SMBJ5355B
SMBJ5355B
    LGE(鲁光)
    DO-214AA(SMB)
SMBJ5355B 数据手册
SMBJ5333B-SMBJ5388B Surface Mount Silicon Zener Diodes VZ : 3.3 - 200 Volts PD : 5 Watts Features SMB/DO-214AA  Complete Voltage Range 3.3 to 200 Volts  High peak reverse power dissipation  High reliability  Low leakage current  Pb / RoHS Free 0.180(4.57) 0.160(4.06) 0.086(2.20) 0.077(1.95) 0.209(5.30) 0.201(5.10) Mechanical Data       0.155(3.94) 0.130(3.30) 0.012(0.30) 0.006(0.15) Case : SMB (DO-214AA) Molded plastic Epoxy : UL94V-O rate flame retardant Lead : Lead formed for Surface mount Polarity : Color band denotes cathode end Mounting position : Any Weight : 0.093 gram 0.096(2.44) 0.084(2.13) 0.059(1.50) 0.035(0.90) 0.008(0.20) 0.002(0.05) Dimensions in inches and(millimeters) MAXIMUM RATINGS Rating at 25 °C ambient temperature unless otherwise specified Rating Symbol Value Unit Power Dissipation at T L = 25 °C PD 5 W Maximum Forward Voltage at I F = 1.0 A VF 1.2 V Thermal Resistance, Junction to Ambient (Note 1) RӨJA 90 °C/W Thermal Resistance, Junction to Lead (Note 1) RӨJL 25 °C/W TJ, TSTG - 65 to + 150 °C Operating and Storage Temperature Range Note : (1) When mounted on FR4 PC board (1 oz Cu) with recommended footprint. ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SMBJ5333B-SMBJ5388B Surface Mount Silicon Zener Diodes ELECTRICAL CHARACTERISTICS Microsemi Part Number Regulator Voltage (VZ) Test Current (IZT) Maximum Dynamic Impedance (ZZ) (A&B Suffix) TYPE SMBJ5333B SMBJ5334B SMBJ5335B SMBJ5336B SMBJ5337B SMBJ5338B SMBJ5339B SMBJ5340B SMBJ5341B SMBJ5342B SMBJ5343B SMBJ5344B SMBJ5345B SMBJ5346B SMBJ5347B SMBJ5348B SMBJ5349B SMBJ5350B SMBJ5351B SMBJ5352B SMBJ5353B SMBJ5354B SMBJ5355B SMBJ5356B SMBJ5357B SMBJ5358B SMBJ5359B SMBJ5360B SMBJ5361B SMBJ5362B SMBJ5363B SMBJ5364B SMBJ5365B SMBJ5366B SMBJ5367B SMBJ5368B SMBJ5369B SMBJ5370B SMBJ5371B SMBJ5372B SMBJ5373B SMBJ5374B SMBJ5375B SMBJ5376B SMBJ5377B SMBJ5378B SMBJ5379B SMBJ5380B SMBJ5381B SMBJ5382B SMBJ5383B SMBJ5384B SMBJ5385B SMBJ5386B SMBJ5387B SMBJ5388B MARKING 333B 334B 335B 336B 337B 338B 339B 340B 341B 342B 343B 344B 345B 346B 347B 348B 349B 350B 351B 352B 353B 354B 355B 356B 357B 358B 359B 360B 361B 362B 363B 364B 365B 366B 367B 368B 369B 370B 371B 372B 373B 374B 375B 376B 377B 378B 379B 380B 381B 382B 383B 384B 385B 386B 387B 388B (Rating at 25 °C ambient temperature unless otherwise specified) Maximum Reverse Current (IR) @ VR IR Test Voltage (VR) (Non-Suffix & A Suffix) IR Test Voltage (VR) Maximum Regulator Current (IZM) Maximum Surge Current (IZSM) (B,C,D Suffix) Maximum Dynamic Knee Impedance Zzk @ 1.0 mA (B,C,D Suffix) (A,B,C,D Suffix) Maximum Voltage Regulation (∆VZ) (A,B,C,D Suffix) V mAdc OHMS µA V V mA OHMS AMPS VOLTS 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.0 6.2 6.8 7.5 8.2 8.7 9.1 10 11 12 13 14 15 16 17 18 19 20 22 24 25 27 28 30 33 36 39 43 47 51 56 60 62 68 75 82 87 91 100 110 120 130 140 150 160 170 180 190 200 380 350 320 290 260 240 220 200 200 175 175 150 150 150 125 125 100 100 100 75 75 70 65 65 65 50 50 50 50 50 40 