S2A-S2M
GENERAL PURPOSE RECTIFIER DIODE
FEATURES
Glass passivated junction
Low reverse leakage current
Low forward voltage drop
High current capability
Surface Mount device
MECHANICAL DATA
Case: SMB(DO-214AA)
Case Material: Molded Plastic. UL flammability
Classification Rating: 94V-0
Weight: 0.088 grams (approximate)
MAXIMUM RATINGS AND CHARACTERISTICS(TA = 25°C unless otherwise noted)
Parameter
Symbol S2A S2B S2D S2G S2J S2K S2M Unit
Maximum Recurrent Peak Reverse Voltage
DC Blocking Reverse Voltage
RMS Reverse Voltage
VRRM
50 100 200 400 600 800 1000
V
VR
V
VR(RMS) 35 70 140 280 420 560 700
V
IF
2
A
Non-Repetitive Peak Forward Surge Current @ t=8.3ms
IFSM
60
A
Thermal Resistance From Junction To Ambient
RθJA
35
°C/W
Junction Temperature
TJ
150
°C
Storage Temperature
TSTG
-55 ~+150
°C
Maximum Average Forward Rectified Current
ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise specified)
Parameter
Symbol Min
Forward voltage
VF
Reverse current
Diode capacitance
IR
CD
© SHENZHEN HOTTECH ELECTRONICS CO.,LTD
Typ
Max Unit
1.0
1.1
V
IF=2A
5
uA
pF
V=VR
30
Conditions
VR=4V,f=1MHz
E-mail:hkt@heketai.com
1/4
S2A-S2M
FIG.2: MAXIMUM NON-REPETITIVE FORWARD URGE CURRENT
3.50
IFSM(A)
IO(A)
FIG.1: FORWARD CURRENT DERATING CURVE
3.00
50
8.3ms Single Half Sine Wave
JEDEC Method
40
2.50
30
2.00
1.50
60Hz Resistive or Inductive Load
P.C.B. Mounted on 0.3"×0.3"(8.0mm×8.0mm)
Copper Pad Areas
0.50
90
70
10
110
130
TL(℃)
1
10
10
FIG.4:TYPICAL REVERSE CHARACTERISTICS
IR(uA)
IF(A)
FIG.3: TYPICAL FORWARD CHARACTERISTICS
100
Number of Cycles
TJ=25℃
Pulse width=300us
1% Duty Cycle
1000
US2A-D
1.0
100
Tj=100℃
0.1
10
US2G
0.01
HS2J-M
Tj=25℃
1.0
0.1
0.001
0.4
0.6
0.8
1.0
1.2
VF(V)
60
80
100
Voltage(%)
FIG.5: Diagram of circuit and Testing wave form of reverse recovery time
I
D
trr
IF
VR
IF
RL
t
IRR
IR
2/4
S2A-S2M
SMB Package Outline Dimensions
Symbol
Dimensions In Millimeters
Dimensions In Inches
Min.
Max.
Min.
Max.
A
5.00
5.45
0.197
0.215
B
3.20
4.00
0.126
0.157
C
4.30
4.70
0.169
0.185
D
1.80
2.20
0.071
0.087
E
2.20
2.50
0.087
0.098
G
1.90
2.30
0.075
0.090
H
0.95
1.25
0.037
0.049
I
0.05
0.15
0.002
0.006
K
1.70
2.10
0.067
0.083
L
0.90
1.60
0.035
0.063
N
0.10
0.30
0.004
0.012
SMB Suggested Pad Layout
Note:
1.Controlling dimension: in millimeters
2.General tolerance: ±0.05mm
3.The pad layout is for reference purposes only
3/4
S2A-S2M
SMB Tape and Reel
SMB Embossed Carrier Tape
DIMENSIONS ARE IN MILLIMETER
TYPE
A
B
C
d
E
F
P0
P
P1
W
SMB
4.10
5.50
2.58
Ø1.50
1.75
5.50
4.00
8.00
2.00
12.00
TOLERANCE
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
±0.1
SMB Tape Leader and Trailer
SMB Reel
REEL OPTION
13’’ DIA
TOLERANCE
D
D1
D2
G
H
I
W1
W2
Ø330
75.0
13.00
R165
R37.50
R6.50
12.40
17.60
±2
±1
±1
±1
±1
±1
±1
±1
4/4
很抱歉,暂时无法提供与“S2M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.11697
- 50+0.09203
- 150+0.07819
- 500+0.06988
- 3000+0.05931
- 6000+0.05541
