RS3MB
RS3MB
    HONGJIACHENG(宏嘉诚)
    DO-214AA(SMB)
RS3MB 数据手册
� �D� 宏迦橙 RS3AB THRU RS3MB SURFACE MOUNT FAST RECOVERY RECTIFIER www.ichjc.com Features DO-214AA(SMB) •Low profile package •Ideal for automated placement •Glass passivated pallet chip junction •Fast reverse recovery time •Fast switching for high efficiency •High forward surge capability Applications For use in fast switching rectification of power supplies,inverters, converters, and freewheeling diodes forconsumer, and telecommunication. Mechanical Data •Case: DO-214AA(SMB) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT RS3AB RS3BB RS3DB RS3GB RS3JB RS3KB RS3MB Maximum RMS Voltage VRMS V 35 70 140 280 420 560 700 Maximum repetitive peak reverse voltage VRRM Maximum DC blocking Voltage V VDC Maximum Average Forward Rectified Current  @60Hz sinewave, Resistance load,TL (Fig.1) Non-repetitive Peak Forward Surge Current @ t=8.3ms Half-sine wave V Junction temperature 100 200 200 400 400 Tstg ℃ -55 ~+150 RθJ-A(1) ℃ /W 60 RθJ-L(1) A 600 600 A Tj Typical Thermal Resistance 50 100 IF(AV) IFSM Storage temperature 50 3.0 800 800 1000 1000 100 ℃ -55 ~+150 ℃ /W 25 Note : (1)Thermal resistance from junction to ambient and from junction tolead mounted on P.C.B.with 0.2"× 0.2"(5.0mm x5.0 mm) copper pad areas Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER Maximum instantaneous forward voltage Maxinum reverse recovery time Maximum DC reverse currentat rated DC blocking voltage Typical junction capacitance Revision:FRD-May.2023-A0 TEST CONDITIONS SYMBOL UNIT IF=0.5A,IR=1.0A,Irr=0.25A Trr ns VRM=VRRM IR μA CJ pF IF=3.0A Ta=25℃ Ta=125℃ 4.0V DC,1MHz VF V 1 of 3 RS3AB RS3BB RS3DB RS3GB RS3JB RS3KB RS3MB Zhuhai Hongjiacheng Technology co., Ltd 150 1.3 2.0 250 500 200 60 www.ichjc.com � �D� 宏迦橙 RS3AB THRU RS3MB SURFACE MOUNT FAST RECOVERY RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 140 4.0 3.5 PEAKFORWARDSURGECURRENT(A) AVERAGEFORWARDOUTPUTCURRENT(A) 120 3.0 100 2.5 80 2.0 60 1.5 40 1.0 20 0.5 0.2 0 20 40 60 80 100 LEADTEMPERATURE(℃) 120 140 0 160 Fig. 1 Forward Current Derating Curve 100 10 NUMBEROFCYCLES Fig.2 Maximum Non-Repetitive Peak Forward Surge Current ��� Tj=25℃ Pulsewidth=300us 1%DutyCycle �� 1 Tj=125℃ �.� 0.1 0.01 0.2 1 INSTANTANEOUSREVERSECURRENT(μA) 10  INSTANTANEOUSFORWARDCURRENT(A) 8.3msSingleHalfSineWave (JEDECMethod) Tj=25℃ �.� 0.4 0.6 0.8 1.0 1.2 INSTANTANEOUSFORWARDVOLTAGE(V) 1.4 �.�� 1.6 Fig.3 Typical Forward Voltage Revision:FRD-May.2023-A0 ��� PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) ��� Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 RS3AB THRU RS3MB SURFACE MOUNT FAST RECOVERY RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMB R3 0.098 3000 / 48000 13'' Package Outline Dimensions (SMB/DO-214AA) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:FRD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 4.25 4.85 1.85 3.30 2.15 0.75 0.073 0.087 3.94 0.130 0.155 2.65 1.52 0.203 0.15 0.31 5.59 Min. Max. 2.10 - - Zhuhai Hongjiacheng Technology co., Ltd 0.167 0.191 0.085 0.104 0.030 0.060 - 0.008 0.200 0.220 0.006 Dimensions Millimeters 2.26 Max. 2.21 - 5.08 Min. Inches Min. - 0.089 2.74 - 0.085 0.012 Inches Max. - 0.107 www.ichjc.com
RS3MB 价格&库存
很抱歉,暂时无法提供与“RS3MB”相匹配的价格&库存,您可以联系我们找货
RS3MB
    • 20+0.16913
    • 200+0.13306
    • 600+0.11308
    • 3000+0.10098
    • 9000+0.09062
    • 21000+0.08500
    库存:208
