SS32B~SS320B
Rev. A Dec.-2017
DATA SHEET
Descriptions
表面贴装肖特基整流二极管,反向电压:20V~200V,正向电流:3.0A, SMB 封装。
Surface Mount Schottky Barrier Rectifiers, Reverse Voltage:20 to 200V,Forward Current: 3.0A ,SMB
package.
特征
/ Features
玻璃钝化芯片,无铅符合欧盟 RoHS 指令 2011/65/EU,适用表面贴装。无卤产品。
Glass Passivated Chip Junction, Lead free in comply with EU RoHS 2011/65/EU directives, For
surface mounted applications. HF product.
用途
Applications
一般用途.
General purpose.
内部等效电路
/ Equivalent Circuit
引脚排列
/ Pinning
印章代码
/ Marking
见印章说明。See Marking Instructions.
http://www.fsbrec.com
1/7
SS32B~SS320B
Rev. A Dec.-2017
极限参数
DATA SHEET
Absolute Maximum Ratings(Ta=25℃)
数值
Rating
单位
Unit
参数
Parameter
符号
Symbol
Maximum Repetitive Peak
Reverse Voltage
VRRM
60
80
100
120
150
200
V
Maximum RMS voltage
VRMS
14
28
42
56
70
84
105
140
V
VDC
60
80
100
120
150
200
V
Maximum DC Blocking
Voltage
Maximum Average
Forward Rectified Current
Peak Forward Surge
Current 8.3 ms Single Half
Sine Wave Superimposed
on Rated Load
(JEDEC Method)
Typical Junction
Capacitance
Typical Thermal
1)
Resistance
Operating and Storage
Temperature Range
SS32B SS34B SS36B SS38B SS310B SS312B SS315B SS320B
IF(AV)
3.0
A
IFSM
80
A
Cj
450
400
RθJA
Tj,Tstg
pF
60
℃/W
-55~+150
Note:
1)P.C.B. mounted with 2.0 X 2.0" (5 X5 cm) copper pad areas.
电性能参数
/ Electrical Characteristics(Ta=25℃)
参数
Parameter
Maximum
Instantaneous
Forward Voltage
Maximum DC
Reverse Current
at Rated DC
Blocking Voltage
符号
Symbol
VF
数值
测试条件
Rating
Test
Conditions SS32B SS34B SS36B SS38B SS310BSS312B SS315B SS320B
IF=3.0A
0.55
0.70
0.85
0.95
单位
Unit
V
Ta=25℃
0.5
0.3
mA
Ta=100℃
5.0
3.0
mA
IR
2/7
SS32B~SS320B
Rev. A Dec.-2017
电参数曲线图
DATA SHEET
/ Electrical Characteristic Curve
3/7
SS32B~SS320B
Rev. A Dec.-2017
外形尺寸图
DATA SHEET
/ Package Dimensions
4/7
SS32B~SS320B
Rev. A Dec.-2017
印章说明
DATA SHEET
5/7
SS32B~SS320B
Rev. A Dec.-2017
印章说明
DATA SHEET
SS32
说明:
SS32:
为型号代码
: 为生产批号追溯码,第 1 个*为年月代码,后面 3 个*为当月小批号代码
Note:
SS32:
Product Type Code
****: Lot No. Code,The 1st * means:YM Code,The last 3 * means:little Lot No
Code
6/7
SS32B~SS320B
Rev. A Dec.-2017
DATA SHEET
回流焊温度曲线图(无铅)
Temperature Profile for IR Reflow Soldering(Pb-Free)
说明:
Note:
1、预热温度 25~150℃,时间 60~90sec;
1.Preheating:25~150℃, Time:60~90sec.
2、峰值温度 245±5℃,时间持续为 5±0.5sec;
2.Peak Temp.:245±5℃, Duration:5±0.5sec.
3、焊接制程冷却速度为 2~10℃/sec.
3. Cooling Speed: 2~10℃/sec.
耐焊接热试验条件
Resistance to Soldering Heat Test Conditions
温度:260±5℃
包装规格
Time:10±1 sec
/ REEL
Package Type
封装形式
使用说明
Temp.:260±5℃
/ Packaging SPEC.
卷盘包装
SMB
时间:10±1 sec.
Units 包装数量
Dimension
包装尺寸
3
(unit:mm )
Units/Reel
只/卷盘
Reels/Inner Box
卷盘/盒
Units/Inner Box
只/盒
Inner Boxes/Outer Box
盒/箱
Units/Outer Box
只/箱
Reel
Inner Box 盒
Outer Box 箱
3000
5
15000
5
75000
7〞×11
185X180X105
390X385X205
/ Notices
7/7
很抱歉,暂时无法提供与“SS320B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39334
- 100+0.31860
- 300+0.28124
