SS210(SMB)
SS210(SMB)
    TWGMC(台湾迪嘉)
    DO-214AA(SMB)
    二极管配置:独立式 直流反向耐压(Vr):100V 平均整流电流(Io):2A 正向压降(Vf):850mV@2A
SS210(SMB) 数据手册
SS22 Forward THRU SS220 Current - 2.0 Ampere Reverse Voltage - 20 to 200 Volts PINNING Features PIN DESCRIPTION 1 Cathode  Metal silicon junction, majority carrier conduction 2 Anode  For surface mounted applications  Low power loss, high efficiency  High forward surge current capability  For use in low voltage, high frequency inverters , free wheeling, and polarity protection applications DO-214AA/SMB 2 1 MECHANICAL DATA  Case: SMB  Terminals: Solderable per MIL-STD-750, Method 2026  Approx. Weight: 60mg / 0.0021oz Unipolar Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Parameter Symbols SS22 SS24 SS26 SS28 SS210 SS212 SS2150 SS220 Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM A 2.0 55 45 A Max Instantaneous Forward Voltage at 2 A VF Maximum DC Reverse Current T a = 25°C T a =100°C IR 0.5 5 0.3 3 mA Typical Junction Capacitance(1) Cj 220 110 pF Typical Thermal Resistance (2) RθJA 60 °C/W Tj -55 ~ +125 °C T stg -55 ~ +150 °C at Rated DC Reverse Voltage Operating Junction Temperature Range Storage Temperature Range 0.55 0.70 (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. www.tw-gmc.com 1 0.95 0.85 V SS22 Forward THRU SS220 Current - 2.0 Ampere Reverse Voltage - 20 to 200 Volts Typical Characterisitics Fig.2 Typical Reverse Characteristics Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 10 4 T J =75°C 10 2 SS22~SS26 T J =25°C 10 0 0 60 T J =25°C Junction Capacitance ( pF) T J =25°C 20 10 1.0 SS22~SS24 SS26~SS28 SS210~ SS212 SS2150~SS220 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 500 200 100 20 SS2 2~SS26 SS28~SS220 10 1.8 1 0.1 100 10 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance SS22~SS28 SS210~SS220 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 1000 Instaneous Forward Voltage (V) 60 10 100 80 Fig.4 Typical Junction Capacitance Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) SS28~SS220 10 1 Case Temperature (°C) 10 100 Number of Cycles at 60Hz www.tw-gmc.com T J =100°C 10 3 100 10 1 0.01 0.1 1 10 t, Pulse Duration(sec) 2 100 SS22 Forward THRU SS220 Current - 2.0 Ampere Reverse Voltage - 20 to 200 Volts PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMB L A A1 C A b D E E1 VM A SMB mechanical data UNIT mm mil A E D max 2.44 4.70 3.94 min 2.13 4.06 3.3 A1 L C b 5.59 0.20 1.5 0.305 2.2 5.08 0.05 0.8 0.152 1.9 59 12 87 32 6 75 E1 max 96 185 155 220 7.9 min 84 160 130 200 2.0 The recommended mounting pad size 2.4 (94) 2.4 (94) 2.8 (110) 2.2 (86) mm Unit : (mil) www.tw-gmc.com 3
SS210(SMB) 价格&库存
很抱歉,暂时无法提供与“SS210(SMB)”相匹配的价格&库存,您可以联系我们找货
SS210(SMB)
  • 20+0.13357
  • 200+0.10806
  • 600+0.09389
  • 3000+0.08198
  • 9000+0.07460
  • 21000+0.07064
库存:24936
