SMB3ZxxA SERIES
Surface Mount Silicon Zener Diodes
Zener Voltage 3.3 ~ 250 V
DO-214AA(SMB)
3.0 Watt Power Dissipation
Features
● Glass passivated chip
● Built-in strain relief
● Low inductance
● High peak reverse power dissipation
● Low reverse leakage
● For use in stabilizing and clipping
with high power rating
● RoHS compliant
Mechanical Data
Unit: inch(mm)
● Case: DO-214AA Molded plastic
● Lead: Solderable per MIL-STD-750, method 2026
● Epoxy: UL 94V-0 rate flame retardant
● High reliability grade (AEC-Q101 qualified)
● Polarity: Color band denotes cathode end
● Mounting position: Any
Parameter
Symbols
Value
Unit
PD
3.0
W
VF
1.2
V
Junction temperature range
TJ,TSTG
-55 to +150
Storage temperature range
TJ,TSTG
-55 to +150
DC Power dissipation at TL = 75 °C
(1)
Maximum forward voltage at if=200mA
Note:
(1)TL=Lead temperature at 3/8'' (9.5mm)from body
REV.1.1,2019-01
Changzhou zhide Electronics CO.,LTD
www.cz-zhide.com
SMB3ZxxA SERIES
Ratings and Characteristics Curves (TA=25℃ unless otherwise noted)
REV.1.1,2019-01
www.cz-zhide.com
SMB3ZxxA SERIES
Part Number
Device
Marking
Code
SMB3Z3.3A
SMB3Z3.6A
SMB3Z3.9A
SMB3Z4.3A
SMB3Z4.7A
SMB3Z5.1A
SMB3Z5.6A
SMB3Z6.2A
SMB3Z6.8A
SMB3Z7.5A
SMB3Z8.2A
SMB3Z9.1A
SMB3Z10A
SMB3Z11A
SMB3Z12A
SMB3Z13A
SMB3Z14A
SMB3Z15A
SMB3Z16A
SMB3Z17A
SMB3Z18A
SMB3Z19A
SMB3Z20A
SMB3Z22A
SMB3Z24A
SMB3Z27A
SMB3Z30A
SMB3Z33A
SMB3Z36A
SMB3Z39A
SMB3Z43A
SMB3Z47A
SMB3Z51A
SMB3Z56A
SMB3Z62A
SMB3Z68A
SMB3Z75A
SMB3Z82A
SMB3Z91A
SMB3Z100A
SMB3Z110A
SMB3Z120A
SMB3Z130A
SMB3Z140A
SMB3Z150A
SMB3Z160A
SMB3Z170A
SMB3Z180A
SMB3Z190A
SMB3Z200A
SMB3Z210A
SMB3Z220A
SMB3Z230A
SMB3Z240A
SMB3Z250A
REV.1.1,2019-01
3H0
3H1
3H2
3H3
3H4
3H5
3H6
3A0
3A1
3A2
3A3
3A4
3A5
3A6
3A7
3A8
3A9
3B0
3B1
3B2
3B3
3B4
3B5
3B6
3B7
3B8
3B9
3C0
3C1
3C2
3C3
3C4
3C5
3C6
3C7
3C8
3C9
3F0
3F1
3F2
3F3
3F4
3F5
3F6
3F7
3F8
3F9
3G1
3G2
3G3
3G4
3G5
3G6
3G7
3G8
Nominal Zener Voltage @IT
Maximum Zener Impedance
IZT(mA)
VZ AVE.(V)
VZ MIN.(V)
VZ MAX.(V)
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10.0
11.0
12.0
13.0
14.0
15.0
16.0
17.0
18.0
19.0
20.0
22.0
24.0
27.0
30.0
33.0
36.0
39.0
43.0
47.0
51.0
56.0
62.0
68.0
75.0
82.0
91.0
100.0
110.0
120.0
130.0
140.0
150.0
160.0
170.0
180.0
190.0
200.0
210.0
220.0
230.0
240.0
250.0
3.14
3.42
3.71
4.09
4.47
4.85
5.32
5.89
6.46
7.13
7.79
8.65
9.50
10.45
11.40
12.35
13.30
14.25
15.20
16.15
17.10
18.05
19.00
20.90
22.80
25.65
28.50
31.35
34.20
37.05
40.85
44.65
48.45
53.20
