RS2M
RS2M
    NH(纽航)
    DO-214AA(SMB)
RS2M 数据手册
Niu Hang Electronic Co. Ltd Specification For Approval RS2A THRU RS2M SURFACE MOUNT FAST RECOVERY RECTIFIERS VOLTAGE: 50~1000 Volts 2.0 CURRENT: Amperes SMB(DO-214AA) Marking and Polarity FEATURES · · · · · Glass passivated chip junction FFYWW fast reverse recovery time Low Forward Voltage Drop for high efficiency Low leakage current for high reliability RS2x High forward surge capability for high reliability MECHANICAL DATA · · · · Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Mounting Position: Any Remark: Lead Free: Lead Free Finish, RoHS Compliant ①. NH=niuhang trademark Weight:App. 0.095 grams(0.0034 ounce) ②. FF=Product line,According to actual changes; TYPICAL APPLICATIONS YWW=Periodic code,According to actual changes; · For use in high frequency inverters ,AC/DC converters, ③. RS2x=Modle,x=A,B,D,G,J,K,M DC/DC converters,LED driver etc. applications ④. White band denotes cathode Maximum Ratings (Ratings at 25℃ ambient temperature unless otherwise specified.) Parameter Symbol RS2A RS2B RS2D RS2G RS2J RS2K RS2M Unit Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V Maximum DC blocking voltage Maximum average forward rectified current(see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC method at rated TL)(see fig.5) IF(AV) 2.0 A IFSM 60 A 2 14.94 A2sec It Current Squared Time Per Diode(t
很抱歉,暂时无法提供与“RS2M”相匹配的价格&库存,您可以联系我们找货
