SMBJ5333B-SMBJ5388B
Surface Mount Silicon Zener Diodes
VZ : 3.3 - 200 Volts
PD : 5 Watts
Features
SMB/DO-214AA
Complete Voltage Range 3.3 to 200 Volts
High peak reverse power dissipation
High reliability
Low leakage current
Pb / RoHS Free
0.180(4.57)
0.160(4.06)
0.086(2.20)
0.077(1.95)
0.209(5.30)
0.201(5.10)
Mechanical Data
0.155(3.94)
0.130(3.30)
0.012(0.30)
0.006(0.15)
Case : SMB (DO-214AA) Molded plastic
Epoxy : UL94V-O rate flame retardant
Lead : Lead formed for Surface mount
Polarity : Color band denotes cathode end
Mounting position : Any
Weight : 0.093 gram
0.096(2.44)
0.084(2.13)
0.059(1.50)
0.035(0.90)
0.008(0.20)
0.002(0.05)
Dimensions in inches and(millimeters)
MAXIMUM RATINGS
Rating at 25 °C ambient temperature unless otherwise specified
Rating
Symbol
Value
Unit
Power Dissipation at T L = 25 °C
PD
5
W
Maximum Forward Voltage at I F = 1.0 A
VF
1.2
V
Thermal Resistance, Junction to Ambient (Note 1)
RӨJA
90
°C/W
Thermal Resistance, Junction to Lead (Note 1)
RӨJL
25
°C/W
TJ, TSTG
- 65 to + 150
°C
Operating and Storage Temperature Range
Note :
(1) When mounted on FR4 PC board (1 oz Cu) with recommended footprint.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SMBJ5333B-SMBJ5388B
ELECTRICAL CHARACTERISTICS
Microsemi
Part
Number
Regulator
Voltage
(VZ)
Test
Current
(IZT)
Maximum
Dynamic
Impedance
(ZZ)
(A&B Suffix)
TYPE
SMBJ5333B
SMBJ5334B
SMBJ5335B
SMBJ5336B
SMBJ5337B
SMBJ5338B
SMBJ5339B
SMBJ5340B
SMBJ5341B
SMBJ5342B
SMBJ5343B
SMBJ5344B
SMBJ5345B
SMBJ5346B
SMBJ5347B
SMBJ5348B
SMBJ5349B
SMBJ5350B
SMBJ5351B
SMBJ5352B
SMBJ5353B
SMBJ5354B
SMBJ5355B
SMBJ5356B
SMBJ5357B
SMBJ5358B
SMBJ5359B
SMBJ5360B
SMBJ5361B
SMBJ5362B
SMBJ5363B
SMBJ5364B
SMBJ5365B
SMBJ5366B
SMBJ5367B
SMBJ5368B
SMBJ5369B
SMBJ5370B
SMBJ5371B
SMBJ5372B
SMBJ5373B
SMBJ5374B
SMBJ5375B
SMBJ5376B
SMBJ5377B
SMBJ5378B
SMBJ5379B
SMBJ5380B
SMBJ5381B
SMBJ5382B
SMBJ5383B
SMBJ5384B
SMBJ5385B
SMBJ5386B
SMBJ5387B
SMBJ5388B
MARKING
333B
334B
335B
336B
337B
338B
339B
340B
341B
342B
343B
344B
345B
346B
347B
348B
349B
350B
351B
352B
353B
354B
355B
356B
357B
358B
359B
360B
361B
362B
363B
364B
365B
366B
367B
368B
369B
370B
371B
372B
373B
374B
375B
376B
377B
378B
379B
380B
381B
382B
383B
384B
385B
386B
387B
388B
(Rating at 25 °C ambient temperature unless otherwise specified)
Maximum
Reverse
Current
(IR)
@ VR
IR Test
Voltage
(VR)
(Non-Suffix
& A Suffix)
IR Test
Voltage
(VR)
Maximum
Regulator
Current
(IZM)
Maximum
Surge
Current
(IZSM)
(B,C,D Suffix)
Maximum
Dynamic
Knee
Impedance
Zzk @ 1.0 mA
(B,C,D
Suffix)
(A,B,C,D Suffix)
Maximum
Voltage
Regulation
(∆VZ)
(A,B,C,D
Suffix)
V
mAdc
OHMS
µA
V
V
mA
OHMS
AMPS
VOLTS
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.0
6.2
6.8
7.5
8.2
8.7
9.1
10
11
12
13
14
15
16
17
18
19
24
25
27
28
30
33
36
39
43
47
51
56
60
62
68
75
82
87
91
100
110
120
130
140
150
160
170
180
190
200
380
350
320
290
260
240
220
200
200
175
175
150
150
150
125
125
100
