3SMB5936B
3SMB5936B
    LGE(鲁光)
    DO-214AA(SMB)
3SMB5936B 数据手册
3SMB5913B-3SMB5957B Silicon Zener Diodes VZ : 3.3 - 240 Volts PD : 3. 0Watts SMB (DO-214AA) 5.4 ± 0.15 * Complete Voltage Range 3.3 to 240 Volts * High peak reverse power dissipation * High reliability * Low leakage current 1.1 ± 0.3 4.8 ± 0 . 1 5 Features 0.22 ± 0.07 2.0 ± 0.1 Mechanical Data 2.3 ± 0.2 3.6 ± 0.15 * Case : SMB (DO-214AA) Molded plastic * Epoxy : UL94V-O rate flame retardant * Lead : Lead formed for Surface mount * Polarity : Color band denotes cathode end * Mounting position : Any * Weight : 0.093 gram Dimensions in millimeter MAXIMUM RATINGS Rating at 25 °C ambient temperature unless otherwise specified Rating Symbol Value Unit DC Power Dissipation at T L = 75 °C (Note1) PD 3.0 Watts Maximum Forward Voltage at IF = 200 mA VF 1.5 Volts Junction Temperature Range TJ - 55 to + 150 °C Storage Temperature Range Ts - 55 to + 150 °C Note : 2 (1) TL = Lead temperature at 5.0 mm ( 0.013 mm thick ) copper land areas. Revision:20181026-P1 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com 3SMB5913B-3SMB5957B Silicon Zener Diodes ELECTRICAL CHARACTERISTICS Rating at = 25 °C ambient temperature unless otherwise specified TYPE Nominal Zener Voltage V Z @ I ZT IZT (V) (mA) Z ZT @ I ZT (Ω ) Maximum Zener Impedance Z ZK @ I ZK (Ω ) IZK (mA) Maximum Reverse Leakage Current IR @ V R (V) (µA) Maximum DC Zener Current IZM (mA) 3SMB5913B 3.3 113.6 10 500 1.0 100 1.0 454 3SMB5914B 3.6 104.2 9.0 500 1.0 75 1.0 416 3SMB5915B 3.9 96.1 7.5 500 1.0 25 1.0 384 3SMB5916B 4.3 87.2 6.0 500 1.0 5.0 1.0 348 3SMB5917B 4.7 79.8 5.0 500 1.0 5.0 1.5 319 3SMB5918B 5.1 73.5 4.0 500 1.0 5.0 2.0 294 3SMB5919B 5.6 66.9 2.0 250 1.0 5.0 3.0 267 3SMB5920B 6.2 60.5 2.0 200 1.0 5.0 4.0 241 3SMB5921B 6.8 55.1 2.5 200 1.0 5.0 5.2 220 3SMB5922B 7.5 50.0 3.0 400 0.5 5.0 6.0 200 3SMB5923B 8.2 45.7 3.5 400 0.5 5.0 6.5 182 3SMB5924B 9.1 41.2 4.0 500 0.5 5.0 7.0 164 3SMB5925B 10 37.5 4.5 500 0.25 5.0 8.0 150 3SMB5926B 11 34.1 5.5 550 0.25 1.0 8.4 136 3SMB5927B 12 31.2 6.5 550 0.25 1.0 9.1 125 3SMB5928B 13 28.8 7.0 550 0.25 1.0 9.9 115 3SMB5929B 15 25.0 9.0 600 0.25 1.0 11.4 100 3SMB5930B 16 23.4 10 600 0.25 1.0 12.2 93 3SMB5931B 18 20.8 12 650 0.25 1.0 13.7 83 3SMB5932B 20 18.7 14 650 0.25 1.0 15.2 75 3SMB5933B 22 17.0 17.5 650 0.25 1.0 16.7 68 3SMB5934B 24 15.6 19 700 0.25 1.0 18.2 62 3SMB5935B 27 13.9 23 700 0.25 1.0 20.6 55 3SMB5936B 30 12.5 28 750 0.25 1.0 22.8 50 3SMB5937B 33 11.4 33 800 0.25 1.0 25.1 45 3SMB5938B 36 10.4 38 850 0.25 1.0 27.4 41 3SMB5939B 39 9.6 45 900 0.25 1.0 29.7 38 3SMB5940B 43 8.7 53 950 0.25 1.0 32.7 34 3SMB5941B 47 8.0 67 1000 0.25 1.0 35.8 31 3SMB5942B 51 7.3 70 1100 0.25 1.0 38.8 29 3SMB5943B 56 6.7 86 1300 0.25 1.0 42.6 26 3SMB5944B 62 6.0 100 1500 0.25 1.0 47.1 24 3SMB5945B 68 5.5 120 1700 0.25 1.0 51.7 22 3SMB5946B 75 5.0 140 2000 0.25 1.0 56.0 20 3SMB5947B 82 4.6 160 2500 0.25 1.0 62.2 18 3SMB5948B 91 4.1 200 3000 0.25 1.0 69.2 16 3SMB5949B 100 3.7 250 3100 0.25 1.0 76.0 15 3SMB5950B 110 3.4 300 4000 0.25 1.0 83.6 13 3SMB5951B 120 3.1 380 4500 0.25 1.0 91.2 12 3SMB5952B 130 2.9 450 5000 0.25 1.0 98.8 11 3SMB5953B 150 2.5 600 6000 0.25 1.0 114.0 10 3SMB5954B 160 2.3 700 6500 0.25 1.0 121.6 9.0 3SMB5955B 180 2.1 