ES2A-ES2K
2.0 AMPS. Surface Mount Super Fast Rectifiers
Features
SMB/DO-214AA
Glass passivated junction chip
For surface mounted application
Low profile package
Built-in strain relief
Ideal for automated placement
Easy pick and place
Superfast recovery time for high efficiency
Glass passivated chip junction
High temperature soldering:
O
260 C/10 seconds at terminals
Plastic material used carries Underwriters
Laboratory Classification 94V-0
0.180(4.57)
0.160(4.06)
0.086(2.20)
0.077(1.95)
0.155(3.94)
0.130(3.30)
0.209(5.30)
0.201(5.10)
0.012(0.30)
0.006(0.15)
Mechanical Data
0.096(2.44)
0.084(2.13)
Cases: Molded plastic
Terminals: Pure tin plated, lead free.
Polarity: Indicated by cathode band
Weight: 0.093 gram
0.059(1.50)
0.035(0.90)
Marking Information
XXXX
0.008(0.20)
0.002(0.05)
Dimensions in inches and(millimeters)
LGE:Lu Guang Electronic
XXXX:marking code (ES2A-ES2K)
Maximum Ratings and Electrical Characteristics
Rating at 25 O C ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol ES ES ES
Type Number
2A
2B
2C
Maximum Recurrent Peak Reverse
50 100 150
V RRM
Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified
Current See Fig. 1
Peak Forward Surge Current, 8.3 ms
Single Half Sine-wave Superimposed on
Rated Load (JEDEC method )
Maximum Instantaneous Forward Voltage
@ 2.0A
Maximum DC Reverse Current
o
@T A =25 C at Rated DC Blocking Voltage
o
@ T A =100 C
Maximum Reverse Recovery Time
( Note 1 )
Typical Junction Capacitance ( Note 2 )
Maximum Thermal Resistance (Note 3)
Operating Temperature Range
Notes:
ES
2G
400
ES
2J
600
ES
2K K
700
Units
V
35
70
105
140
210
280
420
490
V
V DC
50
100
150
200
300
400
600
700
V
I(AV)
2.0
A
IFSM
50
A
VF
0.95
1.3
1.7
V
IR
10
350
uA
uA
Trr
35
nS
Cj
R θJA
R θJL
25
-55 to +150
-55 to +150
T STG
1. Reverse Recovery Test Conditions: IF =0.5A, IR =1.0A, IRR =0.25A
2. Measured at 1 MHz and Applied V R =4.0 Volts
3. Units Mounted on P.C.B. 0.4” x 0.4” (10mm x 10mm) Pad Areas
ht t p : //
Revision:20170701-P1
ES
2E
300
V RMS
TJ
Storage Temperature Range
ES
2D
200
www.lgesemi .c o m
pF
o
C /W
o
o
C
C
mail:lge@lgesemi.com
ES2A-ES2K
RATINGS AND CHARACTERISTIC CURVES (ES2A THRU ES2K)
FIG.2- TYPICAL REVERSE CHARACTERISTICS
FIG.1- MAXIMUM FORWARD CURRENT DERATING
CURVE
1000
RESISTIVE OR
INDUCTIVE LOAD
0.4X0.4"(10X10mm)
COPPER PAD AREAS
INSTANTANEOUS REVERSE CURRENT. ( A)
AVERAGE FORWARD CURRENT. (A)
3.0
2.0
1.0
90
100
120
110
140
130
150
o
LEAD TEMPERATURE. ( C)
FIG.3- MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
Tj=125 0C
10
Tj=85 0C
1
Tj=25 0C
0.1
8.3ms Single Half Sine Wave
o
(JEDEC Method) at TL=120 C
50
0.01
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
40
30
10
FIG.5- TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
Tj=25 C
PULSE WIDTH-300 S
1% DUTY CYCLE
ES
30
ES
2F-
2A
-D
-D
-G
2F
-K
ES
1
ES
JUNCTION CAPACITANCE.(pF)
Tj=25 0C
f=1.0MHz
Vsig=50mVp-p
2A
FIG.4- TYPICAL JUNCTION CAPACITANCE
60
ES
NUMBER OF CYCLES AT 60Hz
50
10
INSTANTANEOUS FORWARD CURRENT. (A)
100
10
1
2H
PEAK FORWARD SURGE CURRENT. (A)
60
0.1
K
10
0.4
100
10
0.6
0.8
REVERSE VOLTAGE. (V)
1.0
1.2
1.4
1.6
1.8
FORWARD VOLTAGE. (V)
FIG.6- REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM
50W
NONINDUCTIVE
10W
NONINDUCTIVE
trr
+0.5A
DUT
50Vdc
(approx)
PULSE
GENERATOR
(NOTE 2)
1W
NON
INDUCTIVE
OSCILLOSCOPE
(NOTE 1)
NOTES: 1. Rise Time=7ns max. Input Impedance=
1 megohm 22pf
2. Rise Time=10ns max. Sourse Impedance=
50 ohms
-1.0A
1cm
SET TIME BASE FOR
5/ 10ns/ cm
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMB
3000/REEL
48000
36X35.8X36.5
12.00
11.00
ht t p : //
-0.25A
www.lgesemi .c o m
很抱歉,暂时无法提供与“ES2K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28081
- 100+0.22746
- 300+0.20079
- 3000+0.18079
- 6000+0.16478
- 9000+0.15678
