山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 60 to 100V
Forward Current - 10A
SS1060B THRU SS10100B
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverter,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: S1060 ~ S10100
Simplified outline SMB and symbol
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.1g / 0.0034oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Parameter
Symbols
SS1060B
SS10100B
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
100
V
Maximum RMS voltage
V RMS
42
70
V
Maximum DC Blocking Voltage
V DC
60
100
V
Maximum Average Forward Rectified Current
I F(AV)
10
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
150
A
Max Instantaneous Forward Voltage @10 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Thermal Resistance
(1)
Operating Junction Temperature Range
Storage Temperature Range
VF
0.75
0.90
V
IR
0.5
50
mA
RθJA
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
(1)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2018.07
SMB-S-SS1060B~SS10100B-10A100V
Page 1 of 3
山东晶导微电子股份有限公司
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
12.0
10.0
8.0
6.0
4.0
2.0
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( mA)
Fig.1 Forward Current Derating Curve
1000
100
T J =25°C
1
Case Temperature (°C)
10
1
SS1060B
SS10100B
0.1
1.0
1.5
2.0
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
60
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
T J =100°C
10
Fig.4- Typical Transient Thermal Impedance
100
10
Instaneous Forward Voltage (V)
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
180
175
150
125
100
75
50
25
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
2018.07
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
Marking
Type number
2.2
(86)
2.4
(94)
SS 1060 B
S1060
SS 10100 B
S10100
2.8
(110)
2.4
(94)
Marking code
mm
Unit :
(mil)
2018.07
807128B8
Page 3 of 3
很抱歉,暂时无法提供与“SS1060B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68786
- 50+0.54530
- 150+0.47402
- 500+0.42056
- 3000+0.37779
