SL56-MS
SL56-MS
    MSKSEMI(美森科)
    DO-214AA(SMB)
    二极管配置:独立式 直流反向耐压(Vr):60V 平均整流电流(Io):5A 正向压降(Vf):500mV@5A后面-MS代表品牌
SL56-MS 数据手册
SL56-MS Product specification SL56-MS FEATURES  Ideal for surface mount applications  Easy pick and place  Built-in strain relief  Low forward voltage drop  MACHANICAL DATA      Case: Molded plastic Epoxy: UL 94V-0 rate flame retardant Metallurgically bonded construction Polarity: Color band denotes cathode end Mounting position: Any  Weight: 0.093 grams VOLTAGE RANGE 60 Volts  CURRENT 5.0 Ampere Reference News PACKAGE OUTLINE PIN CONFIGURATION Marking SL56 SMB Copyright© Msksemi Incorporated www.msksemi.com SL56-MS MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SL56-MS UNITS Maximum Recurrent Peak Reverse Voltage 60 V Maximum RMS Voltage 42 V Maximum DC Blocking Voltage 60 V 5.0 A 120 A 0.55 V Maximum Average Forward Rectified Current See Fig. 1 Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 2.0A Maximum DC Reverse Current Ta=25 C 0.15 mA at Rated DC Blocking Voltage Ta=125 C 30 mA Typical Junction Capacitance (Note1) 370 pF Typical Thermal Resistance R JA (Note 2) 70 C/W Operating Temperature Range TJ - 5 5 to + 1 2 5 Storage Temperature Range TSTG - 5 5 to + 1 2 5 C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. P.C.B. mounted with 0.2" x 0.2" (5.0 mm x 5.0 mm) copper pad areas Copyright© Msksemi Incorporated www.msksemi.com SL56-MS RATING AND CHARACTERISTIC CURVES (SL56-MS Copyright© Msksemi Incorporated ) www.msksemi.com SL56-MS PACKAGE MECHANICAL DATA Dimensions Ref. Millimeters Inches Min. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 2.60 K L 0.270 0.100 0.090 2.40 REEL SPECIFICATION P/N PKG QTY SL56-MS SMB 3000 Copyright© Msksemi Incorporated www.msksemi.com SL56-MS Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not handle applications that require extremely high levels of reliability, such as life-support have specifications that can systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. Copyright© Msksemi Incorporated www.msksemi.com
SL56-MS 价格&库存
很抱歉,暂时无法提供与“SL56-MS”相匹配的价格&库存,您可以联系我们找货
SL56-MS
  • 5+0.49106
  • 50+0.39775
  • 150+0.35109
  • 500+0.31610
  • 3000+0.28810
  • 6000+0.27411
库存:1643
