SS510B
SS510B
    HONGJIACHENG(宏嘉诚)
    DO-214AA(SMB)
SS510B 数据手册
� �D� 宏迦橙 SS52B THRU SS520B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Features DO-214AA(SMB) •Low profile package •Ideal for automated placement •Guardring for overvoltage protection •Low power losses, high efficiency •Meets MSL level 1, per J-STD-020, LF maximum peak of 260℃ Applications For use in low voltage high frequency inverters, freewheeling,DC/DC converters, and polarity protection applications. Mechanical Data •Case: DO-214AA(SMB) Molding compound meets UL 94V-0 flammability rating, RoHS-compliant, halogen-free •Terminals: Solder plated, solderable per MIL-STD-750,Method 2026 •Polarity: Cathode line denotes the cathode end Maximum Ratings (Ta=25℃ Unless otherwise specified) PARAMETER SYMBOL UNIT Device marking code Maximum Repetitive Peak Reverse Voltage VRRM V Maximum DC blocking Voltage VDC V Maximum RMS Voltage Average rectified output current @60Hz sinewave, Resistance load,TL (Fig.1) Forward Surge Current (Nonrepetitive) @60HzHalf-sine wave,1 cycle, T=25℃ Storage temperature Junction temperature VRMS Typical Thermal Resistance A Tstg ℃ RθJ-A ℃ /W IFSM RθJ-L SS52B SS53B SS54B SS55B SS56B SS58B SS510B SS515B SS520B V IF(AV) Tj SS52B SS53B SS54B SS55B SS56B SS58B SS510B SS515B SS520B 20 30 40 50 60 80 100 150 200 20 30 40 50 60 80 100 150 200 14 21 28 35 A Maximum instantaneous forward voltage Revision:GPD-May.2023-A0 70 105 140 ℃ -55 ~ +125 ℃ /W -55 ~ +150 -55 ~ +150 60 22 TEST CONDITIONS SYMBOL UNIT SS52B SS53B SS54B SS55B SS56B SS58B SS510B SS515B SS520B IF=5.0A Maximum DC reverse currentat VRM=VRRM rated DC blocking voltage Typical junction capacitance 5 56 120 Electrical Characteristics (Ta=25℃ Unless otherwise specified) PARAMETER 42 VA=25℃ VA=100℃ 4.0V DC,1MHz VF V 0.55 IR mA CJ pF 1 of 3 0.2 10 Zhuhai Hongjiacheng Technology co., Ltd 0.70 0.85 300 0.05 0.95 5 www.ichjc.com � �D� 宏迦橙 SS52B THRU SS520B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ratings And Characteristics Curves (Ta=25℃ Unless otherwise specified) 160 4.0 120 100 3.0 80 2.0 60 40 1.0 0 20 40 0 80 LEADTEMPERATURE(℃) 120 0 160 Fig. 1 Forward Current Derating Curve 100 10 100 NUMBEROFCYCLES 100 Tj=25℃ Pulsewidth=300us 1%DutyCycle SS52B-SS56B SS58B-SS520B 10 INSTANTANEOUSREVERSECURRENT(mA)  LNSTANTANEOUSFORWARDCURRENT(A) 1 Fig.2 Maximum Non-Repetitive Peak Forward Surge Current 10 Tj=100℃ 1.0 1.0 0.1 1.0 0.1 8.3msSingleHalfSineWave (JEDECMethod) 140 PEAKFORWARDSURGECURRENT(A) AVERAGERECTIFIELDOUTPUTCURRENT(A) 5.0 0 0.2 0.4 0.6 0.8 1.0 SS52B-SS54B SS55B-SS56B SS58B-SS510B SS515B-SS520B INSTANTANEOUSFORWARDVOLTAGE(V) 1.2 0.01 0.001 1.4 Fig.3 Typical Forward Voltage Revision:GPD-May.2023-A0 Tj=25℃ 0 20 40 60 80 PERCENTOFRATEDPEAKREVERSEVOLTAGE(%) 100 Fig.4 Typical Reverse Characteristics 2 of 3 Zhuhai Hongjiacheng Technology co., Ltd www.ichjc.com � �D� 宏迦橙 SS52B THRU SS520B SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER www.ichjc.com Ordering Information PACKAGE PACKAGE CODE UNIT WEIGHT(g) REEL(pcs) BOX(pcs) CARTON(pcs) DELIVERY MODE SMB R3 0.098 3000 / 48000 13'' Package Outline Dimensions (SMB/DO-214AA) Symbol A C A B B C H D E D E F F G G H Suggested Pad Layout J K J Symbol M M J K Revision:GPD-May.2023-A0 3 of 3 Dimensions Millimeters Min. Max. 4.25 4.85 1.85 3.30 2.15 0.75 0.073 0.087 3.94 0.130 0.155 2.65 1.52 0.203 0.15 0.31 5.59 Min. Max. 2.10 - - Zhuhai Hongjiacheng Technology co., Ltd 0.167 0.191 0.085 0.104 0.030 0.060 - 0.008 0.200 0.220 0.006 Dimensions Millimeters 2.26 Max. 2.21 - 5.08 Min. Inches Min. - 0.089 2.74 - 0.085 0.012 Inches Max. - 0.107 www.ichjc.com
SS510B 价格&库存
很抱歉,暂时无法提供与“SS510B”相匹配的价格&库存,您可以联系我们找货
SS510B
    • 10+0.30899
    • 100+0.26147
    • 300+0.23760
    • 3000+0.19916
    • 6000+0.18490
    • 9000+0.17777
    库存:41837
