1SMB3EZ3.9 - 1SMB3EZ400
SURFACE MOUNT SILICON ZENER DIODES
VOLTAGE RANGE: 3.9 - 400V
POWER: 3.0Wa t t s
Features
Complete Voltage Range 3.9 to 400 Volts
High peak reverse power dissipation
High reliability
Low leakage current
B
SMB(DO-214AA)
Dim
Mechanical Data
A
Case: SMB/DO-214AA, Molded Plastic
Terminals: Solder Plated, Solderable
per MIL-STD-750, Method 2026
Polarity: Cathode Band or Cathode Notch
Marking: Type Number
Weight: 0.093 grams (approx.)
C
D
J
H
G
E
Min
Max
A
3.30
3.94
B
4.06
4.70
C
1.91
2.21
D
0.15
0.31
E
5.00
5.59
G
0.10
0.20
H
0.76
1.52
J
2.00
2.62
All Dimensions in mm
Maximum Ratings TA = 25C unless otherwise specified
Rating
Symbol
Value
Unit
DC Power Dissipation at TL = 75 °C (Note1)
PD
3.0
Watts
Maximum Forward Voltage at IF = 200 mA
VF
1.5
Volts
RθJA
60
K/W
Junction Temperature Range
TJ
- 55 to + 175
°C
Storage Temperature Range
Ts
- 55 to + 175
°C
Maximum Thermal Resistance Junction to Ambient Air (Note2)
Note :
(1) TL = Lead temperature at 3/8 " (9.5mm) from body
(2) Valid provided that leads are kept at ambient temperature at a distance of 10 mm from case.
1 of 3
www.sunmate.tw
ELECTRICAL CHARACTERISTICS
TYPE
Nominal Zener
Voltage
VZ @ IZT
IZT
(V)
(mA)
Rating at = 25 ° C ambient temperature unless otherwise specified
ZZT @ IZT
(Ω)
Maximum Zener
Impedance
ZZK @ IZK
(Ω)
IZK
(mA)
Maximum Reverse
Leakage Current
IR @ VR
(V)
(µ A)
Maximum DC
Zener Current
IZM
(mA)
1SMB3EZ3.9
3.9
192
4.5
400
1.0
80
1.0
630
1SMB3EZ4.3
4.3
174
4.5
400
1.0
30
1.0
590
1SMB3EZ4.7
4.7
160
4.0
500
1.0
550
1SMB3EZ5.1
5.1
147
3.5
550
1.0
5.0
1.0
520
1SMB3EZ5.6
5.6
134
2.5
600
1.0
5.0
2.0
480
1SMB3EZ6.2
6.2
121
1.5
700
1.0
5.0
3.0
435
1SMB3EZ6.8
6.8
110
2.0
700
1.0
50
4.0
393
1SMB3EZ7.5
7.5
100
2.0
700
0.5
50
5.0
360
1SMB3EZ8.2
8.2
91
2.3
700
0.5
50
6.0
330
1SMB3EZ9.1
9.1
82
2.5
700
0.5
50
7.0
297
1SMB3EZ10
10
75
3.5
700
0.3
50
7.6
270
1SMB3EZ11
11
68
4.0
700
0.25
50
8.4
225
1SMB3EZ12
12
63
4.5
700
0.25
1.0
9.1
246
1SMB3EZ13
13
58
4.5
700
0.25
0.5
9.1
208
1SMB3EZ14
14
53
5.0
700
0.25
0.5
10.6
193
1SMB3EZ15
15
50
5.5
700
0.25
0.5
11.4
180
1SMB3EZ16
16
47
5.5
700
0.25
0.5
12.2
169
1SMB3EZ17
17
44
6.0
750
0.25
0.5
13.0
159
1SMB3EZ18
18
42
6.0
750
0.25
0.5
13.7
150
1SMB3EZ19
19
40
7.0
750
0.25
0.5
14.4
142
1SMB3EZ20
7.0
750
0.25
0.5
15.2
135
1SMB3EZ22
22
34
8.0
750
0.25
0.5
16.7
123
1SMB3EZ24
24
31
9.0
750
0.25
0.5
18.2
112
1SMB3EZ27
27
28
10
750
0.25
0.5
20.6
100
1SMB3EZ28
28
27
12
750
0.25
0.5
21.0
96
1SMB3EZ30
30
25
16
1000
0.25
0.5
22.5
90
1SMB3EZ33
33
23
0.25
0.5
25.1
82
1SMB3EZ36
36
21
22
1000
0.25
0.5
27.4
75
1SMB3EZ39
39
19
28
1000
0.25
0.5
29.7
69
1SMB3EZ43
43
17
33
1500
0.25
0.5
32.7
60
1SMB3EZ47
47
16
38
1500
0.25
0.5
35.6
57
1SMB3EZ51
51
15
45
1500
0.25
0.5
38.8
53
1SMB3EZ56
56
13
50
2000
0.25
0.5
42.6
48
1SMB3EZ62
62
12
55
2000
0.25
0.5
47.1
44
1SMB3EZ68
68
11
70
2000
0.25
0.5
51.7
40
1SMB3EZ75
75
10
85
2000
0.25
0.5
56.0
36
1SMB3EZ82
82
9.1
95
3000
0.25
0.5
62.2
33
1SMB3EZ91
91
8.2
115
3000
0.25
0.5
69.2
30
1SMB3EZ100
100
7.5
160
3000
0.25
0.5
76.0
27
2 of 3
www.sunmate.tw
TYPE
1SMB3EZ110
Nominal Zener
Voltage
VZ @ IZT
IZT
(V)
(mA)
110
6.8
ZZT @ IZT
(Ω)
Maximum Zener
Impedance
ZZK @ IZK
(Ω)
IZK
(mA)
Maximum Reverse
Leakage Current
IR @ VR
(V)
(µ A)
225
4000
0.25
0.5
83.6
Maximum DC
Zener Current
IZM
(mA)
25
1SMB3EZ120
120
6.3
300
4500
0.25
0.5
91.2
22
1SMB3EZ130
130
5.8
375
5000
0.25
0.5
98.8
21
1SMB3EZ140
140
5.3
475
5000
0.25
0.5
106.4
19
1SMB3EZ150
150
5.0
550
6000
0.25
0.5
114.0
18
1SMB3EZ160
160
4.7
625
6500
0.25
0.5
121.6
17
1SMB3EZ170
170
4.4
650
7000
0.25
0.5
130.4
16
1SMB3EZ180
180
4.2
700
7000
0.25
0.5
136.8
15
1SMB3EZ190
190
4.0
800
8000
0.25
0.5
144.8
14
1SMB3EZ200
200
3.7
875
8000
0.25
0.5
152.0
13
1SMB3EZ220
220
3.4
1600
9000
0.25
1
167.0
12
1SMB3EZ240
240
3.1
1700
9000
0.25
1
182.0
11
1SMB3EZ270
270
2.8
1800
9000
0.25
1
205.0
10
1SMB3EZ300
300
2.5
1900
9000
0.25
1
228.0
9
1SMB3EZ330
330
2.3
2200
9000
0.25
1
251.0
8
1SMB3EZ360
360
2.1
2700
9000
0.25
1
274.0
8
1SMB3EZ400
400
1.9
3500
9000
0.25
1
304.0
7
3 of 3
www.sunmate.tw
很抱歉,暂时无法提供与“1SMB3EZ4.7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.77751
- 50+0.63387
- 150+0.56205
- 500+0.48664
- 2500+0.44355
- 5000+0.42199
