ES5JB
ES5JB
    HONGJIACHENG(宏嘉诚)
    DO-214AA(SMB)
ES5JB 数据手册
� �D� 宏迦橙 ES5AB THRU ES5JB SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER www.ichjc.com Features DO-214AA(SMB) •For surface mounted applications •Low reverse leakage •Glass passivated pallet chip junction •Super fast reverse recovery time •Fast switching for high efficiency •High forward surge capability Applications For use in high frequency rectification and free wheeling application in switching mode converters and inverters for consumer, computer, automotive, and telecommunication. Mechanical Data •Case: DO-214AA(SMB) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT ES5AB ES5BB ES5CB ES5DB ES5EB ES5GB ES5JB Maximum RMS Voltage VRMS V 35 70 105 140 210 280 420 Maximum repetitive peak reverse voltage Maximum DC blocking Voltage VRRM VDC Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave Junction temperature Typical Thermal Resistance 50 V IF(AV) 100 50 A IFSM Storage temperature V 100 A 150 200 150 200 5.0 ℃ -55 ~+150 RθJ-A(1) ℃ /W 60 RθJ-L(1) 300 400 400 600 600 150 Tstg Tj 300 ℃ -55 ~+150 ℃ /W 20 Note : (1)Thermal resistance from junction to ambient and from junction tolead mounted on P.C.B.with 0.2"× 0.2"(5.0mm x5.0 mm) copper pad areas Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER TEST CONDITIONS Maxinum reverse recovery time IF=0.5A,IR=1.0A,Irr=0.25A Maximum instantaneous forward voltage Maximum DC reverse currentat rated DC blocking voltage Typical junction capacitance Revision:SFRD-May.2023-A0 IF=5.0A VRM=VRRM Ta=25℃ Ta=125℃ 4.0V DC,1MHz SYMBOL UNIT ES5AB ES5BB ES5CB ES5DB ES5EB ES5GB ES5JB VF V Trr ns IR μA CJ pF 1 of 3 Zhuhai Hongjiacheng Technology co., Ltd 1.0 35 1.3 1.7 2.0 200 75 www.ichjc.com � �D� 宏迦橙 ES5AB THRU ES5JB SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 210 8.0 7.0 PEAKFORWARDSURGECURRENT(A) AVERAGEFORWARDOUTPUTCURRENT(A) 180 6.0 150 5.0 120 4.0 90 3.0 60 2.0 30 1.0 0.0 0 20 40 60 80 100 LEADTEMPERATURE(℃) 120 140 0 160 Fig. 1 Forward Current Derating Curve 10 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current ��� Tj=25℃ Pulsewidth=300us 1%DutyCycle �� 1 Tj=125℃ �.� 0.1 0.01 0.2 100 10 NUMBEROFCYCLES INSTANTANEOUSREVERSECURRENT(μA) 20  INSTANTANEOUSFORWARDCURRENT(A) 8.3msSingleHalfSineWave (JEDECMethod) Tj=25℃ �.� 0.6 1.0 1.4 ES5AB-ES5DB ES5FB-ES5GB ES5JB INSTANTANEOUSFORWARDVOLTAGE(V) 1.8 �.�� 2.0 Fig.3 Typical Forward Voltage Revision:SFRD-May.2023-A0 ��� PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) ��� Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 ES5AB THRU ES5JB SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMB R3 0.098 3000 6000 48000 13'' Package Outline Dimensions (SMB/DO-214AA) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:SFRD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 4.25 4.85 1.85 3.30 2.15 0.75 0.073 0.087 3.94 0.130 0.155 2.65 1.52 0.203 0.15 0.31 5.59 Min. Max. 2.10 - - Zhuhai Hongjiacheng Technology co., Ltd 0.167 0.191 0.085 0.104 0.030 0.060 - 0.008 0.200 0.220 0.006 Dimensions Millimeters 2.26 Max. 2.21 - 5.08 Min. Inches Min. - 0.089 2.74 - 0.085 0.012 Inches Max. - 0.107 www.ichjc.com
ES5JB 价格&库存
很抱歉,暂时无法提供与“ES5JB”相匹配的价格&库存,您可以联系我们找货
ES5JB
    • 1+0.25456
    • 10+0.20315
    • 30+0.17745
    • 100+0.15812
    • 500+0.14267
    • 1000+0.13500
    库存:6566
