SS310
SS310
    ELECSUPER(静芯微)
    DO-214AA(SMB)
SS310 数据手册
SS32 THRU SS310 Rev-1.1 www.elecsuper.com SuperDiode – 3A, 20~100V Surface Mount Schottky Barrier Rectifier 1. Features 2. Mechanical Data  Flammability Classification 94V-0  Built-in strain relief, ideal for automated  Case: JEDEC DO-214AA/SMB molded plastic body placement  Terminals: Solderable per MIL-STD-750,  High forward surge current capability Method 2026  High temperature soldering guaranteed:  Polarity: Color band denotes cathode end 250 ℃/10 seconds at terminals  Mounting Position: Any 3. Marking and Circuit Marking Circuit Marking 1 2 4. Specification Absolute Maximum Rating & Electrical Characteristics Ratings at 25 ℃ ambient temperature unless otherwise specified. Single phase half-wave 60Hz, resistive or inductive load, for capacitive load current derate by 20%. Parameters Symbols SS32 SS33 SS34 SS35 SS36 SS38 SS310 Unit Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 80 100 V Maximum RMS voltage VRMS 14 21 28 35 42 56 70 V Maximum DC blocking voltage VDC 20 30 40 50 60 80 100 V Maximum average forward rectified current at TL(Fig1) I(AV) 3.0 A IFSM 100.0 A Peak forward surge current 8.3ms single half sine-wave superimposed on rated load Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current at rated DC TA=25℃ blocking voltage TA=100℃ Typical junction capacitance (NOTE 1) VF 0.55 20 CJ 10 500 RθJA Operating junction temperature range TJ Copyright© ElecSuper Incorporated 0.85 0.5 IR Typical thermal resistance (NOTE 2) Storage temperature range 0.70 300 TSTG Contact Us ℃/W -50 ~ 150 -50 ~ 150 mA pF 55.0 -50 ~ 125 V ℃ ℃ 1 / 4 SS32 THRU SS310 Rev-1.1 www.elecsuper.com Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.PCB mounted on 0.2*0.2" (5.0*5.0mm) copper pad area. 5. Typical Characteristic Copyright© ElecSuper Incorporated Contact Us 2 / 4 SS32 THRU SS310 Rev-1.1 www.elecsuper.com 6. Dimension (DO-214AA/SMB) Dimensions in inches and (millimeters) Copyright© ElecSuper Incorporated Contact Us 3 / 4 SS32 THRU SS310 Rev-1.1 www.elecsuper.com DISCLAIMER ELECSUPER PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN RESOURCES (INCLUDING REFERENCE DESIGNS), APPLICATION OR OTHER DESIGN ADVICE, SAFETY INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES, EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY RIGHTS. These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for (1) selecting the appropriate ElecSuper products for your application; (2) designing, validating and testing your application; (3) ensuring your application meets applicable standards, and any other safety, security, or other requirements. These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products. Copyright© ElecSuper Incorporated Contact Us 4 / 4
SS310 价格&库存
很抱歉,暂时无法提供与“SS310”相匹配的价格&库存,您可以联系我们找货
SS310
    • 20+0.13965
    • 200+0.12021
    • 600+0.10941
    • 3000+0.10617
    • 9000+0.10055
    • 21000+0.09753
    库存:761
