SS82 THRU SS810
SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 20 to 100 Volts
Forward Current - 8.0 Amperes
SMB
FEATURES
DO-214AA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Construction utilizes void-free
molded plastic technique
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
250 C,0.25”(6.35mm) from case for 10 seconds
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.071 (1.80)
0.183(4.65)
0.160(4.05)
MECHANICAL DATA
0.012(0.305)
0.006(0.152)
0.096(2.45)
0.081(2.05)
0.060(1.52)
0.008(0.203)MAX.
0.030(0.76)
Case: JEDEC DO-214AA molded plastic body
Terminals: leads solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.005 ounce, 0.138 grams
0.220(5.59)
0.205(5.21)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 8.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
VRRM
VRMS
VDC
Specifications are subject to change without notice.
21
30
40
28
40
50
35
50
60
42
60
80
56
80
90
63
90
100
70
100
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
8.0
Amps
IFSM
200
Amps
VF
IR
CJ
RqJC
TJ
TSTG
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
Please refer to http://www.ruilon.com.cn for current information.
SS82 SS83 SS84 SS85 SS86 SS88 SS89 SS810
0.55
0.70
0.85
Volts
0.1
5.0
mA
0.5
15.0
300
3.0
-65 to +125
-65 to +150
-65 to +150
pF
C/W
C
C
2.P.C.B. mounted with 0.4x0.4”(10x10mm) copper pad areas
Page:1
8
6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
4
SS82-SS84
SS85-SS810
2
50
75
100
125
150
175
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
£PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
10
200
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
160
120
80
40
10
AMBIENT TEMPERATURE, C
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
100
10
TJ=25 C
PULSE WIDTH=300 ms
1%DUTY CYCLE
1
0.1
SS82-SS84
SS85-SS86
SS88-SS810
0.2
0.4
0.6
0.8
1.0
1.1
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
CURRENT,AMPERES
50
0.01
10
TJ=100 C
1
TJ=75 C
0.1
0.01
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
100
1.0
10
40
60
80
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
TRANSIENT THERMAL IMPEDANCE,
C/W
TJ=25 C
0.1
PERCENT OF PEAK REVERSE VOLTAGE,%
2000
1000
TJ=25 C
0.001
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
10
100
NUMBER OF CYCLES AT 60 Hz
100
10
1
0.1
0.01
0.1
1
10
100
100
REVERSE VOLTAGE,VOLTS
t,PULSE DURATION,sec.
Page:2
很抱歉,暂时无法提供与“SS810B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.88226
- 50+0.70990
- 150+0.63603
- 500+0.54378
- 3000+0.50274
- 6000+0.47812
