SS515B
SS515B
    ELECSUPER(静芯微)
    DO-214AA(SMB)
SS515B 数据手册
MMSZ52xxB SERIES Rev-1.1 www.elecsuper.com SuperDiode – SOD-123 Plastic-Encapsulate Zener Diode 1. Features 2. Mechanical Data ⚫ Low zener impedance ⚫ SOD-123 Small Outline Plastic Package ⚫ Power dissipation of 500mW ⚫ Polarity: Color band denotes cathode end ⚫ High stability and high reliability ⚫ Mounting Position: Any 3. Marking and Circuit Marking 1 Circuit 2 1 Marking 2 4. Specification Absolute Maximum Rating & Thermal Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Parameters Symbol Value Unit Forward voltage @IF=10mA VF 0.9 2) V Power dissipation PD 500 1) mW Thermal Resistance, Junction-to-Ambient RθJA 340 3) ℃/W Thermal Resistance, Junction-to-Lead RθJL 150 3) ℃/W TS -65~150 ℃ Storage temperature range 1) Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm² 2) Short duration test pulse used to minimize self-heating effect 3) Thermal Resistance measurement obtained via infrared Scan Method. 4) f=1KHz Copyright© ElecSuper Incorporated Contact Us 1 / 5 MMSZ52xxB SERIES Rev-1.1 Electrical Characteristics (At TA = 25℃ unless otherwise specified) Vz1(@Izt) Part Number Marking www.elecsuper.com Zzt@Izt Zzk IR Min Max Izt Max Max Izk Max VR (V) (V) mA Ω Ω mA uA V MMSZ5221B C1 2.28 2.52 20 30 1200 0.25 100 1 MMSZ5222B C2 2.38 2.63 20 30 1250 0.25 100 1 MMSZ5223B C3 2.57 2.84 20 30 1300 0.25 75 1 MMSZ5224B C4 2.66 2.94 20 30 1400 0.25 75 1 MMSZ5225B C5 2.85 3.15 20 30 1600 0.25 50 1 MMSZ5226B G1 3.14 3.47 20 28 1600 0.25 25 1 MMSZ5227B G2 3.42 3.78 20 24 1700 0.25 15 1 MMSZ5228B G3 3.71 4.1 20 23 1900 0.25 10 1 MMSZ5229B G4 4.09 4.52 20 22 2000 0.25 5 1 MMSZ5230B G5 4.47 4.94 20 19 1900 0.25 5 2 MMSZ5231B E1 4.85 5.36 20 17 1600 0.25 5 2 MMSZ5232B E2 5.32 5.88 20 11 1600 0.25 5 3 MMSZ5233B E3 5.7 6.3 20 7 1600 0.25 5 3.5 MMSZ5234B E4 5.89 6.51 20 7 1000 0.25 5 4 MMSZ5235B E5 6.46 7.14 20 5 750 0.25 3 5 MMSZ5236B F1 7.13 7.88 20 6 500 0.25 3 6 MMSZ5237B F2 7.79 8.61 20 8 500 0.25 3 6.5 MMSZ5238B F3 8.27 9.14 20 8 600 0.25 3 6.5 MMSZ5239B F4 8.65 9.56 20 10 600 0.25 3 7 MMSZ5240B F5 9.5 10.5 20 17 600 0.25 3 8 MMSZ5241B H1 10.45 11.55 20 22 600 0.25 2 8.4 MMSZ5242B H2 11.4 12.6 20 30 600 0.25 1 9.1 MMSZ5243B H3 12.35 13.65 9.5 13 600 0.25 0.5 9.9 MMSZ5244B H4 13.3 14.7 9 15 600 0.25 0.1 10 MMSZ5245B H5 14.25 15.75 8.5 16 600 0.25 0.1 11 MMSZ5246B J1 15.2 16.8 7.8 17 600 0.25 0.1 12 MMSZ5247B J2 16.15 17.85 7.5 19 600 0.25 0.1 13 MMSZ5248B J3 17.1 18.9 7 21 600 0.25 0.1 14 MMSZ5249B J4 18.05 19.95 6.6 23 600 0.25 0.1 14 MMSZ5250B J5 19 21 6.2 25 600 0.25 0.1 15 MMSZ5251B K1 20.9 23.1 5.6 29 600 0.25 0.1 17 MMSZ5252B K2 22.8 25.2 5.2 33 600 0.25 0.1 18 MMSZ5253B K3 23.75 26.25 5 35 600 0.25 0.1 19 MMSZ5254B K4 25.65 28.35 5 41 600 0.25 0.1 21 MMSZ5255B K5 26.6 29.4 4.5 44 600 0.25 0.1 21 MMSZ5256B M1 28.5 31.5 4.2 49 600 0.25 0.1 23 Copyright© ElecSuper Incorporated Contact Us 2 / 5 MMSZ52xxB SERIES Rev-1.1 Vz1(@Izt) Part Number Marking www.elecsuper.com Zzt@Izt Zzk IR Min Max Izt Max Max Izk Max VR (V) (V) mA Ω Ω mA uA V MMSZ5257B M2 31.35 34.65 3.8 58 700 0.25 0.1 25 MMSZ5258B M3 34.2 37.8 3.4 70 700 0.25 0.1 27 MMSZ5259B M4 37.05 40.95 3.2 80 800 0.25 0.1 30 MMSZ5260B M5 40.85 45.15 3 93 900 0.25 0.1 33 MMSZ5261B N1 44.65 49.35 2.7 105 1000 0.25 0.1 36 MMSZ5262B N2 48.45 53.55 2.5 125 1100 0.25 0.1 39 MMSZ5263B N3 53.2 58.8 2.2 150 1300 0.25 0.1 43 MMSZ5264B N4 57 63 2.1 170 1400 0.25 0.1 46 MMSZ5265B N5 58.9 65.1 2 185 1400 0.25 0.1 47 MMSZ5266B P1 64.6 71.4 1.8 230 1600 0.25 0.1 52 MMSZ5267B P2 71.25 78.75 1.7 270 1700 0.25 0.1 56 5. Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 3 / 5 MMSZ52xxB SERIES Rev-1.1 www.elecsuper.com 6. Dimension and Patterns (SOD-123) A2 E A b D E1 c A1 Symbol A A1 A2 b c D L1 Min. 1.05 0.00 1.05 0.45 0.08 1.50 L Max. 1.25 0.10 1.15 0.65 0.15 1.70 θ Symbol E E1 L L1 θ Units: mm Max. 2.80 3.85 Min. 2.60 3.55 0.50REF 0.25 0° 0.45 8° Note: 1. Controlling dimension: in millimeters 2. General tolerance: ±0.05mm 3. The pad layout is for reference only 4. Unit: mm Copyright© ElecSuper Incorporated Contact Us 4 / 5 MMSZ52xxB SERIES Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 5 / 5
SS515B 价格&库存
很抱歉,暂时无法提供与“SS515B”相匹配的价格&库存,您可以联系我们找货
SS515B
    • 1+0.53255
    • 10+0.42866
    • 30+0.37671
    • 100+0.33772
    • 500+0.30651
    • 1000+0.29096
    库存:2277
