SS520B
SS520B
    HONGJIACHENG(宏嘉诚)
    DO-214AA(SMB)
SS520B 数据手册
� �D� 宏迦橙 SS52B THRU SS520B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Features DO-214AA(SMB) •Low profile package •Ideal for automated placement •Guardring for overvoltage protection •Low power losses, high efficiency •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications For use in low voltage high frequency inverters, freewheeling,DC/DC converters, and polarity protection applications. Mechanical Data •Case: DO-214AA(SMB) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Device marking code Maximum Repetitive Peak Reverse Voltage VRRM V Maximum DC blocking Voltage VDC V Maximum RMS Voltage VRMS Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave Junction temperature 20 30 20 30 14 21 40 50 60 40 50 60 28 35 42 IF(AV) A Tstg ℃ -55 ~ +150 RθJ-A ℃ /W 60 A Tj Typical Thermal Resistance SS52B SS53B SS54B SS55B SS56B SS58B SS510B SS515B SS520B V IFSM Storage temperature SS52B SS53B SS54B SS55B SS56B SS58B SS510BSS515BSS520B Maximum instantaneous forward voltage Revision:SBD-May.2023-A0 100 70 200 150 200 105 140 ℃ /W 22 TEST CONDITIONS SYMBOL UNIT SS52B SS53B SS54B SS55B SS56B SS58B SS510B SS515B SS520B IF=5.0A Maximum DC reverse currentat VRM=VRRM rated DC blocking voltage Typical junction capacitance 80 56 150 -55 ~ +150 Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER 100 120 ℃ RθJ-L 5.0 80 VA=25℃ VA=100℃ 4.0V DC,1MHz VF V 0.55 IR mA CJ pF 1 of 3 0.2 10 Zhuhai Hongjiacheng Technology co., Ltd 0.70 0.85 300 0.05 0.95 5 www.ichjc.com � �D� 宏迦橙 SS52B THRU SS520B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 160 4.0 120 100 3.0 80 2.0 60 40 1.0 0 20 40 0 80 LEADTEMPERATURE(℃) 120 0 160 Fig. 1 Forward Current Derating Curve 100 100 Tj=25℃ Pulsewidth=300us 1%DutyCycle 10 100 NUMBEROFCYCLES SS52B-SS56B SS58B-SS520B 10 INSTANTANEOUSREVERSECURRENT(mA)  INSTANTANEOUSFORWARDCURRENT(A) 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 10 Tj=100℃ 1.0 1.0 0.1 0.1 0.01 8.3msSingleHalfSineWave (JEDECMethod) 140 PEAKFORWARDSURGECURRENT(A) AVERAGERECTIFIELDOUTPUTCURRENT(A) 5.0 0 0.2 0.4 0.6 0.8 1.0 SS52B-SS54B SS55B-SS56B SS58B-SS510B SS515B-SS520B 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) 1.4 0.01 0.001 1.6 Fig.3 Typical Forward Voltage Revision:SBD-May.2023-A0 Tj=25℃ 0 20 40 60 80 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 100 Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SS52B THRU SS520B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMB R3 0.098 3000 / 48000 13'' Package Outline Dimensions (SMB/DO-214AA) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:SBD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 4.25 4.85 1.85 3.30 2.15 0.75 0.073 0.087 3.94 0.130 0.155 2.65 1.52 0.203 0.15 0.31 5.59 Min. Max. 2.10 - - Zhuhai Hongjiacheng Technology co., Ltd 0.167 0.191 0.085 0.104 0.030 0.060 - 0.008 0.200 0.220 0.006 Dimensions Millimeters 2.26 Max. 2.21 - 5.08 Min. Inches Min. - 0.089 2.74 - 0.085 0.012 Inches Max. - 0.107 www.ichjc.com
SS520B 价格&库存
很抱歉,暂时无法提供与“SS520B”相匹配的价格&库存,您可以联系我们找货
SS520B
    • 1+0.42768
    • 10+0.34128
    • 30+0.29808
    • 100+0.26568
    • 500+0.23976
    • 1000+0.22680
    库存:2324
