ES3K
ES3K
    LJ(朗捷)
    DO-214AA(SMB)
ES3K 数据手册
SURFACE MOUNT SUPER FAST RECTIFIER VOLTAGE RANGE ES3AB THRU ES3KB 50 to 800 Volts CURRENT 3.0 Ampere Features  Glass passivated chip:84mil  Plastic package has underwrites laboratory flammability  Classification 94V-0  For surface mounted applications  Low profile package  Built-in strain relief, ideal for automated placement  Glass Passivated chip junction  High temperature soldering:250℃/10 second at terminals Mechanical Data  Case: JEDED DO-214AA molded plastic over glass passivated chip  Terminals: Solder plated, Solderable per MIL-STD-750, method 2026  Polarity: Color band denotes cathode end  Weight: 0.003ounce, 0.093 gram Maximum Ratings and Electrical Characteristics  Ratings at 25℃ ambient temperature unless otherwise specified.  Single phase, half wave, 60Hz, resistive or inductive load.  For capacitive load derate current by 20%. SYMBO LS ES 3AB ES 3BB ES 3CB ES 3DB ES 3EB ES 3GB ES 3JB ES 3KB UNIT Maximum Repetitive Peak Reverse Voltage VRRM 50 100 150 200 300 400 600 800 Volts Maximum RMS Voltage VRMS 35 70 105 140 210 280 420 560 Volts Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 800 Volts Maximum Average Forward Rectified Current At TA=100℃ I(AV) 3.0 Amps Peak Forward Surge Current 8.3ms single half sine wave superimposed on rated load (JEDEC Method) IFSM 80 Amps Maximum Instantaneous Forward Voltage at 3.0A VF TYPE NUMBER Maximum DC Reverse Current at rated DC blocking voltage at TA = 25℃ TA = 125℃ TRR Typical Junction Capacitance CJ Typical Thermal Resistance (NOTE 1) Operating Junction Temperature Storage Temperature Range 1.25 1.70 5.0 IR Maximuml Reverse Recovery Time (NOTE 3) (NOTE 2) 0.95 µA 100 nS 35 60 Volts 45 pF RθJA 75 RθJL 30 TJ -55 to +150 ℃ TSTG -55 to +150 ℃ ℃/W Notes: 1. Thermal resistance from Junction to ambient and from junction to lead mounted on P.C.B.with0.3×0.3″(8.0 × 8.0mm) copper pad areas. 2. Measured at 1.0MHz and applied reverse voltage of 4.0V 3. Test conditions IF =0.5A, IR =1.0A, IRR =0.25A Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SUPER FAST RECTIFIER VOLTAGE RANGE ES3AB THRU ES3KB 50 to 800 Volts CURRENT 3.0 Ampere Ratings and Characteristic Curves (T =25℃ unless otherwise noted) A FIG.2-MAXIMUM NON-REPETITIVE PEAK FIG.1-TYPICAL FORWARD CURRENT AVERAGE FORWARD CURRENT, (A) 3.0 2.5 2.0 1.5 Single Phase Half Wave 60Hz Inductive or Resistive Load 1.0 0.375″(9.5mm) Lead Length 0.5 0 0 25 100 75 50 125 175 150 FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT, (A) DERATING CURVE AMBIENT TEMPERATURE, (°C) 105 90 8.3ms Single Half Sine-Wave (JEDEC Method) T j = Tjmax 75 60 45 30 15 0 1 Cycle 1 2 4 6 8 10 40 20 60 100 NUMBER OF CYCLES AT 60 Hz FIG.3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG.4-TYPICAL REVERSE CHARACTERISTICS ES TJ =25°C Pulse Width=300us 0.1 1% Duty Cycle 0.01 10 1.0 (μA) INSTANTANEOUS REVERSE CURRENT, 3J -E S3 K 3E ES ES 3A- 3D -3 G 1.0 (A) INSTANTANEOUS FORWARD CURRENT, 10 TJ =125°C 0.1 TJ =25℃ 0.01 0.001 0.4 0.6 0.8 1.0 1.2 1.6 1.4 0 20 1.8 40 60 100 80 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) INSTANTANEOUS FORWARD VOLTAGE,(V) FIG.5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 100 F1G.6-TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC TRR 50Ω 10Ω NONINDUCTIVE NONINDUCTIVE +0.5A (-) 10 (+) 25 Vdc (approx.) (-) T J =25°C f=1MHz Vsig=50mVp-p ES3A-ES3D ES3E-ES3K 1.0 10 REVERSE VOLTAGE,(V) Sep-03, Rev A 1Ω NON INDUCTIVE PULSE GENERATIOR (NOTE 2) OSCILLOSCOPE (NOTE 1) 0 -0.25A (+) -1.0A 1cm SET TIME BASE FOR 50/100ns/cm 1 0.1 D.U.T. 100 NOTES : 1.Rise Time=7ns max. Input Impedance= 1 megohm. 22pF 2.Rise time=10ns max. Source Impedance= 50 ohms CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SUPER FAST RECTIFIER VOLTAGE RANGE ES3AB THRU ES3KB Package Outline Dimensions Sep-03, Rev A CURRENT 50 to 800 Volts 3.0 Ampere in inches (millimeters) CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SUPER FAST RECTIFIER VOLTAGE RANGE ES3AB THRU ES3KB 50 to 800 Volts CURRENT 3.0 Ampere Package Reel Information Specifications Ao Bo Ko Po W t1 SMB 3.77±0.10 5.70±0.10 2.67±0.10 4.00±0.1 12.0±0.05 0.23±0.02 13"Reel Tape DEVICE TYPE Width Q'TY/REEL(pcs BOX/CARTOO Q'TY/CARTON Q'TY/REEL(pcs ) N (pcs) ) SMB Sep-03, Rev A 12mm 3000 8 48000 NA 07"Reel REEL/BOX NA BOX/CARTOO Q'TY/CARTON N (pcs) NA NA CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SUPER FAST RECTIFIER VOLTAGE RANGE ES3AB THRU ES3KB CURRENT 50 to 800 Volts 3.0 Ampere Reflow Profile Reflow Condition Pre Heat Temperature Min. +150°C Temperature Max. +200°C Time(Min to Max) 60-180 secs. Average ramp up rate(Liquidus Temp(TL) to peak) 3°C/sec. Max. TS(max) to TL - Ramp-up Rate 3°C/sec. Max. Reflow Sep-03, Rev A Pb-Free Assembly Temperature (TL)(Liquidus) +217°C Temperature (TL) 60-150 secs. Peak Temp (TP) +(260+0/-5 )°C Time within 5°C of actual Peak Temp (TP) 25 secs. Ramp-down Rate 6°C/sec. Max. Time 25°C to peak Temp (TP) 8 min. Max. Do not exceed +260°C CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SUPER FAST RECTIFIER ES3AB THRU ES3KB VOLTAGE RANGE CURRENT 50 to 800 Volts 3.0 Ampere Disclaimer The information presented in this document is for reference only. Chongqing changjie Electronic Technology Co., Ltd. reserves the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or design or otherwise. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Changjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such improper use of sale. This publication supersedes & replaces all information previously supplied. For additional information, please visit our website http:// www.czlangjie.com , or consult your nearest Langjie’s sales office for further assistance. Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
很抱歉,暂时无法提供与“ES3K”相匹配的价格&库存,您可以联系我们找货
ES3K
    • 10+0.36800
    • 100+0.29724
    • 300+0.26186
    • 3000+0.23533
    • 6000+0.21414
    • 9000+0.20344
    库存:2749
