SS52 Forward
THRU
SS520
Current - 5.0 Ampere
Reverse Voltage - 20 to 200 Volts
PINNING
PIN
Features
DESCRIPTION
1
Cathode
2
Anode
DO-214AA/SMB
2
1
Metal silicon junction, majority carrier conduction
For surface mounted applications
Low power loss, high efficiency
High forward surge current capability
For use in low voltage, high frequency inverters ,
free wheeling, and polarity protection applications
MECHANICAL DATA
Case: SMB
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 0.055 g / 0 .002oz
Unipolar
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS52
SS54
SS56
SS58
SS510
SS512
SS5150
SS520
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
5.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
150
A
Max Instantaneous Forward Voltage at 5 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating Junction Temperature Range
Storage Temperature Range
VF
0.55
IR
1.0
50
0.3
25
mA
Cj
500
300
pF
0.70
V
RθJA
50
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
(1)Measured at 1MHz and applied reverse voltage of 4 V D.C.
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.tw-gmc.com
0.85
1
SS52 Forward
THRU
SS520
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
6.0
5.0
4.0
3.0
2.0
1.0
0.0
25
50
75
100
125
150
10 4
SS52~ SS56
SS510~ SS520
10 1
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1
SS52~ SS54
SS56~ SS58
SS510~ SS520
0.1
1.0
1.5
100
SS52~SS54
SS56~SS520
0.1
10
1
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
500
Instaneous Forward Voltage (V)
175
25
1000
2.0
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
T J =25°C
10 0
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
10
100
Number of Cycles at 60Hz
www.tw-gmc.com
T J =100°C
10 3
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2
100
SS52 Forward
THRU
SS520
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMB
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
3.3
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
5.08
0.05
0.8
0.152
1.9
59
12
87
32
6
75
E1
max
96
185
155
220
7.9
min
84
160
130
200
2.0
The recommended mounting pad size
2.4
(94)
2.4
(94)
2.8
(110)
2.2
(86)
mm
Unit :
(mil)
www.tw-gmc.com
3
很抱歉,暂时无法提供与“SS56(SMB)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41181
- 100+0.33405
- 300+0.29517
- 3000+0.26601
- 6000+0.24268
- 9000+0.23102
