SS220
SS220
    YFW(佑风微)
    DO-214AA(SMB)
SS220 数据手册
SS22 THRU SS220 SMB Surface Mount Schottky Barrier Rectifier Pinning Reverse Voltage - 20 to 200 V 1.Cathode Forward Current - 2 A         1 FEATURES  Metal silicon junction, majority carrier conduction  For surface mounted applications  Low power loss, high efficiency 2.Anode   2     DO-214AA/SMB  High forward surge current capability Marking Code  For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications SS22 SS22 SS24 SS24  Lead free in comply with EU RoHS 2011/65/EU directives SS26 SS26 MECHANICAL DATA  Case: DO-214AA/SMB  Terminals: Solderable per MIL-STD-750, Method 2026 SS28 SS28 SS210 SS210 SS212 SS212 SS215 SS215 SS220 SS220  Approx. Weight: 0.095g / 0.003oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,for capacitive load, derate by 20 % Parameter Symbols SS22 SS24 SS26 SS28 SS210 SS212 SS215 SS220 Units Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current IF(AV) Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method) 2.0 IFSM A 55 45 A Maximum Instantaneous Forward Voltage at 2 A VF Maximum Instantaneous Reverse Current TA = 25°C at Rated DC Reverse Voltage TA = 100°C IR 0.5 5 0.3 3 mA Typical Junction Capacitance(1) Cj 220 110 pF Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range 0.55 0.70 0.90 0.85 V RθJA 60 °C/W Tj -55 ~ +150 °C Tstg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.yfwdiode.com 1/3 G uangDong YFW Electronics Co, Ltd. SS22 THRU SS220 SMB Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 10 4 T J =75°C 10 2 SS22B/SS26B T J =25°C 10 0 0 40 20 60 80 Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) T J =25°C 20 10 1.0 SS22B/SS24B SS26B/SS28B SS210B/SS212B SS215B/SS220B 0.1 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 20 SS22B~SS26B SS28B~SS220B 10 0.1 10 1 100 Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 100 Number of Cycles at 60Hz www.yfwdiode.com 200 100 1.8 SS22B-SS28B SS210B-SS220B 1 500 Reverse Voltage (V) 60 10 1000 Instaneous Forward Voltage (V) Transient Thermal Impedance( °C /W) 0 100 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Instaneous Forward Current (A) SS28B-SS220B 10 1 Case Temperature (°C) Peak Forward Surage Current (A) T J =100°C 10 3 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) 2/3 G uangDong YFW Electronics Co, Ltd. SS22 THRU SS220 SMB DO-214AA SMB Package Outline Plastic surface mounted package; 2 leads L A A1 C A b D E E1 UNIT mm mil VM A A1 L C b 5.59 0.20 1.5 0.305 2.2 3.3 5.08 0.05 0.8 0.152 1.9 155 220 7.9 59 12 87 200 2.0 32 6 75 E1 A E D max 2.44 4.70 3.94 min 2.13 4.06 max 96 185 min 84 160 130 The recommended mounting pad size 2.2 (86) 2.4 (94) 2.8 (110) 2.4 (94) mm Unit : (mil) Summary of Packing Options Package DO-214AA SMB www.yfwdiode.com Packing Description Packing Quantity Industry Standard Tape/Reel,13”reel 3000 EIA-481-1 3/3 G uangDong YFW Electronics Co, Ltd.
SS220 价格&库存
很抱歉,暂时无法提供与“SS220”相匹配的价格&库存,您可以联系我们找货
