Approval
TL58B
SUPER LOW VF SCHOTTKY RECTIFIERS
80
VOLTAGE:
Volts
5.0
CURRENT:
Amperes
SMB(DO-214AA)
Marking and Polarity
FEATURES
Super Low Forward Voltage Drop for high efficiency
Low leakage current for high reliability
FFYWW
High forward surge capability for high reliability
H
MECHANICAL DATA
TL58B
Terminals: Plated Leads Solderable per MIL-STD-202, Method 208
Mounting Position: Any
Lead Free: Lead Free Finish, RoHS Compliant
Weight:App. 0.095 grams(0.0034 ounce)
Remark:
TYPICAL APPLICATIONS
①.
TL58B=Modle
For use in high frequency inverters ,
②.
NH=niuhang trademark
DC/DC converters,LED driver etc. applications
③.
FF=Product line,According to actual changes;
④.
White band denotes cathode
YWW=Periodic code,According to actual changes;
Maximum Ratings (Ratings at 25℃ ambient temperature unless otherwise specified.)
Parameter
Symbol
TL58B
Unit
Maximum repetitive peak reverse voltage
VRRM
80
V
Maximum RMS voltage
VRMS
56
V
Maximum DC blocking voltage
VDC
80
V
Maximum average forward rectified current(see fig.1)
IF(AV)
5.0
A
Peak forward surge current 8.3ms single half sine-wave
superimposed on rated load (JEDEC method at rated TL)(see fig.5)
IFSM
120
A
Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified).
TL58B
Parameter
Symbol
Test Conditions
Maximum instantaneous forward voltage
(see fig.2) (Note 1)
Maximum instantaneous reversecurrent at
rated DC blockingvoltage (see fig.3)(Note 1)
TA=25℃
IF= 5.0
A
Typ.
Max.
0.58
0.65
0.50
0.55
uA
1.0
mA
370
pF
VF
TA=125℃
TA=25℃
Unit
Min.
VR= VRRM
V
IR
TA=125℃
VR= 80%*VRRM
4V,1MHz
Typical junction capacitance(see fig.4)
CJ
Thermal Characteristcs (Ratings at 25℃ ambient temperature unless otherwise specified )
Symbol
Parameter
Operating junction
Storage temperature range
Typical thermal resistance (Note 2)
TL58B
Unit
TJ
-55
to
150
TSTG
-55
to
150
RθJA
25
RθJL
8
℃/W
Note: 1.Pulse width < 300 uS, Duty cycle < 2%
2.Mounted on P.C.B. with 0.3" x 0.3" (7.62 mm x 7.62 mm) copper pad areas
Http://www.nh-semicon.com
Data:2014/10/20
Rev.:A/1
Page: 1 of 5
Niu Hang
Electronic Co. Ltd
Specification
For Approval
TL58B
RATINGANDCHARACTERISTICCURVES
10
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
6
5
4
3
2
1
50
75
100
125
200
300
400
25℃
500
600
700
125℃
Tc, Case Temp (℃)
FORWORD VOLTAGE,(mV)
Fig.1- FORWARD CURRENT DERATING CURVE
Fig.2-TYPICAL INSTANTANEOUS FORWARD
10000
JUNCTION CAPACITANCE,(pF)
10000
1000
100
10
1
0.1
1000
100
10
0.01
60
80
100
1
25℃
0.1
125℃
1
10
100
PERCENT OF RATED PEAK REVERSE VOLTAGE%
REVERSE VOLTAGE,(V)
Fig.3-TYPICAL REVERSE CHARACTERISTICS
Fig.4- TYPICAL JUNCTION CAPACITANCE
120
TJ=TJMAX.
8.3ms SINGLE HALF
SINE-WAVE
JEDEC Method
80
40
10
100
TRANSIENT THERMAL IMPEDANCE, ℃/ W
INSTANTANEOUS REVERSE CURRENT (uA)
0.1
100
150
100000
PEAK FORWARD SURGE CURRENT (A)
1
100
10
1
0.1
0.01
0.1
1
10
100
NUMBER OF CYCLES AT 60HZ
TP,PULSE DURATION ,(sec.)
