SS22-SS220
表面安装肖特基二极管
Surface Mounted Schottky Barrier Rectifiers
反向电压 20 ~ 200 V
正向电流 2.0 A
Reverse Voltage 20 ~ 200 V
Forward Current 2.0 A
特征 Features
DO-214AA/SMB
● 反向漏电流低 Low reverse leakage
● 正向浪涌承受能力强 High forward surge capability
● 高信赖性 High reliability
● 高温焊接保证 High temperature soldering guaranteed:
260℃/10 秒
260℃/10seconds
● 引线和管体皆符合RoHS标准
Lead and body according with RoHS standard
● 型号后缀“-F”标记无卤素产品
Green compound with suffix "-F" on Marking
机械数据 Mechanical Data
● 封装外形:DO-214AA塑封 Case:DO-214AA Molded plastic
● 环氧树脂:UL易燃等级:94V-0
Unit: inch (mm)
Epoxy: UL 94V-0 rate flame retardant
● 引脚:镀锡,无铅 Lead: Pure tin plated, lead free
最大值和特性 TA = 25℃ 除非另有规定。
Maximum Ratings & Characteristics
参数
Parameter
Ratings at 25℃ ambient temperature unless otherwise specified.
符号
Symbols
SS22
SS23
SS24
SS25
SS26
VRRM
40
50
60
80
100
150
200
V
VRMS
14
21
28
35
42
56
70
105
140
V
VDC
40
50
60
80
100
150
200
V
最大可重复峰值反向电压
Maximum repetitive peak reverse voltage
最大均方根电压 Maximum RMS voltage
最大直流阻断电压
SS28 SS210 SS215 SS220
单位
Unit
Maximum DC blocking voltage
最大正向平均整流电流
Maximum average forward rectified current
IF(AV)
2.0
A
IFSM
50
A
正向不重复浪涌电流 8.3 ms单一正弦半波
Non-repetitive peak forward surge current
8.3 ms singlehalf sine-wave
最大正向电压 @IF=2.0A
VF
0.55
0.70
0.85
0.92
0.95
V
Maximum forward voltage
最大反向电流 @VDC
TA= 25℃
Maximum reverse current
TA= 100℃
IR
典型热阻 Typical thermal resistance
(Note 1)
典型结电容 VR=4.0V,f=1MHz
Type junction capacitance
工作结温
0.5
0.1
RθJA
85
RθJL
25
CJ
180
TJ
-55 --- +125
mA
℃/W
pF
-55 --- +150
Operating junction
存储温度
TSTG
Storage temperature rang
-55 --- +150
备注 Note:
1) 安装在PCB板上,从PN结到周围环境的热阻。
1) Thermal resistance from junction to ambient , PCB mounted.
REV.1.1,2018-12
Changzhou zhide Electronics CO.,LTD
www.cz-zhide.com
SS22-SS220
特性曲线 Characteristic Curves
正向特性曲线(典型值)
正向电流降额曲线
IF(AV) (A)
10
1
0.1
0.1
0.5
0.9
1.3
1.7
IF(A) Average Forward Rectified Current (A)
FORWARD CURRENT DERATING CURVE
平均正向电流
IF Instantaneous Forward Current (A)
正向电流 IF(A)
TYPICAL FORWARD CHARACTERISTIC
2.5
2
1.5
1
0.5
正向电压 VF(V)
VF Instantaneous Forward Voltage (V)
25
50
75
100
125
150
175
环境温度 Ta(°C)
Tamb, ambient temperature (°C)
浪涌特性曲线(最大值)
反向特性曲线
MAXIMUM NON REPETITIVE
Typical Reverse Characteristics
PEAK FORWARD SURGE CURRENT
1000
30
Reverse Current(uA)
40
反向电流IR(uA)
IFSM Peak Forward Surge Current (A)
峰值正向浪涌电流 IFSM(A)
50
100
10
10
1
10
100
0%
20%
40%
60%
80%
通过电流的周期
额定峰值反向电压%
Number of Cycles at 60 Hz.
Percent Of Rated Peak Reverse voltage %
REV.1.1,2018-12
100%
www.cz-zhide.com
很抱歉,暂时无法提供与“SS26”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.16038
- 100+0.15682
- 300+0.15442
- 1000+0.15209
