SL310B
SL310B
    NH(纽航)
    DO-214AA(SMB)
SL310B 数据手册
Niu Hang Electronic Co. Ltd Specification For Approval SL310B LOW VF SCHOTTKY RECTIFIERS 100 VOLTAGE: Volts CURRENT: 3.0 Amperes Marking and Polarity SMB(DO-214AA) FEATURES · · · Super Low Forward Voltage Drop for high efficiency Low leakage current for high reliability FFYWW High forward surge capability for high reliability H MECHANICAL DATA SL310B · · · · Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Mounting Position: Any Lead Free: Lead Free Finish, RoHS Compliant Weight:App. 0.095 grams(0.0034 ounce) Remark: TYPICAL APPLICATIONS ①. · For use in high frequency inverters , ②. NH=niuhang trademark DC/DC converters,LED driver etc. applications ③. FF=Product line,According to actual changes; SL310B=Modle YWW=Periodic code,According to actual changes; ④. White band denotes cathode Maximum Ratings (Ratings at 25℃ ambient temperature unless otherwise specified.) Symbol SL310B Unit Maximum repetitive peak reverse voltage VRRM 100 V Maximum RMS voltage VRMS 70 V Maximum DC blocking voltage VDC 100 V Maximum average forward rectified current(see fig.1) IF(AV) 3.0 A Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC method at rated TL)(see fig.5) IFSM 80 A I2t 26.56 A2sec Parameter Current Squared Time Per Diode(t
SL310B 价格&库存
很抱歉,暂时无法提供与“SL310B”相匹配的价格&库存,您可以联系我们找货
SL310B
    • 10+0.18774
    • 100+0.18333
    • 300+0.18040
    • 1000+0.17736
    库存:10
