RS3MB
RS3MB
    LJ(朗捷)
    DO-214AA(SMB)
RS3MB 数据手册
SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE RS3AB THRU RS3MB 50 to 1000 Volts CURRENT 3.0 Ampere Features       Plastic package has underwrites laboratory flammability Classification 94V-0 Low profile surface mount package Built-in strain relief Fast switching for high efficiency Glass passivated chip junction High temperature soldering 250℃/10 second at terminals Mechanical Data     Case: JEDED DO-214AA molded plastic over glass passivated chip Terminals: Solder plated, Solderable per MIL-STD-750, method 2026 Polarity: Laser band denote cathode band Weight: 0.003ounce, 0.093 gram Maximum Ratings and Electrical Characteristics  Ratings at 25℃ambient temperature unless otherwise specified  Single Phase, half wave, 60Hz, resistive or inductive load  For capacitive load derate current by 20% SYMBOL S RS 3AB RS 3BB RS 3DB RS 3GB RS 3JB RS 3KB RS 3MB UNITS Maximum Repetitive Peak Reverse Voltage VRRM 50 100 200 400 600 800 1000 Volts Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 Volts Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 Volts Maximum Average Forward Rectified Current at TL =100℃ I(AV) 3.0 Amp Peak Forward Surge Current 8.3mS single half sine wave superimposed on rated load (JEDEC method) IFSM 80 Amps Maximum Instantaneous Forward Voltage @ 3.0A VF 1.30 Volts TYPE NUMBER Maximum DC Reverse Current at Rated DC Blocking Voltage TA = 25℃ TA = 125℃ Typical Reverse Recovery Time (Note 3) Typical Junction Capacitance (Note 1) Typical Thermal Resistance (Note 2) Operating Junction Temperature Range Storage Temperature Range 5.0 IR µA 50 TRR 150 CJ 20 250 500 17 nS pF RθJA 55 RθJL 18 TJ -55 to +150 ℃ TSTG -55 to +150 ℃ ℃/W Notes: 1. Measured at 1.0MHz and applied reverse voltage of 4.0 Volts. 2. Thermal resistance from Junction to ambient and from junction to lead mounted on PCB. with 0.3×0.3″(8.0 × 8.0mm) copper pad areas. 3. Reverse Recovery Test Conditions:If=0.5mA,Ir=1.0mA,Irr=0.25A. Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE RS3AB THRU RS3MB 50 to 1000 Volts CURRENT 3.0 Ampere Ratings and Characteristic Curves (T =25℃ unless otherwise noted) A FIG.1-TYPICAL FORWARD CURRENT FIG.2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 90 2.5 2.0 1.5 1.0 0.071×0.071"(1.8×1.8mm) Copper Pads 0.5 80 70 CURRENT, (A) PEAK FORWARD SURGE 3.0 (A) AVERAGE FORWARD CURRENT, DERATING CURVE 8.3ms Single Half Sine-Wave (JEDEC Method) Tj = Tjmax 60 50 40 30 20 10 0 0 25 50 100 75 175 150 125 0 1 Cycle 1 2 AMBIENT TEMPERATURE, (°C) 4 6 8 10 40 20 60 100 NUMBER OF CYCLES AT 60 Hz FIG.3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS FIG.4-TYPICAL REVERSE CHARACTERISTICS 0.1 0.01 TJ =25°C Pulse Width=300us 1% Duty Cycle 100 10 (μA) INSTANTANEOUS REVERSE CURRENT, 1.0 (A) INSTANTANEOUS FORWARD CURRENT, 10 TJ =125°C 1.0 TJ =25℃ 0.1 0.001 0.4 0 0.6 0.8 1.0 1.2 1.4 1.6 20 1.8 40 60 100 80 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) INSTANTANEOUS FORWARD VOLTAGE,(V) FIG.5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 100 F1G.6-TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC Trr 50Ω 10Ω NONINDUCTIVE NONINDUCTIVE +0.5A (-) 10 (+) 25 Vdc (approx.) (-) T J =25°C f=1MHz Vsig=50mVp-p 1 0.1 1.0 10 REVERSE VOLTAGE,(V) Sep-03, Rev A 100 D.U.T. 1Ω NON INDUCTIVE PULSE GENERATIOR (NOTE 2) OSCILLOSCOPE (NOTE 1) 0 -0.25A (+) -1.0A NOTES : 1.Rise Time=7ns max. Input Impedance= 1 magohm. 22pF 2.Rise time=10ns max. Source Impedance= 50 ohms 1cm SET TIME BASE FOR 50/100ns/cm CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE RS3AB THRU RS3MB 50 to 1000 Volts CURRENT Package Outline Dimensions 3.0 Ampere in inches (millimeters) Package Reel Information Specifications Ao Bo Ko Po W t1 SMB 3.77±0.10 5.70±0.10 2.67±0.10 4.00±0.1 12.0±0.05 0.23±0.02 Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE RS3AB THRU RS3MB DEVICE TYPE SMB CURRENT 13"Reel Tape Width Q'TY/REEL(pcs BOX/CARTOO Q'TY/CARTON Q'TY/REEL(pcs ) N (pcs) ) 12mm 3000 50 to 1000 Volts 8 48000 NA 3.0 Ampere 07"Reel REEL/BOX NA BOX/CARTOO Q'TY/CARTON N (pcs) NA NA Marking code Sep-03, Rev A Type number Marking code RS3AB RS3A RS3BB RS3B RS3DB RS3D RS3GB RS3G RS3JB RS3J RS3KB RS3K RS3MB RS3M CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER VOLTAGE RANGE RS3AB THRU RS3MB CURRENT 50 to 1000 Volts 3.0 Ampere Reflow Profile Reflow Condition Pre Heat Temperature Min. +150°C Temperature Max. +200°C Time(Min to Max) 60-180 secs. Average ramp up rate(Liquidus Temp(TL) to peak) 3°C/sec. Max. TS(max) to TL - Ramp-up Rate 3°C/sec. Max. Reflow Sep-03, Rev A Pb-Free Assembly Temperature (TL)(Liquidus) +217°C Temperature (TL) 60-150 secs. Peak Temp (TP) +(260+0/-5 )°C Time within 5°C of actual Peak Temp (TP) 25 secs. Ramp-down Rate 6°C/sec. Max. Time 25°C to peak Temp (TP) 8 min. Max. Do not exceed +260°C CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT FAST SWITCHING RECTIFIER RS3AB THRU RS3MB VOLTAGE RANGE CURRENT 50 to 1000 Volts 3.0 Ampere Disclaimer The information presented in this document is for reference only. Chongqing changjie Electronic Technology Co., Ltd. reserves the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or design or otherwise. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Changjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such improper use of sale. This publication supersedes & replaces all information previously supplied. For additional information, please visit our website http:// www.czlangjie.com , or consult your nearest Langjie’s sales office for further assistance. Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
RS3MB 价格&库存
很抱歉,暂时无法提供与“RS3MB”相匹配的价格&库存,您可以联系我们找货
RS3MB
    • 20+0.20655
    • 200+0.16408
    • 600+0.14056
    • 3000+0.12636
    • 9000+0.11412
    • 21000+0.10751
    库存:497
