SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
VOLTAGE RANGE
SS32L THRU SS3150L
20 to 150 Volts
CURRENT
3.0 Ampere
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed: 260 C/10 seconds at terminals
Mechanical Data
Case: Transfer molded plastic
Epoxy: UL 94V-0 rate flame retardant
Lead :Solder plated, solderable per MIL-STD-750 method 2026
Polarity: Color band denotes cathode end
Weight: 0.003ounce, 0.093 gram
Maximum Ratings and Electrical Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load
For capacitive load derate current by 20%
SYMBOL
S
SS
32L
SS
34L
SS
35L
SS
36L
SS
38L
SS
310L
SS
3150L
UNIT
Maximum Repetitive Peak Reverse Voltage
VRRM
50
60
80
100
150
Volts
Maximum RMS Voltage
VRMS
14
28
35
42
56
70
105
Volts
Maximum DC Blocking Voltage
VDC
50
60
80
100
150
Volts
TYPE NUMBER
Maximum Average Forward Rectified Current at TLsee figure 1 TL
=100℃
Peak Forward Surge Current 8.3ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage @ 3.0A(Note1)
Maximum DC Reverse Current at rated DC Blocking
Voltage per element
Typical Thermal Resistance (Note 2)
Diode junction capacitance (Note 3)
Operating and Storage Temperature Range
I(AV)
3.0
Amps
IFSM
80
Amps
VF
TA = 25℃
TA = 125℃
IR
0.45
0.55
0.70
0.78
0.5
0.3
Volts
mA
RθJA
50
RθJL
15
CJ
200
pF
TJ,TSTG
-55 to +150
℃/W
Notes:
1.
Pulse test:300μs pulse width,1% duty cycle.
2.
Thermal resistance from Junction to ambient and from junction to lead mounted on PCB. with 0.3×0.3″(8.0 × 8.0mm)copper
pad areas.
3.
f=1MHz and applied 4V DC reverse voltage.
Sep-03, Rev A
CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
VOLTAGE RANGE
SS32L THRU SS3150L
20 to 150 Volts
CURRENT
3.0 Ampere
Ratings and Characteristic Curves (T =25℃ unless otherwise noted)
3.0
2.5
2.0
1.5
S ingle P hase H alf W ave 60H z
1.0
Inductive or R esistive Load
0.5
0.3× 0.3″(8.0 × 8.0m m ) Lead Length
50
60
70
80
90
100
110
120
130
140
150
160
F 1G .2-M A X IM U M N O N -R E P E T IT IV E P E A K
FORW ARD SURGE CURRENT
100
T L = 100℃
8.3m s S ingle H alf S ine-W ave
(JE D E C M ethod)
90
80
70
AMPERES
3.5
AMPERES
AVERAGE FORWARD CURRENT
F 1G .1 -F O R W A R D C U R R E N T
D E R A T IN G C U R V E
PEAK FORWARD SURGE CURRENT,
A
60
50
40
30
F 1G .3 -T Y P IC A L IN S T A N T A N E O U S
F O R W A R D C H A R A C T E R IS T IC S
0.1
S S 32L-S S 34L
S S 35L-S S 36L
S S 38L-S S 3150L
0.4
0.6
0.8
1.0
1.2
1.4
IN S T A N T A N E O U S F O R W A R D V O L T A G E , V O LT S
100
T J = 100℃
10
MICROAMPERES
INSTANTANEOUS REVERSE CURRENT,
1.0
AMPERES
INSTANTANEOUS FORWARD CURRENT,
T J = 25℃
P ulse W idth= 300us
1% D uty C ycle
0.2
100
F 1G .4-T Y P IC A L R E V E R S E C H A R A C T E R IS T IC S
10
0.01
N U M B E R O F C Y C LE S A T 60 H z
L E A D T E M P E R A T U R E ,(℃ )
1.0
T J = 75℃
0.1
T J = 25℃
0.01
0.001
60
80
100
PERCENT OF RATED PEAK
R E V E R S E V O L T A G E ,(% )
F 1G .5 -T Y P IC A L JU N C T IO N C A P A C IT A N C E
JUNCTION CAPACITANCE,(pF)
1000
T J = 25℃
f= 1M H z
V sig= 50m V p-p
100
10
1.0
10
100
R E V R E S E V O LT A G E , V O LT S
Sep-03, Rev A
VOLTAGE RANGE
SS32L THRU SS3150L
Package Outline Dimensions
Sep-03, Rev A
CURRENT
20 to 150 Volts
3.0 Ampere
in inches (millimeters)
VOLTAGE RANGE
SS32L THRU SS3150L
20 to 150 Volts
CURRENT
3.0 Ampere
Package Reel Information
Specifications
Ao
Bo
Ko
Po
W
t1
SMB
3.77±0.10
5.70±0.10
2.67±0.10
4.00±0.1
12.0±0.05
0.23±0.02
13"Reel
DEVICE TYPE
Tape
Width
Q'TY/REEL(pcs)
SMB
12mm
3000
Sep-03, Rev A
07"Reel
BOX/CARTOON Q'TY/CARTON(pcs) Q'TY/REEL(pcs)
8
48000
NA
REEL/BOX
BOX/CARTOON
Q'TY/CARTON(pc
s)
NA
NA
NA
VOLTAGE RANGE
SS32L THRU SS3150L
CURRENT
20 to 150 Volts
3.0 Ampere
Reflow Profile
Reflow Condition
Pre Heat
Temperature Min.
+150°C
Temperature Max.
+200°C
Time(Min to Max)
60-180 secs.
Average ramp up rate(Liquidus Temp(TL) to peak)
3°C/sec. Max.
TS(max) to TL - Ramp-up Rate
3°C/sec. Max.
Reflow
Sep-03, Rev A
Pb-Free Assembly
Temperature (TL)(Liquidus)
+217°C
Temperature (TL)
60-150 secs.
Peak Temp (TP)
+(260+0/-5 )°C
Time within 5°C of actual Peak Temp (TP)
25 secs.
Ramp-down Rate
6°C/sec. Max.
Time 25°C to peak Temp (TP)
8 min. Max.
Do not exceed
+260°C
SS32L THRU SS3150L
VOLTAGE RANGE
CURRENT
20 to 150 Volts
3.0 Ampere
Disclaimer
The information presented in this document is for reference only. Chongqing changjie Electronic Technology Co., Ltd. reserves
the right to make changes without notice for the specification of the products displayed herein to improve reliability, function or
design or otherwise.
The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used
with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life
(such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and
other safety devices), Changjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such
improper use of sale.
This publication supersedes & replaces all information previously supplied. For additional information, please visit our website
http:// www.czlangjie.com , or consult your nearest Langjie’s sales office for further assistance.
Sep-03, Rev A
很抱歉,暂时无法提供与“SS36L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.44081
- 50+0.35605
- 150+0.31367
- 500+0.28188
- 3000+0.25642
- 6000+0.24368