40 30 30 30 25 25 20 20 20 20 20 15 15 15 12 12 10 10 8.0 8.0 8.0 8.0 5.0 5.0 5.0 3.0 2.5 2.0 2.0 2.0 1.5 1.0 1.0 1.0 1.0 1.5 1.5 2.0 2.0 2.0 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 3.0 3.0 3.5 3.5 4.0 5.0 6.0 8.0 10 11 14 20 25 27 35 40 42 44 45 65 75 75 90 125 170 190 230 330 350 380 430 450 480 300 150 50 10 5.0 1.0 1.0 1.0 1.0 10 10 10 10 7.5 5.0 5.0 2.0 1.0 1.0 1.0 1.0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 1.0 1.0 1.0 1.0 1.0 1.0 2.0 3.0 3.0 4.9 6.4 6.9 6.25 6.6 7.2 8.0 8.6 9.4 10.1 10.8 11.5 12.2 13 13.7 14.4 15.8 17.3 18 19.4 20.1 21.6 23.8 25.9 28.1 31 33.8 36.7 40.3 43 44.6 49 54 59 63 65.5 72 79.2 86.4 93.6 101 108 115 122 130 137 144 1.0 1.0 1.0 1.0 1.0 1.0 2.0 3.0 3.0 5.2 5.7 6.2 6.6 6.9 7.6 8.4 9.1 9.9 10.6 11.5 12.2 12.3 13.7 14.4 15.2 16.7 18.2 19 20.6 21.2 22.8 25.1 27.4 29.7 32.7 35.8 38.8 42.5 45.5 47.1 51.7 56 62.2 66 69.2 76 83.6 91.2 93.8 106 114 122 129 137 144 152 1440 1320 1220 1100 1010 930 865 790 765 700 630 580 545 520 475 430 395 265 340 315 295 280 264 250 237 216 198 190 176 170 158 144 132 122 110 100 93 86 79 76 70 63 58 54.5 52.5 47.5 43 39.5 36.6 34 31.5 29.4 28 26.4 25 23.6 400 500 500 500 450 400 400 300 200 200 200 200 200 150 125 125 125 100 75 75 75 75 75 75 75 75 100 110 120 130 140 150 160 170 190 210 230 280 350 400 500 620 720 760 760 800 1000 1150 1250 1500 1500 1660 1750 1750 1850 1850 20 18.7 17.6 16.4 15.3 14.4 13.4 12.7 12.4 11.5 10.7 10 9.5 9.2 8.6 8.0 7.5 7.0 6.7 6.3 6.0 5.8 5.5 5.3 5.1 4.7 4.4 4.3 4.1 3.9 3.7 3.5 3.3 3.1 2.8 2.7 2.5 2.3 2.2 2.1 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.2 1.1 1.1 1.0 1.0 0.9 0.9 0.85 0.80 0.54 0.49 0.44 0.39 0.25 0.19 0.10 0.15 0.15 0.20 0.20 0.22 0.22 0.25 0.25 0.25 0.25 0.25 0.30 0.35 0.40 0.40 0.40 0.45 0.55 0.55 0.60 0.60 0.60 0.63 0.65 0.65 0.70 0.80 0.90 1.00 1.20 1.35 1.50 1.60 1.80 2.00 2.20 2.30 2.50 2.50 2.50 2.50 3.00 3.00 3.00 4.00 5.00 5.00 Notes : (1) Suffix " B " indicates ± 5% tolerance, suffix " A " indicates ± 10% tolerance. (2) The surge current (IZSM) is specified as the maximum peak of a non- recurrent half-sin wave of 8.3 ms duration. (3) Voltage regulation (VZ) is the difference between the voltage measured at 10% and 50% of I ZM ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com SMBJ5333B-SMBJ5388B Surface Mount Silicon Zener Diodes RATING AND CHARACTERISTIC CURVES ( SMBJ5333B - SMBJ5388B ) Fig. 1 POWER DERATING CURVE PD, MAXIMUM DISSIPATION (WATTS) 5.0 4.0 3.0 2.0 1.0 0 0 25 50 75 100 125 150 TL, LEAD TEMPERATURE (°C) Ir, PEAK SURGE CURRENT (AMPS) Fig.2 Maximum Non-Repetitive Surg Current versus Nominal Zener Voltage 40 PW=1 ms* 20 10 PW=8.3 ms* 4 2 1 PW=100 ms* 0.4 PW=1000 ms* 0.2 *SQURE WAVE 0.1 3 4 6 8 10 20 30 40 80 100 200 NORMINAL Vz (V) PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMB 3000/REEL 48000 36X35.8X36.5 12.00 11.00 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
SMBJ5355B 价格&库存
很抱歉,暂时无法提供与“SMBJ5355B”相匹配的价格&库存,您可以联系我们找货
SMBJ5355B
    • 5+0.77858
    • 50+0.76040
    • 150+0.74825
    • 500+0.73610
    库存:563