58.90
64.60
71.25
77.90
86.45
95.00
104.50
114.00
123.50
133.00
142.50
152.00
161.50
171.00
180.50
190.00
199.50
209.00
218.50
228.00
237.50
3.47
3.78
4.10
4.52
4.94
5.36
5.88
6.51
7.14
7.88
8.61
9.56
10.50
11.55
12.60
13.65
14.70
15.75
16.80
17.85
18.90
19.95
21.00
23.10
25.20
28.35
31.50
34.65
37.80
40.95
45.15
49.35
53.55
58.80
65.10
71.40
78.75
86.10
95.55
105.00
115.50
126.00
136.50
147.00
157.50
168.00
178.50
189.00
199.50
210.00
220.50
231.00
241.50
252.00
262.50
227.3
208.3
192.0
174.0
160.0
147.0
134.0
121.0
110.0
100.0
91.0
82.0
75.0
68.0
63.0
58.0
53.0
50.0
47.0
44.0
42.0
40.0
37.0
34.0
31.0
28.0
25.0
23.0
21.0
19.0
17.0
16.0
15.0
13.0
12.0
11.0
10.0
9.1
8.2
7.5
6.8
6.3
5.8
5.3
5.0
4.7
4.4
4.2
4.0
3.7
3.5
3.3
3.1
2.9
2.7
Maximum Reverse
Leakage Current
Maximum
DC Zener
Current
ZZT MAX.(Ω)
@IZT
ZZK MAX.(Ω)
@IZK
IZK(mA)
IR(uA)@VR
VR(V)
IZM(mA)
10.0
9.0
4.5
4.5
4.0
3.5
2.5
1.5
2.0
2.0
2.3
2.5
3.5
4.0
4.5
4.5
5.0
5.5
5.5
6.0
6.0
7.0
7.0
8.0
9.0
10.0
16.0
20.0
22.0
28.0
33.0
38.0
45.0
50.0
55.0
70.0
85.0
95.0
115.0
160.0
225.0
300.0
375.0
475.0
550.0
625.0
650.0
700.0
800.0
875.0
950.0
1600.0
2000.0
2500.0
3000.0
500.0
500.0
400.0
400.0
500.0
550.0
600.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
700.0
750.0
750.0
750.0
750.0
750.0
750.0
750.0
1000.0
1000.0
1000.0
1000.0
1500.0
1500.0
1500.0
2000.0
2000.0
2000.0
2000.0
3000.0
3000.0
3000.0
4000.0
4500.0
5000.0
5000.0
6000.0
6500.0
7000.0
7000.0
8000.0
8000.0
8300.0
8500.0
9000.0
9000.0
9500.0
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
0.50
0.50
0.50
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
100.0
100.0
100.0
50.0
50.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
1.0
1.0
1.0
1.0
1.0
1.0
2.0
3.0
4.0
5.0
6.0
7.0
7.6
8.4
9.1
9.9
10.6
11.4
12.2
13.0
13.7
14.4
15.2
16.7
18.2
20.6
22.5
25.1
27.4
29.7
32.7
35.6
38.8
42.6
47.1
51.7
56.0
62.2
69.2
76.0
83.6
91.2
98.8
106.4
114.0
121.6
130.4
136.8
144.8
152.0
169.0
178.0
186.0
195.0
205.0
817.0
749.0
691.0
627.0
573.0
528.0
481.0
435.0
393.0
360.0
330.0
297.0
270.0
225.0
246.0
208.0
193.0
180.0
169.0
159.0
150.0
142.0
135.0
123.0
112.0
100.0
90.0
82.0
75.0
69.0
63.0
57.0
53.0
48.0
44.0
40.0
36.0
33.0
30.0
27.0
25.0
22.0
21.0
19.0
18.0
17.0
16.0
15.0
14.0
13.0
12.3
11.6
10.9
10.2
9.5
www.cz-zhide.com
很抱歉,暂时无法提供与“SMB3Z36A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.75888
- 50+0.61463
- 250+0.53221
- 500+0.45509
- 2500+0.42075
- 5000+0.40014