900 7000 0.25 1.0 136.8 8.0 3SMB5956B 200 1.9 1200 8000 0.25 1.0 152.0 7.0 3SMB5957B 240 1.5 1600 9000 0.25 1.0 182.4 6.0 Note : ( 1 ) Suffix " A " indicates ± 10% tolerance, suffix " B " indicates ± 5.0% tolerance. Revision:20181026-P2 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com 3SMB5913B-3SMB5957B Silicon Zener Diodes RATING AND CHARACTERISTICS CURVES 5 Note 5 4 TL 3 2 1 TA 0 0 100 125 50 25 75 TA, AMBIENT TEMPERATURE ( °C) Figure Power Dissipation vs. Ambient Temperature 100 IZ , ZENER CURRENT (mA) TC of VZ , TEMPERATURE COEFFICIENT OF ZENER VOLTAGE (mV/°C) 250 6.2V 10 13V 15V 39V 1 0.1 0 200 150 100 50 0 0 150 20 30 40 50 VZ , ZENER VOLTAGE (V) Figure 3 Typical Zener Breakdown Characteristics 100 IZ , ZENER CURRENT (mA) PD, MAXIMUM POWER DISSIPATION (W) 6 50 100 150 VZ , ZENER VOLTAGE (V) Figure 2 Typical Temperature Coefficient of Zener Voltage vs. Zener Voltage 200 200V 10 1 0.1 50 200 250 150 VZ , ZENER VOLTAGE (V) Figure 4 Typical Zener Breakdown Characteristics 10 100 1000 ZZ, DYNAMIC IMPEDANCE (Ω) 200V 100 3.3V 13V 10 6.2V 1 0.1 Revision:20181026-P3 ht t p : // 1 10 100 IZ , ZENER TEST CURRENT (mA) Figure 6 Effect of Zener Current www.lgesem i .c o m 1000 mail:lge@lgesemi.com 3SMB5913B-3SMB5957B Silicon Zener Diodes RATING AND CHARACTERISTICS CURVES 1800 CT, TOTAL CAPACITANCE (pF) 1400 1200 1000 800 V R = 0V 600 400 V R = VZ /2 200 0 100 1000 1 10 V Z, NOMINAL ZENER BREAKDOWN VOLTAGE (V) Figure 7 Typical Total Capacitance vs. Nominal Zener Breakdown Voltage I PP, PEAK PULSE CURRENT (%Ip p) f = 1MHz 1600 100 Peak Value I pp Half Value I pp /2 50 tp 0 8x20 Waveform as defined by R.E.A. 0 40 t, TIME ( µ s) Figure 8 Pulse Waveform 60 0.01 0.1 1 td , PULSE DURATION (ms) Figure 10 Max. Peak Pulse Power vs. Pulse Duration 10 20 100 Pe a k Va lu e pp I H a lf Va lu e pp I /2 50 tp 0 Revision:20181026-P4 P PK, PEAK PULSE POWER (kW) IP, PEAK PULSE CURRENT (%Ip p) 10 0 1 0 X 1 0 0 0 Wa ve fo rm a s d e fin e d b y R .E.A. 1 1 0.1 0.01 3 2 t, TIME (ms) Figure 9 Pulse Waveform PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMB 3000/REEL 48000 36X35.8X36.5 12.00 11.00 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com 3SMB5913B-3SMB5957B Silicon Zener Diodes SOLDERING PARAMETERS Lead–free assembly Reflow Condition Pre Heat - Temperature Min (Ts(min)) 150°C - Temperature Max (Ts(max)) 200°C - Time (min to max) (ts) 60 – 180 secs Average ramp up rate (Liquidus Temp (TA) to peak 3°C/second max TS(max) to TA - Ramp-up Rate 3°C/second max Reflow 217°C - Temperature (TA) (Liquidus) 60 – 150 seconds - Time (min to max) (ts) Peak Temperature (TP) 260+0/-5 °C Time within 5°C of actual peak Temperature (tp) 20 – 40 seconds Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Do not exceed 260°C tp TP Ramp-up Temperature (T) TL tL Critical Zone TL to TP Ts(max) Ts(min) Ramp-down ts Preheat 25˚C t 25˚C to Peak Time (t) MOUNTING PAD LAYOUT 0.085 (2.159) MAX. 0.086 (2.18) MIN. 0.060 (1.52) MIN. 0.220 (5.59) REF. Revision:20181026-P5 ht t p : // www.lgesem i .c o m mail:lge@lgesemi.com
3SMB5936B 价格&库存
很抱歉,暂时无法提供与“3SMB5936B”相匹配的价格&库存,您可以联系我们找货
3SMB5936B
    • 5+0.89500
    • 50+0.78160
    • 150+0.73300
    • 500+0.67230
    • 3000+0.64530
    • 6000+0.62910
    库存:2656
