SS32B-SS320B
SCHOTTKY BARRIER DIODE
FEATURES
Small Surface Mount device
Low power loss, high efficiency
High forward surge current capability
For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
SMB
MECHANICAL DATA
Case: SMB(DO-214AA)
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.088 grams (approximate)
MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Parameter
Symbol SS32B SS33B SS34B SS35B SS36BSS38B SS310B SS315B SS320B Unit
Repetitive
peak
reverse VRRM
40
50
60
80
100
150
200
V
voltage
VR
40
50
60
80
100
150
200
DC Reverse Voltage
V
RMS Reverse Voltage
Non-Repetitive Peak Forward
Surge Current @ t = 8.3 ms
Mean rectifying current
VRMS
14
21
28
35
42
56
70
105
140
V
IFSM
70
A
IF
3.0
A
Thermal Resistance
RθJA
55
°C/W
Thermal Resistance
RθJL
17
°C/W
Junction Temperature
TJ
Storage Temperature
TSTG
-55 ~+125
-55 ~+150
°C
-55 ~+150
°C
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol SS32B SS33B SS34B SS35B SS36B SS38B SS310B SS315B SS320B
Forward voltage
VF
Reverse current TA=25°C
IR
Reverse current TA=100°C
IR
Junction capacitance
CJ
0.55
0.70
0.90
0.85
0.1
0.5
250
V
IF=3A
mA
V=VR
mA
5.0
10
Unit Conditions
160
pF
V=4V,f=1MHZ
Notes: Thermal resistance from junction to ambient and from junction to lead mounted on P.C.B. with 0.6" x 0.6" (16 mm
x16mm)copper pad areas
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
E-mail:hkt@heketai.com
1/4
SS32B-SS320B
Typical Characteristics
FIG.2: MAXIMUM NON-REPETITIVE FORWARD URGE CURRENT
IFSM(A)
IO(A)
FIG.1: FORWARD CURRENT DERATING CURVE
3.0
SS32B-SS34B
90
SS35B-SS320B
2.5
8.3ms Single Half Sine Wave
JEDEC Method
80
2.0
70
1.5
60
1.0
50
Resistive or Inductive Load
P.C.B. Mounted on 0.6"×0.6"
(16mm×16mm)Copper Pad Areas
0.5
25
100
75
1
150
TL(℃)
125
10
Number of Cycles
FIG.4:TYPICAL REVERSE CHARACTERISTICS
FIG.3: TYPICAL FORWARD CHARACTERISTICS
100
IR(mA)
IF(A)
2
TJ=25 ℃
Pulse width=300us
1% Duty Cycle
100
SS32B-SS36B
SS38B-SS320B
10
10
Tj=75℃
1.0
1.0
Tj=75℃
0.1
SS32B-SS34B
SS35B-SS36B
SS38B-SS310B
SS315B-SS320B
0.1
0.01
Tj=25℃
0.01
0.001
0.4
0.6
0.8
1.0
1.2
1.4
VF(V)
60
80
100
Voltage(%)
2/4
SS32B-SS320B
SMB Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
5.00
5.45
0.197
0.215
B
3.20
4.00
0.126
0.157
C
4.30
4.70
0.169
0.185
D
1.80
2.20
0.071
0.087
E
2.20
2.50
0.087
0.098
G
1.90
2.30
0.075
0.090
H
0.95
1.25
0.037
0.049
I
0.05
0.15
0.002
0.006
K
1.70
2.10
0.067
0.083
L
0.90
1.60
0.035
0.063
N
0.10
0.30
0.004
0.012
SMB Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
SS32B-SS320B
SMB Tape and Reel
SMB Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SMB
4.10
5.50
2.58
Ø1.50
1.75
5.50
4.00
8.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SMB Tape Leader and Trailer
SMB Reel
REEL OPTION
13’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø330
75.0
13.00
R165
R37.50
R6.50
12.40
17.60
±2
±1
±1
±1
±1
±1
±1
±1
SHENZHEN HOTTECH
ELECTRONICS
CO.,LTD
©GUANGDONG
HOTTECH
INDUSTRIAL
CO.,LTD
4/4
很抱歉,暂时无法提供与“SS310B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.22254
- 200+0.17863
- 600+0.15431
- 3000+0.13964
- 9000+0.12702
- 21000+0.12014
