www.msksemi.com
S3AB THRU S3MB
Semiconductor
Compiance
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
FEATURES
3.0 Ampere
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.093 grams
SMB
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
P/N(MARK)
S3AB
S3BB
S3DB
S3GB
S3JB
S3KB
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
S3MB
UNITS
1000
700
1000
V
V
V
At TL=75 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
3.0
A
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 3.0A
Maximum DC Reverse Current
Ta=25 C
100
1.10
5.0
A
V
A
at Rated DC Blocking Voltage
Ta=125 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJL (Note 2)
Operating and Storage Temperature Range TJ, TSTG
250
A
pF
C/W
C
60
13
-65
+150
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
www.msksemi.com
S3AB THRU S3MB
Semiconductor
Compiance
RATING AND CHARACTERISTIC CURVES (S3AB THRU S3MB)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
2.5
2.0
Single Phase
1.5
Half Wave 60Hz
Resistive Or Inductive Load
1.0
0.375"(9.5mm) Lead Length
0.5
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE,( C)
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
.01
.6
.7
.8
.9
1.0
1.1
1.2
1.3
FORWARD VOLTAGE,(V)
FIG.3 - TYPICAL REVERSE
CHARACTERISTICS
PEAK FORWARD SURGE CURRENT,(A)
INSTANTANEOUS FORWARD CURRENT,(A)
50
3.0
100
80
60
8.3ms Single Half
Tj=25 C
Sine Wave
40
JEDEC method
100
5
50
10
100
NUMBER OF CYCLES AT 60Hz
FIG.5-TYPICAL JUNCTION CAPACITANCE
140
Tj=100 C
JUNCTION CAPACITANCE,(pF)
REVERSE LEAKAGE CURRENT, ( A)
10
1.0
Tj=25 C
.1
120
100
80
60
40
60
80
.01
.05
.1
.5
1
5
10
50
100
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
REVERSE VOLTAGE,(V)
www.msksemi.com
S3AB THRU S3MB
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
A
Dimensions
B
C
Ref.
H
F
G
D
E
L
J
K
Millimeters
Min.
Max.
Min.
Max.
A
4.25
4.75
0.167
0.187
B
3.30
3.94
0.130
0.155
C
1.85
2.21
0.073
0.087
D
0.76
1.52
0.030
0.060
E
5.08
5.59
0.200
0.220
F
0.051
0.203
0.002
0.008
G
0.15
0.31
0.006
0.012
H
2.11
2.44
0.083
0.096
J
6.80
L
0.270
2.60
K
DO-214AA (SMB)
Inches
2.40
0.100
0.090
REEL SPECIFICATION
P/N
S3AB THRU S3MB
PKG
QTY
SMB
3000
www.msksemi.com
S3AB THRU S3MB
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities concerned in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property
rights or other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“S3MB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10858
- 500+0.08671
- 3000+0.07456
- 6000+0.06727
- 24000+0.06095
- 51000+0.05755
