TSS56LB
TSS56LB
    ZHIDE(志得)
    DO-214AA(SMB)
TSS56LB 数据手册
TSS52LB-TS510LB 表面安装肖特基二极管 Surface Mounted Schottky Barrier Rectifiers 反向电压 20 ~ 100 V 正向电流 5.0 A Reverse Voltage 20 ~ 100 V Forward Current 5.0 A 特征 Features DO-214AA/SMB ● 反向漏电流低 Low reverse leakage ● 正向浪涌承受能力强 High forward surge capability ● 高信赖性 High reliability ● 高温焊接保证 High temperature soldering guaranteed: 260℃/10 秒 260℃/10seconds ● 引线和管体皆符合RoHS标准 Lead and body according with RoHS standard ● 型号后缀“-F”标记无卤素产品 Green compound with suffix "-F" on Marking 机械数据 Mechanical Data ● 封装外形:DO-214AB塑封 Case:DO-214AB Molded plastic ● 环氧树脂:UL易燃等级:94V-0 Unit: inch (mm) Epoxy: UL 94V-0 rate flame retardant ● 引脚:镀锡,无铅 Lead: Pure tin plated, lead free 最大值和特性 TA = 25℃ 除非另有规定。 Maximum Ratings & Characteristics 参数 Parameter Ratings at 25℃ ambient temperature unless otherwise specified. 符号 Symbols 最大可重复峰值反向电压 Maximum repetitive peak reverse voltage 最大均方根电压 Maximum RMS voltage Maximum average forward rectified current 单位 Unit VRRM 20 30 40 50 60 70 80 90 100 V VRMS 14 21 28 35 42 49 56 63 70 V VDC 20 30 40 50 60 70 80 90 100 V 最大直流阻断电压 Maximum DC blocking voltage 最大正向平均整流电流 TSS52L TSS53L TSS54L TSS55L TSS56L TSS57L TSS58L TSS59L TSS510 B B B B B B B B LB IF(AV) 5.0 A IFSM 150 A 正向不重复浪涌电流 8.3 ms单一正弦半波 Non-repetitive peak forward surge current 8.3 ms singlehalf sine-wave 最大正向电压 @IF=5.0A VF Maximum forward voltage 最大反向电流 @VDC TA= 25℃ Maximum reverse current TA= 100℃ 典型热阻 Typical thermal resistance (Note 1) 0.58 0.65 0.1 V mA 50 RθJA 60 75 90 RθJL 12 16 20 ℃/W CJ 160 pF TJ -55 --- +125 ℃ TSTG -55 --- +150 ℃ Type junction capacitance 工作结温 Storage temperature rang 0.50 IR 典型结电容 VR=4.0V,f=1MHz Operating junction 存储温度 0.45 备注 Note: 1) 安装在PCB板上,从PN结到周围环境的热阻。 1) Thermal resistance from junction to ambient , PCB mounted. REV.1.1,2018-10 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com TSS52LB-TS510LB 特性曲线 Characteristic Curves 正向电流降额曲线 正向特性曲线(典型值) IF(AV) (A) 10 1 0.1 0.2 0.6 1 1.4 1.8 IF(A) Average Forward Rectified Current (A) FORWARD CURRENT DERATING CURVE 平均正向电流 IF Instantaneous Forward Current (A) 正向电流 IF(A) TYPICAL FORWARD CHARACTERISTIC 5 4.5 4 3.5 3 2.5 2 1.5 1 0.5 0 0 正向电压 VF(V) VF Instantaneous Forward Voltage (V) 25 50 75 100 125 150 175 环境温度 Ta(°C) Tamb, ambient temperature (°C) 浪涌特性曲线(最大值) 反向特性曲线 MAXIMUM NON REPETITIVE Typical Reverse Characteristics 1000 150 90 60 Reverse Current(uA) 120 反向电流IR(uA) IFSM Peak Forward Surge Current (A) 峰值正向浪涌电流 IFSM(A) PEAK FORWARD SURGE CURRENT 100 10 30 0 1 1 10 100 0% 20% 40% 60% 80% 通过电流的周期 额定峰值反向电压% Number of Cycles at 60 Hz. Percent Of Rated Peak Reverse voltage % REV.1.1,2018-10 Changzhou zhide Electronics CO.,LTD 100% www.cz-zhide.com
TSS56LB 价格&库存
很抱歉,暂时无法提供与“TSS56LB”相匹配的价格&库存,您可以联系我们找货
TSS56LB
    • 5+0.95224
    • 50+0.77125
    • 150+0.69368
    • 500+0.59682
    • 3000+0.52789
    • 6000+0.50202
    库存:2780