Fig.5-MAX. NON-REPETITIVE SURGE CURRENT
FIG.6-TYPICAL TRANSIENT THERMAL IMPEDANCE
Data:2014/10/20
Rev.:A/1
Page: 2 of 5
Niu Hang
Electronic Co. Ltd
Specification
For Approval
TL58B
OUTLINE DRAWINGS
SMB(DO-214AA)
OUTLINE DIMENSIONS
Milimeters
Inches
Dim.
RECOMMEDNED LAYOUT DRAWINGS
Min.
Typ.
Max.
Min.
Typ.
Max.
A
4.060
4.700
0.15984
0.18504
B
5.080
5.590
0.2
0.22008
C
3.300
3.940
0.12992
0.15512
D
2.130
2.440
0.08386
0.09606
E
1.910
2.110
0.0752
0.08307
F
0.910
1.500
0.03583
0.05906
G
0.051
0.203
0.00201
0.00799
H
0.152
0.305
0.00598
0.01201
SMB(DO-214AA)
RECOMMEDNED MOUNTING PAD DIMENSIONS
Milimeters
Inches
Dim.
PACKING INFORMATION
Min.
Typ.
Max.
Min.
Typ.
Max.
A
6.340
0.24961
B
2.720
0.10709
C
1.760
0.06929
D
2.290
0.09016
SMB(DO-214AA)
Package
Method
Reel Size
(mm)
Quantity
(pcs/reel)
Inner Box Size
L×W×H(mm)
Quantity
(pcs/Inner Box)
Carton Size
L×W×H(mm)
Quantity
(pcs/carton)
Tape Reel
Φ330
3000
340×340×45
6000
360×360×470
60000
Data:2014/10/20
Rev.:A/1
Page: 3 of 5
Niu Hang
Electronic Co. Ltd
Specification
For Approval
TL58B
Recommended wave soldering condition
Product
Peak Temperature
Soldering Time
Pb-free devices
260 +0/-5 °C
5 +1/-1 seconds
Profile feature
Sn-Pb eutectic Assembly
Pb-free Assembly
Average ramp-up rate
(Tsmax to Tp)
3°C/second max.
3°C/second max.
Preheat
−Temperature Min(TS min)
−Temperature Max(TS max)
−Time(ts min to ts max)
100°C
150°C
60-120 seconds
150°C
200°C
60-180 seconds
Time maintained above:
−Temperature (TL)
− Time (tL)
183°C
60-150 seconds
217°C
60-150 seconds
Peak Temperature(TP)
240 +0/-5 °C
260 +0/-5 °C
Time within 5°C of actual peak
temperature(tp)
10-30 seconds
20-40 seconds
Ramp down rate
6°C/second max.
6°C/second max.
Time 25 °C to peak temperature
6 minutes max.
8 minutes max.
Recommended temperature profile for IR reflow
Note : All temperatures refer to topside of the package, measured on the package body surface.
Data:2014/10/20
Rev.:A/1
Page: 4 of 5
Niu Hang
Electronic Co. Ltd
Specification
For Approval
TL58B
Disclaimer
Reproducing and modifying informatiom of the document is prohibited without permission
from niuhang Electronics co., LTD
Niuhang Electronics co., LTD. reserves the rights to make changes of the content herein
the document anytime without notification.
Niuhang Electronics co., LTD. disclaims any and all liability arising out of the application or
use of any product including damages incidentally and consequentially occurred.
Niuhang Electronics co., LTD. does not assume any and all implied warranties,
including warranties of fitness for particular purpose,non-infringement and merchantability.
Applications shown on the herein document are examples of standard use and operation.
Customers are responsible in comprehending the suitable use in particular applications.
Niuhang Electronics co., LTD.makes no representation or warranty that such applications will
be suitable for the specified use without further testing or modification.
The products shown herein are not designed and authorized for equipments requiring high
level of reliability or relating to human life and for any applications concerning life-saving or
life-sustaining,such as medical instruments.transportation equipment,aerospae machinery
et cetera.Customers usin or selling these products for use in such applications do so at their
own rish and agree to fully indemnify Niuhang Electronics co., LTD.for any damages resulting
resulting from such improper use or sale.
When the appearance of the product and chip size does not change, in order to product
the customer.
quality, change the internal structure and the production process Niuhang can not notify
Data:2014/10/20
Rev.:A/1
Page: 5 of 5
很抱歉,暂时无法提供与“TL58B”相匹配的价格&库存,您可以联系我们找货
