US2A-US2M
表面安装高效率整流二极管
Surface Mounted High-efficiency Rectifiers
Reverse Voltage 50 ~ 1000 V
Forward Current 2.0 A
反向电压 50 ~ 1000 V
正向电流 2.0 A
特征 Features
DO-214AA/SMB
● 反向漏电流低 Low reverse leakage
● 正向浪涌承受能力强 High forward surge capability
● 高信赖性 High reliability
● 高温焊接保证 High temperature soldering guaranteed:
260℃/10 秒
260℃/10seconds
● 引线和管体皆符合RoHS标准
Lead and body according with RoHS standard
● 型号后缀“-F”标记无卤素产品
Green compound with suffix "-F" on Marking
机械数据 Mechanical Data
● 封装外形:DO-214AA塑封 Case:DO-214AA Molded plastic
● 环氧树脂:UL易燃等级:94V-0
Unit: inch (mm)
Epoxy: UL 94V-0 rate flame retardant
● 引脚:镀锡,无铅 Lead: Pure tin plated, lead free
最大值和特性 TA = 25℃ 除非另有规定。
Maximum Ratings & Characteristics
参数
Parameter
Ratings at 25℃ ambient temperature unless otherwise specified.
符号
US2B
US2D
US2G
US2J
US2K
US2M
VRRM
50
100
200
400
600
800
1000
V
VRMS
35
70
140
280
420
560
700
V
VDC
50
100
200
400
600
800
1000
V
Symbols
最大可重复峰值反向电压
Maximum repetitive peak reverse voltage
最大均方根电压 Maximum RMS voltage
最大直流阻断电压
Maximum DC blocking voltage
最大正向平均整流电流
Maximum average forward rectified current
单位
US2A
Unit
IF(AV)
2.0
A
IFSM
50
A
正向不重复浪涌电流 8.3 ms单一正弦半波
Non-repetitive peak forward surge current
8.3 ms singlehalf sine-wave
最大正向电压 @IF=2.0A
VF
Maximum forward voltage
最大反向电流 @VDC
Maximum reverse current
TA= 25℃
TA= 100℃
最大反向恢复时间 IF=0.5A , IR=1.0A ,IRR=0.25A
MAX. reverse recovery time
典型热阻 Typical thermal resistance (Note 1)
典型结电容 VR=4.0V,f=1MHz
Type junction capacitance
工作结温
Operating junction temperature rang
存储温度
storage temperature rang
1.0
1.3
5
IR
TRR
1.7
μA
100
50
V
75
nS
RθJA
85
℃/W
CJ
42
pF
TJ
-55 --- +150
TSTG
-55 --- +150
备注 Note:
1) 安装在PCB板上,从PN结到周围环境的热阻。
1) Thermal resistance from junction to ambient, PCB mounted.
REV.1.0,2016-12
Changzhou zhide Electronics CO.,LTD
www.cz-zhide.com
US2A-US2M
特性曲线 Characteristic Curves
正向特性曲线(典型值)
正向电流降额曲线
IF(AV) (A)
10
1
0.1
0.01
0.4
0.8
1.2
1.6
IF(A) Average Forward Rectified Current (A)
FORWARD CURRENT DERATING CURVE
平均正向电流
IF Instantaneous Forward Current (A)
正向电流 IF(A)
TYPICAL FORWARD CHARACTERISTIC
2.5
2
1.5
1
0.5
25
50
75
100
125
正向电压 VF(V)
环境温度 Ta(°C)
VF Instantaneous Forward Voltage (V)
Tamb, ambient temperature (°C)
浪涌特性曲线(最大值)
150
175
反向特性曲线
MAXIMUM NON REPETITIVE
TYPICAL REVERSE CHARACTERISTICS
PEAK FORWARD SURGE CURRENT
10
40
30
Reverse Current(uA)
50
反向电流IR(uA)
IFSM Peak Forward Surge Current (A)
峰值正向浪涌电流 IFSM(A)
60
1
0.1
10
Tj=25℃
Tj=25℃
1
10
100
0%
20%
40%
60%
80%
通过电流的周期
额定峰值反向电压%
Number of Cycles at 60 Hz.
Percent Of Rated Peak Reverse voltage %
REV.1.0,2016-12
100%
www.cz-zhide.com
很抱歉,暂时无法提供与“US2M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.11820
- 100+0.11554
- 300+0.11379
- 1000+0.11204
