SS310B
SS310B
    HONGJIACHENG(宏嘉诚)
    DO-214AA(SMB)
SS310B 数据手册
� �D� 宏迦橙 SS32B THRU SS320B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Features DO-214AA(SMB) •Low profile package •Ideal for automated placement •Guardring for overvoltage protection •Low power losses, high efficiency •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications For use in low voltage high frequency inverters, freewheeling,DC/DC converters, and polarity protection applications. Mechanical Data •Case: DO-214AA(SMB) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT SS32B SS33B SS34B SS35B SS36B SS38B SS310B SS315B SS320B Device marking code Maximum Repetitive Peak Reverse Voltage VRRM V Maximum DC blocking Voltage VDC V Maximum RMS Voltage Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave Storage temperature Junction temperature VRMS V A Tstg ℃ RθJ-A ℃ /W IFSM A 30 40 50 60 80 100 150 200 20 30 40 50 60 80 100 150 200 21 28 35 42 3.0 80 -55 ~ +125 ℃ RθJ-L 20 14 IF(AV) Tj Typical Thermal Resistance SS32B SS33B SS34B SS35B SS36B SS38B SS310B SS315B SS320B -55 ~ +150 Maximum instantaneous forward voltage Revision:SBD-May.2023-A0 105 140 -55 ~ +150 ℃ /W 17 TEST CONDITIONS SYMBOL UNIT SS32B SS33B SS34B SS35B SS36B SS38B SS310B SS315B SS320B IF=3.0A Maximum DC reverse currentat VRM=VRRM rated DC blocking voltage Typical junction capacitance 70 55 Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER 56 Ta=25℃ Ta=100℃ 4.0V DC,1MHz VF V IR mA CJ pF 0.55 500 1 of 3 0.2 10 Zhuhai Hongjiacheng Technology co., Ltd 0.70 0.85 300 0.05 0.95 5 www.ichjc.com � �D� 宏迦橙 SS32B THRU SS320B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 5.0 140 AVERAGERECTIFIELDOUTPUTCURRENT(A) SS32B-SS34B SS35B-SS320B 120 PEAKFORWARDSURGECURRENT(A) 4.0 100 3.0 80 60 2.0 40 1.0 0 20 0 40 80 LEADTEMPERATURE(℃) 120 0 160 Fig. 1 Forward Current Derating Curve 100 100 Tj=25℃ Pulsewidth=300us 1%DutyCycle 10 100 NUMBEROFCYCLES SS32B-SS36B SS38B-SS320B 10 INSTANTANEOUSREVERSECURRENT(mA)  INSTANTANEOUSFORWARDCURRENT(A) 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 10 1.0 Tj=100℃ 1 0.1 0.1 0.01 8.3msSingleHalfSineWave (JEDECMethod) 0 0.2 0.4 0.6 0.8 1.0 SS32B-SS34B SS35B-SS36B SS38B-SS310B SS315B-SS320B 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) 1.4 0.01 0.001 1.6 Fig.3 Typical Forward Voltage Revision:SBD-May.2023-A0 Tj=25℃ 0 20 40 60 80 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 100 Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SS32B THRU SS320B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMB R3 0.098 3000 6000 48000 13'' Package Outline Dimensions (SMB/DO-214AA) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:SBD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 4.25 4.85 1.85 3.30 2.15 0.75 0.073 0.087 3.94 0.130 0.155 2.65 1.52 0.203 0.15 0.31 5.59 Min. Max. 2.10 - - Zhuhai Hongjiacheng Technology co., Ltd 0.167 0.191 0.085 0.104 0.030 0.060 - 0.008 0.200 0.220 0.006 Dimensions Millimeters 2.26 Max. 2.21 - 5.08 Min. Inches Min. - 0.089 2.74 - 0.085 0.012 Inches Max. - 0.107 www.ichjc.com
SS310B 价格&库存
很抱歉,暂时无法提供与“SS310B”相匹配的价格&库存,您可以联系我们找货
SS310B
    • 10+0.25586
    • 100+0.20445
    • 300+0.17874
    • 3000+0.15941
    • 6000+0.14397
    • 9000+0.13630
    库存:1768