100
100
75
75
70
65
65
65
50
50
50
50
50
40
40
30
30
30
25
25
15
15
12
12
10
10
8.0
8.0
8.0
8.0
5.0
5.0
5.0
3.0
2.5
2.0
2.0
2.0
1.5
1.0
1.0
1.0
1.0
1.5
1.5
2.0
2.0
2.0
2.5
2.5
2.5
2.5
2.5
2.5
2.5
2.5
3.0
3.0
3.5
3.5
4.0
5.0
6.0
8.0
10
11
14
27
35
40
42
44
45
65
75
75
90
125
170
190
230
330
350
380
430
450
480
300
150
50
10
5.0
1.0
1.0
1.0
1.0
10
10
10
10
7.5
5.0
5.0
2.0
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
1.0
1.0
1.0
1.0
1.0
1.0
2.0
3.0
3.0
4.9
6.4
6.9
6.25
6.6
7.2
8.0
8.6
9.4
10.1
10.8
11.5
12.2
13
13.7
14.4
15.8
17.3
18
19.4
20.1
21.6
23.8
25.9
28.1
31
33.8
36.7
40.3
43
44.6
49
54
59
63
65.5
72
79.2
86.4
93.6
101
108
115
122
130
137
144
1.0
1.0
1.0
1.0
1.0
1.0
2.0
3.0
3.0
5.2
5.7
6.2
6.6
6.9
7.6
8.4
9.1
9.9
10.6
11.5
12.2
12.3
13.7
14.4
15.2
16.7
18.2
19
20.6
21.2
22.8
25.1
27.4
29.7
32.7
35.8
38.8
42.5
45.5
47.1
51.7
56
62.2
66
69.2
76
83.6
91.2
93.8
106
114
122
129
137
144
152
1440
1320
1220
1100
1010
930
865
790
765
700
630
580
545
520
475
430
395
265
340
315
295
280
264
250
237
216
198
190
176
170
158
144
132
122
110
100
93
86
79
76
70
63
58
54.5
52.5
47.5
43
39.5
36.6
34
31.5
29.4
28
26.4
25
23.6
400
500
500
500
450
400
400
300
200
200
200
200
200
150
125
125
125
100
75
75
75
75
75
75
75
75
100
110
120
130
140
150
160
170
190
210
230
280
350
400
500
620
720
760
760
800
1000
1150
1250
1500
1500
1660
1750
1750
1850
1850
17.6
16.4
15.3
14.4
13.4
12.7
12.4
11.5
10.7
10
9.5
9.2
8.6
8.0
7.5
7.0
6.7
6.3
6.0
5.8
5.5
5.3
5.1
4.7
4.4
4.3
4.1
3.9
3.7
3.5
3.3
3.1
2.8
2.7
2.5
2.3
2.2
2.1
2.0
1.9
1.8
1.7
1.6
1.5
1.4
1.3
1.2
1.2
1.1
1.1
1.0
1.0
0.9
0.9
0.85
0.80
0.54
0.49
0.44
0.39
0.25
0.19
0.10
0.15
0.15
0.20
0.20
0.22
0.22
0.25
0.25
0.25
0.25
0.25
0.30
0.35
0.40
0.40
0.40
0.45
0.55
0.55
0.60
0.60
0.60
0.63
0.65
0.65
0.70
0.80
0.90
1.00
1.20
1.35
1.50
1.60
1.80
2.00
2.20
2.30
2.50
2.50
2.50
2.50
3.00
3.00
3.00
4.00
5.00
5.00
Notes : (1) Suffix " B " indicates ± 5% tolerance, suffix " A " indicates ± 10% tolerance.
(2) The surge current (IZSM) is specified as the maximum peak of a non- recurrent half-sin wave of 8.3 ms duration.
(3) Voltage regulation (VZ) is the difference between the voltage measured at 10% and 50% of I ZM
ht t p : //
www.lgesemi .c o m
SMBJ5333B-SMBJ5388B
RATING AND CHARACTERISTIC CURVES ( SMBJ5333B - SMBJ5388B )
Fig. 1 POWER DERATING CURVE
PD, MAXIMUM DISSIPATION
(WATTS)
5.0
4.0
3.0
2.0
1.0
50
75
100
125
150
TL, LEAD TEMPERATURE (°C)
Ir, PEAK SURGE CURRENT (AMPS)
Fig.2 Maximum Non-Repetitive Surg Current
versus Nominal Zener Voltage
40
PW=1 ms*
PW=8.3 ms*
4
2
1
PW=100 ms*
0.4
PW=1000 ms*
0.2
*SQURE WAVE
0.1
3
4
6 8 10
40
80
100
200
NORMINAL Vz (V)
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMB
3000/REEL
48000
36X35.8X36.5
12.00
11.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“SMBJ5346B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.82448
- 50+0.80579
- 150+0.79337
- 500+0.78084
