SS320B
SS320B
    LJ(朗捷)
    DO-214AA(SMB)
SS320B 数据手册
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS32B THRU SS320B 20 to 200 Volts CURRENT 3.0 Ampere Features  The plastic package carries Underwriters Laboratory  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency Flammability Classification 94V-0  Built-in strain relief,ideal for automated placement  High forward surge current capability  High temperature soldering guaranteed: 260 C/10 seconds at terminals Mechanical Data  Case: Transfer molded plastic  Epoxy: UL 94V-0 rate flame retardant  Lead :Solder plated, solderable per MIL-STD-750 method 2026  Polarity: Color band denotes cathode end  Weight: 0.003ounce, 0.093 gram Maximum Ratings and Electrical Characteristics  Ratings at 25℃ ambient temperature unless otherwise specified  Single phase, half wave, 60Hz, resistive or inductive load  For capacitive load derate current by 20% SYMBOL S VRRM SS 32B 20 SS 34B 40 SS 35B 50 SS 36B 60 SS 38B 80 Maximum RMS Voltage VRMS 14 28 35 42 Maximum DC Blocking Voltage Maximum Average Forward Rectified Current at TLsee figure 1 TL =100℃ Peak Forward Surge Current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage @ 3.0A(Note1) Maximum DC Reverse Current at TA = 25℃ rated DC Blocking Voltage per TA = 100℃ element VDC 20 40 50 60 TYPE NUMBER Maximum Repetitive Peak Reverse Voltage Typical Thermal Resistance (Note 2) SS 315B 150 SS 320B 200 56 70 105 140 Volts 80 100 150 200 Volts UNIT Volts I(AV) 3.0 Amps IFSM 80 Amps VF 0.55 0.70 0.85 0.1 IR 20.0 10.0 50 RθJL 12 CJ Operating Junction Temperature TJ TSTG 0.90 0.01 RθJA Diode junction capacitance (Note 3) Storage Temperature Range SS 310B 100 300 2.0 Volts mA ℃/W 200 (-55 to +150) pF (-65 to +175) (-55 to +150) ℃ ℃ Notes: 1. Pulse test:300μs pulse width,1% duty cycle. 2. Thermal resistance from Junction to ambient and from junction to lead mounted on PCB. with 0.3×0.3″(8.0 × 8.0mm)copper pad areas. 3. f=1MHz and applied 4V DC reverse voltage. Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS32B THRU SS320B 20 to 200 Volts CURRENT 3.0 Ampere 3 .5 3 .0 2 .5 S S 3 2B -S S 3 10B S S 3 15 B -S S 320B 2 .0 1 .5 1 .0 0 .5 0 50 P .C .B .M O U N T E D 0 .3 0X 0.30 ″(8.0X 8.0m m ) COPPER PAD AREAS 60 70 80 90 1 00 1 10 1 20 1 30 1 40 1 50 1 60 F 1G .2-M A X IM U M N O N -R E P E T IT IV E P E A K FORW ARD SURGE CURRENT 1 00 T L = 100℃ 8 .3 m s S in g le H a lf S ine-W ave (JE D E C M e th od) 90 80 70 AMPERES 4 .0 AMPERES AVERAGE FORWARD CURRENT F 1G .1-F O R W A R D C U R R E N T D E R A T IN G C U R V E PEAK FORWARD SURGE CURRENT, Ratings and Characteristic Curves (TA=25℃ unless otherwise noted) 60 50 40 30 20 10 0 1 1 00 F 1G .4-T Y P IC A L R E V E R S E C H A R A C T E R IS T IC S T J =2 5℃ P u lse W id th=300us 1 % D u ty C ycle 1 .0 0 .1 S S 3 2B -S S 34B S S 3 5B -S S 36B S S 3 8B -S S 3 15B S S 3 20B 1 00 T J = 100℃ 10 MICROAMPERES INSTANTANEOUS REVERSE CURRENT, AMPERES INSTANTANEOUS FORWARD CURRENT, F 1G .3-T Y P IC A L IN S T A N T A N E O U S F O R W A R D C H A R A C T E R IS T IC S 10 10 N U M B E R O F C Y C LE S A T 60 H z LE A D T E M P E R A T U R E ,(℃ ) 1 .0 T J =7 5℃ 0 .1 T J =2 5℃ 0 .01 0 .0 01 0 0 .01 0 0 .2 0 .4 0 .6 0 .8 1 .0 1 .2 1 .4 IN S T A N T A N E O U S F O R W A R D V O LT A G E , V O LT S 20 40 60 80 1 00 PERCENT O F RATED PEAK R E V E R S E V O LT A G E ,(% ) F 1G .5-T Y P IC A L JU N C T IO N C A P A C IT A N C E JUNCTION CAPACITANCE,(pF) 2 0 00 1 0 00 T J =2 5℃ f= 1 M H z V sig = 5 0m V p-p 1 00 S S 3 2B -S S 34B S S 3 5B -S S 3 20B 0 .1 1 .0 10 1 00 R E V R E S E V O LT A G E , V O LT S Sep-03, Rev A CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS32B THRU SS320B Package Outline Dimensions CURRENT 20 to 200 Volts 3.0 Ampere in inches (millimeters) Marking Type number Sep-03, Rev A Marking code SS32B SS32 SS34B SS34 SS35B SS35 SS36B SS36 SS38B SS38 SS310B SS310 SS315B SS315 SS320B SS320 CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS32B THRU SS320B 20 to 200 Volts CURRENT 3.0 Ampere Package Reel Information Specifications Ao Bo Ko Po W t1 SMB 3.77±0.10 5.70±0.10 2.67±0.10 4.00±0.1 12.0±0.05 0.23±0.02 DEVICE TYPE SMB Sep-03, Rev A 13"Reel 07"Reel Tape Width Q'TY/REEL(p BOX/CARTO Q'TY/CARTO Q'TY/REEL(p REEL/BOX BOX/CARTO Q'TY/CARTO cs) ON N(pcs) cs) ON N(pcs) 12mm 3000 8 48000 NA NA NA NA CHANGZHOU LANGJIE ELECTRONICS CO.,LTD SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER VOLTAGE RANGE SS32B THRU SS320B CURRENT 20 to 200 Volts 3.0 Ampere Reflow Profile Reflow Condition Pre Heat Temperature Min. +150°C Temperature Max. +200°C Time(Min to Max) 60-180 secs. Average ramp up rate(Liquidus Temp(TL) to peak) 3°C/sec. Max. TS(max) to TL - Ramp-up Rate 3°C/sec. Max. Reflow Sep-03, Rev A Pb-Free Assembly Temperature (TL)(Liquidus) +217°C Temperature (TL) 60-150 secs. Peak Temp (TP) +(260+0/-5 )°C Time within 5°C of actual Peak Temp (TP) 25 secs. Ramp-down Rate 6°C/sec. Max. Time 25°C to peak Temp (TP) 8 min. Max. Do not exceed +260°C CHANGZHOU LANGJIE ELECTRONICS CO.,LTD
SS320B 价格&库存
很抱歉,暂时无法提供与“SS320B”相匹配的价格&库存,您可以联系我们找货
SS320B
    • 10+0.30589
    • 100+0.24679
    • 300+0.21725
    • 3000+0.19508
    • 6000+0.17730
    • 9000+0.16845
    库存:5804
